Question about Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television
Bulb replacement need step by step instructions on how to replace bulb. how to remove housing,how to replace bulb & how to reinstall thank you ray g
  • 50 Answers
The instructions should have come with the bulb. Ask the seller for the instruction
Posted on Mar 10, 2010
SilverCrest Microwave SMW 800 A1 Bulb replacement instructions please
You have to remove the outer cover but be aware that after removal you are exposing yourself to potentially lethal voltages even with power removed. Remove the old lamp and install the new lamp you have kept on hand for this occasion. Reinstall the cover but test operation before reinstalling all hardware in case the replacement lamp does not work.
Aug 16, 2016 | In Microwave Ovens
Tip
How to Replace the Bulb in a Projection TV
Instructions Things You'll Need:
  • Rubber gloves
  • Replacement bulb
  1. Step 1 Turn off the TV, and unplug it. Make sure to disconnect it from the outlet completely.
  2. Step 2 Locate the bulb door of the TV. This is often on the back, near the power cord. Slide the door open and reveal the bulb.
  3. Step 3 Unscrew the screws. Some screws are thumbscrews, while others may require a screwdriver.
  4. Step 4 Gently remove the bulb. Pull the bulb out of the compartment, usually by grasping a handle and then pulling out and slightly down.
  5. Step 5 Install the new bulb. Line up the groove on top of the new bulb's housing with the groove pocket on the inside of the television. Slide the new one into place.
  6. Step 6 Tighten the screws. Do not over tighten them; they should be finger-tight only.
  7. Step 7 Close the door. Make sure it is closed completely or the TV will not operate.
on Mar 24, 2010 | Televison & Video
How do i remove lamp to replace it? Thank you
Hello there,
Please follow the steps below to be able to replace the lamp,
  1. Park the vehicle on a level surface. Turn off the engine.
  2. Remove the four pushpins located on the underside of the protective shield on the front of the vehicle. Remove the protective shield from the vehicle.
  3. Reach behind the front bumper area from under the vehicle to access the lamp housing.
  4. Remove the largest bulb socket from the housing by rotating the socket counterclockwise. Disconnect the electrical connector from the bulb by lifting the two plastic clips at the base of the bulb.
  5. Pull the burned-out bulb out. Replace it with a new bulb by pushing the new bulb directly into the socket. Reconnect the electrical connector to the socket. Place the socket back into the housing. Rotate it clockwise to secure it in place.
  6. Reattach the protective shield to the front of the vehicle by reinstalling the pushpins.
Hope this helped. Goodluck Elect_Comp
Aug 30, 2011 | Cadillac STS Cars & Trucks
How do you replace the headlight on a 2002 Daewoo Lanos
Hi there, together with providing you the solution to the problem, I also took the liberty of going one step further in giving you steps on how to remove the headlight bulb.
  • Find the hood release handle and activate it, the hood should pop open.
  • Once the hood is popped open locate the hood secondary or safety latch and release it. Then finish opening the hood.
  • Locate and remove mounting clips for any plastic shields that cover the headlight lens mounting screws or clips.
  • Some headlight bulbs can be replaced by simply grasping the bulb socket behind the headlight lens and turn it counter clockwise to remove it. This will expose the headlight bulb.
  • If the headlight bulb socket is not accessible the headlight lens may need to be remove or obstructions behind the bulb removed to gain access to the headlight bulb socket.
  • To remove the headlight lens remove all mounting screws and clips that hold the headlight lens in place.
  • After the headlight housing has been removed from it's mounts, release the headlight bulb from the headlight lens housing (turn counter clockwise) the bulb will then come out of the headlight assembly. Once removed, visually verify that the replacement bulb is exactly the same as the failed bulb before to ensure a proper repair.
  • Clean the headlight lens free from all debris to help maintain the seal from the bulb to the lens. This will keep moisture out of the lens.
  • Install the new headlight bulb by turning the retainer ring or bulb clockwise.
  • Re-install the headlight lens housing and reinstall electrical connector.
  • Re-install plastic covers.
After the job is complete turn the ignition key to the "on" position and activate the headlight switch. Observe the newly replaced headlight bulb to ensure proper operation.
Glad to be of help!!!
Jan 21, 2011 | 2002 Daewoo Lanos
Simple situation - need to replace right headlight on my 1993 Jeep Cherokee, but have no manuel. Can you provide step-be-step instructions ? thanks
Very easy. You don't have to remove anything but you will be working in a slightly cramped space on both sides.
Open the hood, the bulbs come out through the backs of the housings. The wiring plugs into the back of the bulb, unplug the bulb. The bulb itself is held in by a round locking collar. Twist it and than pull the bulb out. Reverse to replace.
Good luck.
Nov 07, 2010 | Jeep Cherokee Cars & Trucks
I need a picture or instructions showing how to replace front turn signal bulbs in a 93 lebaron convertible
Resmove the two screws that secure the light housing, pull the housing out to expose the bulb socket,turn the socket clockwise to remove it from the housing, pull the bulb out and replace and reinstall
Aug 22, 2010 | 1993 Chrysler Lebaron
Replace a headlight bulb
When you open the hood opened, looking at the headlight housing, there are two bolts at the top of the housing that has to be removed. For this you need to access and remove the black plastic cover to access both of them. When the bolts are removed, lift from the top and it should pull out. You will need to turn the bulb retaining ring to free the bulb from the housing.By reverse the above said instructions you can put it all back together.
Thank you !!
Jul 05, 2010 | 2001 Pontiac Sunfire
HOW TO CHANGE HEADLIGHT
  1. Open the hood.
  2. Remove push-pin fasteners from the grill assembly.
  3. Tilt the grill assembly forward and lift it up to remove it from the vehicle.
  4. Remove the fasteners from the headlamp assembly.
  5. Push the headlamp housing lever up to disengage the headlamp housing from the headlamp housing pocket.
  6. Turn the bulb socket being replaced counterclockwise one-quarter of a turn while pressing the socket in firmly.
  7. Pull the socket rearward until the bulb clears the headlamp housing, and lift it up to access the bulb.
  8. Disconnect the wire connector from the bulb by lifting the lock tab and pulling it away from the plastic base.
  9. Remove the bulb assembly and replace it with the appropriate bulb.
  10. Reverse the steps to reinstall the headlamp assembly.
May 05, 2010 | 2003 Saturn L-Series
Do I need to remove my fairing to replace the headling bulbs?
well you can please follow the below steps -
Remove the Fairing - 1. Unscrew all seven outer fairing fasteners using a Torx driver. These screws are located on the inner fairing near the windshield, the speakers, and the handlebar clamps.
2. Stand in front of the motorcycle. Tilt the outer fairing toward you and hold it firmly. Reach in and disconnect the wire connectors for the headlight assembly by hand.
3. Move the fairing to a work bench to continue the procedure.
Change the Headlights - 1. Remove the wire harness connectors from the back of each headlight that need replacement. Turn the plastic retainer counterclockwise by hand to remove each bulb from its housing.
2. Install the new headlight bulb or bulbs, with each bulb's wider ears on the bulb back plates oriented toward the top. Screw in the plastic retainer rings by hand.
3. Connect the headlight wire harness connectors to the back of each headlight.
4. Move the fairing back to the motorcycle. Reinstall the fairing, battery and seat in reverse order.
Please post comments if you need more help or information.........
Good Luck!!
Thanks
Mar 17, 2010 | 2004 Harley Davidson FLTRI Road Glide
Replacing 96 Ford Aerostar Headlights
try www.autozone.com to see if they have your car listed for diagrams pictures and step by step instructions if your car is not listed then try your local library they have all the car manuals and even copy them for you
Mar 20, 2009 | 1996 Ford Aerostar Extended
Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television Logo
155 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
