Question about Asrock 775VM800 Motherboard
Can't enter BIOS setup with F2
I can't enter BIOS setup by pressing the F2 key on start-up. F11 works and lets me set the boot order so I know it's not a keyboard problem.
I've also tried clearing CMOS as well. That didn't help.
I've also upgraded the BIOS to the latest version. That didn't help. I still can't enter BIOS setup.
  • 2 more comments
  • SBal May 08, 2008
    Yes, sorry I forgot to add that I also verified that the F2 key actually does work.
  • SBal May 08, 2008
    To XRAYRON, yes I repeatedly hit F2 as soon as power on. Sorry for not clarifying. I've worked with enough mb that I kind take it for granted as that being the way of getting into the BIOS setup.
    To Danmart, I'll try those tonight after I get home from work. And yes, after posting this yesterday, I tried a different keyboard -- no dice.
  • SBal May 09, 2008
    Those alternate key combos didn't work. It also dawned on me that none of the normal POST output is displayed. Might be time for a new motherboard.
  • Ronald Tisdale
    Ronald Tisdale May 11, 2010
    I'm curious if you have pressed F2 over and over and over as soon as you turn the PC on. Like hit power and start hitting F2 I've had a few mobos that would only goto bios like that.
Found this solution online. This suggestion did resolve my problem: " I confirm for my Microsoft Natural Multimedia keyboard. It has an F-lock key at the right of F12. By default, all function keys do the actions Microsoft assigned for them: Help, Undo, Redo, New, Open, Close, Reply, Forward, Send, Spell, Save and Print. If you want them to work as regular F1...F12, you have to enable F-lock after every reboot. Very aggravating. There's a way to swap the function roles in Windows, but F-lock still needs to be enabled at boot time after the keyboard is reset to be able to use F keys normally in BIOS or DOS."
Posted on Sep 17, 2011
One thing that I could suggesg is get a new very nice mother board for about $59.00. You don't want to send a payload to the moon?, do you ?. Well get yourself a nice 2nd hand mother board.
Posted on May 09, 2008
Posted on May 08, 2008
    Sergeant:
  • 291 Answers
Try Ctrl-Del
hold down escape key
hold down delete key
Tap the F2 key
Hold down escape & tap F2 key
P.S. u are doing this at different boot up times NOT all at the same time.
Did u change the keyboard?
    Scholar:
  • 103 Answers
Try using another application that has a use for the F2 key. I'm not totally convinced that your keyboard is good. It is possible for just one key to fail. Happens quite often.
D800 cannot change boot order
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart This will set the boot order If this fails you might try some of these Acer: - Ctrl+Alt+Esc
ALR PC: (F2) or (Ctrl)(Alt)Esc)
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl + Alt + Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc)
Feb 05, 2013 | Dell Latitude D800 Notebook
Floppy diskette seek failure during start-up
You can disable that by changing the boot sequence of your computer.
Turn on or restart your computer and watch for a message while your computer is restarting about a particular key, usually Del or F2, that you'll need to press to ...enter SETUP. Press this key as soon as you see the message.
You will a screen where it says BIOS Setup. Use the arrow keys to navigate to it and look for the option that says Boot Sequence or Change Boot Sequence. Each computer differs so I can't tell you the exact appearance of your computer's Bios Setup.
You can find the instructions on how to navigate in Bios by looking at the bottom part of the screen.
Change the boot order from there. Make your main hard drive as number one and the floppy drive in the last. You can see the instructions on how to do that in the screen in BIOS setup.
After changing the order. Save and Exit. It will restart automatically and observe if you still see the issue.
I hope this helps!
Please let me know if you need more assistance.
Carlo
Jan 26, 2013 | Dell Computers & Internet
Proper booting up, what needed to type f4 or f2
During the boot process you will see on the screen a certain key to press usually the Delete or F2 to enter setup this may vary depending on your computers bios other possible keys
Press and hold that key during the boot up process to enter BIOS using the arrow keys navigate to Advanced Bios features press Enter you will see what the boot order is set to.
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
If you are unsure on what the boot order should be you can load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart.
This will set the boot order.
Dec 01, 2012 | Microsoft Windows XP Professional With...
HAVE REALTEK RTL8101E/8102E ETHERNET CONTROLLER PXE-E61 MEDIA TEST FAILURE CHECK CABLE PXE-MOF EXITING PXE ROM LOOP. HAVE TRIED ADVANCED BOOT . CAN I USE RECOVERY DISK INSTEAD OF VISTA DVD WHICH I DO NOT...
It is important to isolate the cause of the "PXE-E61 Media Test Failure, Check Cable" error and solve it. To do this, follow the steps below:
  1. A loose or improper hard disk cable connection can be the cause of the error. This typically happens if the hard disk has recently been installed or moved. Check all of the hard disk's cable connections before trying anything else to solve the error.
  2. Make sure that no other storage device is connected to the computer. If there is a storage device connected, remove it.
  3. When computer start up is being attempted, enter the BIOS to see if the hard disk has been set up correctly and detected in BIOS. To enter the BIOS, follow these steps:
a. The key that must be pressed to enter the BIOS varies depending on the computer model. The key is most likely the Del key or one of the F keys. Many computers refer to this as Entering Setup and Setup is just another term used for the BIOS.
b. Try setting one's BIOS to any safe default settings. That might fix the error.
  1. Verify that the boot options in CMOS are setup correctly. Follow these steps to do this:
a. Enter the CMOS by pressing one of the following keys: F1, F2, Del, Esc, or F10. Press one of these keys when trying to start up the computer. If these keys do not work, try holding one or more keys on the keyboard when the computer is booting. This may cause a Stuck Key Error, which should allow the user to enter the setup.
b. If the CMOS setup shows an option to boot from the LAN, disable this option.
c. Try to set the CMOS settings to any safe default settings, then save and exit. After changing any settings, reboot the computer.
  1. It is possible that physical failure caused the error if the hard disk cannot be detected. If this is the case, replace the hard disk and restore one's data if a good backup is available. If one does not have a good backup, contact a company that provides data recovery services. These companies perform hard disk recovery and securely retrieve one's valuable data.
Check that the drive is detected in BIOS:
  1. Press F2 during boot to enter BIOS Setup.
  2. Go to the Boot menu.
  3. Check the Boot Drive Order.
  4. Press F10 to exit BIOS Setup.
If Boot Drive Order shows No Boot Drive:
  • Check that the drive is properly installed in the computer.
  • Try installing a different known good drive.
If PXE Boot is enabled in BIOSTo check the BIOS option:
  2. Go to the Boot menu and check for Boot to Network.
  3. Press F10 to exit BIOS Setup.
If you do not plan to boot to a network, disable this option.
If you do want to boot to a network, check that the network cable connection is working properly.
Dec 29, 2017 | Toshiba Satellite Laptop
Hp Compaq nc6220 Laptop. there begin booting one msg "163-time & Date not set". how to resolve this problem.
go to your BIOS setting
There set the current date and time
[while starting the computer , there will be screen showing options keys for bios setting (it will probably be esc or f12 or f2 or f11)]
Jul 19, 2011 | HP Compaq nc6220 Notebook
How to install change first boot divice on ibm thinkcentre computer
You must enter the "BIOS" at start up (sometimes called SetUp). Press F2 or F8 or F11 or other function key that will be required by your computer. Should tell you at boot.
Enter the BIOS settings, find the boot sequence and edit it. remember to save your changes.
BE VERY CAREFUL WHAT YOU SELECT!
Thanks for your visit today.
Feb 01, 2011 | IBM ThinkCentre A50 PC Desktop
My laptop doesn't boot my windows 7 DVD please help me
This problem can be happen if DVD ROM of laptop is not working or BIOS setting is not set for booting from DVD drive. If DVD ROM is not working then change it. Go to BIOS setting and choose first boot device as DVD ROM if it is BIOS setting problem. This can solve your problem. It is always good to buy licensed copy of OS and other software.
Thank you..
Nov 11, 2010 | Computers & Internet
I Have an old HP pavillion model N3410. I am trying to access BIOS or change boot order but it won't let me. I've tried pressing f2 during reboot but it goes straight to normal windows me startup.Also...
Turn the computer off.
Hold down any key on the keyboard, and turn the computer on.
You might get a "keyboard error, press <something> to enter BIOS SETUP".
Also, instead of F2, try F1 or F10 or F11 or F12 or DEL.
Aug 20, 2010 | HP Pavilion N3410 Notebook
Boot from cd
when u power up the computer press DEL or F2 or F10 F12 key to enter bios setup.
then go to boot option then set your dvd or cd as first boot device.
Nov 30, 2008 | Intel Motherboard
Replaced hard drive
either should work.... however you may need to press a key when propmted to boot from CD
if this does not happen you may need to check your boot settings in BIOS (setup) press F1/F2/F11/del whatever the propmt tells you to press to enter setup when you first boot
Sep 27, 2008 | Toshiba Satellite A75-S211 Notebook
Asrock 775VM800 Motherboard Logo
2,236 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
