Question about Car Audio & Video
Brutus 1600 watt hi fonics amp
My protect light wont go off. my brother says i could of blown a channel
I have had the same problem with one of my amps that was given to me by a friend and one of the channels were blown. Blowing a channel can cause the protect light to stay on.
Posted on May 08, 2008
I have a brand new Hifonics amp 1500 watt Brutus the only thing that powers up is the logo the power light and protection light stay off the amp brand new out the box what can be the problem
Some amps will not power up internally if u donot have remote wire. Also if u connect power then remote wire it will not power up until u reconnect in correct order. But if all that is ok. Than u have a bad amp
Mar 11, 2017 | Hifonics Car Audio & Video
I have a hifonics brutus 1606d 1600 watt amp it gets power green light is on lit up across the top but i cant get any sound
Your amplifier may have experienced circuit failure other than a dead short that still allows power to be applied
Dec 05, 2016 | Hifonics Car Audio & Video
I have a xx zeus 1600 rms amp when i plug in the bais control knob the musuc cut of and protect light comes on what can be the cause knob dont even light up
did bias plug come with amp or is this aftermarket?
bias knobs are manufacturer specific. do not assume 1 bias control will work with different amps.
(even though the RJ11 jack is similar, they are wired differently)
your lucky your amps internal circuitry is detecting the short your introducing.
May 08, 2011 | Hifonics Brutus BX 2005D Car Audio...
I have a brutus bxi 1206d 1200 watts, and the amp is coming on fine not protected. But there is no sound output. u can hear a small feedback rumble when connecting the input rca's. But thats it. My...
i would check the speaker cables to see if something came disconnected first maybe wire i touching other terminal shorted out the channels output .
run a new set of rca cable to see if one use are bad . check to see if rca cables pluged into right output of radio . check to see if your remote wire is powering up the amp to turn on the amp ..
will still light up with battery power but will never put output to the speakers with out the remote turn from the radio ... how to check this is to disconnect the cable at the amp and take a short 18 gauge wire and strip both ends and touch the battery terminal at the amp terminal one end the other end where the remote wire is mounted on the amp if do this for a few seconds to see what happens or better yet buy a digital volt meter and check for 12volt a the remote wire when you turn on your radio
Dec 23, 2010 | Hifonics Brutus BXi 1206D Car Audio...
Protect mode
Protection circuit.
Checek the wiring of the amp and speakers, don' forget to look for shorts at the speakers. Make sure no wires are touching each other
Apr 30, 2010 | Volfenhag 1600 WATT CHROME AMP AMPLIFIER 2...
Amp not working
sounds like the amp is going into protection mode. maybe a sub is shorted (blown). Or, the only other possibility is the mosfet transistors on the inside of the amp are blown.
Feb 01, 2010 | Hifonics Brutus BX 1205D Car Audio...
How do I fix the problem so they work again.?
A 1000 WATT AMP HAS PROBABLY GONE INTO PROTECTION MODE BECAUSE YOU ARE TRYING TO RUN 1600 WATT SUBS COMBINED
Jun 08, 2009 | Car Audio & Video
Speaker amplifier calculation
for $85 i can sell you an Almani 900 watt 2 channel amp i would stay way away from those 3 brands they are all really poor quality and i can get you any major name brand cheaper.
I can get you a hifonics 4008 amp (800 watts peak 100 watts per channel rms) for $100 shipped with full factory warranty. you find an amp you like and i will get you a price. I am a factory wholesale distributor for most brands.
Jan 08, 2009 | Legacy 2 Channel 1600 Watt Bridgeable...
Amp Not working!
If the amp goes into protect mode, it's likely due to shorted output transistors. To eliminate other possible problems, read through the following page:
Amp in Protect Mode - Troubleshooting
If the problems are not with the wiring, follow the link at the bottom of the page to the Amplifier Repair Primer page.
Let me know if you have any other questions.
Sep 20, 2008 | Power Acoustik TS620-2 Synchronized...
2006 12" Kicker L7 4 ohm
first whats the range in terms of WATTS that your 12" sub can handle in 4 OHMS ? second , lets check the AMP , POWER ACOUSTIK 1800 WATTS , Now thats a lot of power to drive a single 12" sub speaker . your amp is 1800 watts , per channel is around 500 watts , if BRIDGE thats around 1600 watts rms for ONE channel , if your sub can handle that kind of wattage fine , but it will not blow the amp , what it does is shuts down , some kind of protection mode , it will come back on after a minute or so. I suggest to use one channel in stereo mode , or purchase another sub to use the other channel. i hope this helps AJ
May 06, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Car Audio & Video Logo
334 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
