Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
We just purchased a Craftsman Lawn Mower model #247.38909 that has a built in 'deck wash' feature. After mowing the lawn, we tried to use that feature. We connected the hose as directed to the coupler and attached the coupler to the water port. No water comes out. There is something about the coupler that is preventing the water to go through. We double-checked all connections - still no water passes through the coupler. Any ideas?
rockitman187
  • 2559 Answers
SOURCE: i need a manual to show me how to adjust the belt
Here is a link to the manual
Please rate this a fixya.
Posted on May 15, 2009
wadembly
  • 448 Answers
SOURCE: Craftsman lawn tractor model new battery drains quickly...
it could be the stator in the engine check the voltage with the volt meter when its running if its low check connections on battery & voltage if its below 12.5 volts then its the stator but the only thing is the engine should run with-out the battery so there is something else going on there is a fuse in the electrical system if theres a short that fuse will blow & engine will stall
Posted on Jun 08, 2009
wadembly
  • 448 Answers
SOURCE: I have a craftsman electric key start lawn mower.
the battery probably got over charge & shorted the cells the tractor should charge the battery as it runs if it was equiped with electric start the battery charger more than likely over charged it killing the battery
wadembly
  • 448 Answers
SOURCE: Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Posted on Jul 05, 2009
bargainbin2
  • 123 Answers
SOURCE: Craftsman 42 inch cutting deck riding lawn mower.
Some of the 42 inch Craftsman mowers Have a cable that goes from the blade leaver to the deck some have a linkage if it has the cable check it to see if it has broken. Find where it connects to the deck pully and pull on the cable wire not the cable cover and see if if comes out also make sure it is connected to the top of the idler pully. If it has a linkage there is a clip that holdes that linkage to the deck it most likely came off.
Posted on Aug 28, 2009
Soon I need to cut the lawn, advise please lawn mowers ?
If you care both of your lawn's beauty and for the planet's health, buy one of our eco-friendly and ergonomic reel lawn mowers to preserve your world in perfect harmony! https://www.bestadvisor.com/push-lawn-mower
Apr 04, 2017 | Garden
Model 56145. How can I remove mower deck?
Look, lower deck as low as it will go, look above deck, under the tractor and pull any pins holding deck to the control arms etc., and remove belt sufficiently to slide deck out from below tractor, I advise you to take pictures to make assy. easy.
How to remove the mowing deck from lawn tractor
Craftsman Deck removal How to
Removing and attaching mower deck
How to Remove the Mowing Deck From Toro eHow
Jun 17, 2012 | Toro Garden
Grass cutting blowing out from in front of mower deck.
Dull or bent blades can cause this. Make sure that the grass is not built up under the mowing deck. You can purchase new blades at a Toro dealer like www.arcolawn.com.
tell them Joe from Fixya sent you!
Feb 12, 2011 | Toro LX466 22HP Lawn Tractor 13RT61RH244
I need a deck diagram for a 19.5 hp 42' cut
Craftsman 42 in deck makes terrible noise and middle wheel shakes. started while mowing.
Jul 26, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Disengaging blades when mowing completed
the cam plate that the tensioner pulley is mounted on that rotates back around to tighten the belt as the cable or rod is engaged is likely rusted and worn, there is a bushing in this pivot that can be removed and cleaned fairly easily with a abrasive wheel or pad and lubricated upon reassembly.
Jul 04, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman riding lawn mower steering shaft fell. Mower will not steer. I just started mowing, and the mower quit steering. Looked underneath, and it appears the shaft came loose that is used to steer. Any...
Look under the seat of your tractor and note the complete Model number.
(usually begins with 917. _ _ _ _ _ _ )
Next, go to THIS PAGE and use the Model Number to find an exploded view of the steering components and how they assemble.
Hope this helps,
Dolf-
Oct 15, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Rider mower won't go forward or back
Ihave craftsman Lawn Tractor was cutting grass and it stop moving forward or backward. Can you help me
May 16, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman Lawn Tractor - Electrical
make sure you mower deck is not still engaged. that might make it not start with that safety switch.
Oct 04, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
55 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
