Question about Koolatron (2526435) Beverage Cooler
Kooltron blows 15 amp fuse in car. Rewired it due to possible short in wires but still blows the fuse in the car.
I have a problem with the 15 amp efi fuse blowing on my 2001 toyota camry. As well as the 15 amp gauge fuse blowing
if there is no shorts, rig a amp meter in series in place of the fuse, if it reads around twelve or more amps some thing else may be wired into the circuit , if the reading is very high there may be a short to earth some ware.
Jul 02, 2015 | Toyota Cars & Trucks
92 geo tracker keeps blowing fuel fuse 15 amp but when I go to a 20 amp it is fine gas tank is haff full of fuel what is my problem
first off each fuse has a name , so what is the correct name, the 92
has 3 EFI fuses, DOME (memory) IG-Coil (ecu and spark) and "FI"
never up the amps ever or burn the wires up. sorry but that is a FACT. the a above data is wrong, this cars pump draws 4amps.
if more its bad, sure if over 15 it blows, but is a bad pump.
all pumps like to do that, they burn up and suck power, like a piggy.
see your fuse here, linked,
this car and ECU nor know for shorted pumps and shorted ECU
the 92 uses these JUNK brand caps, large electrolytic caps.
and they love to short, on all 89 to 95 trackers and sidekicks in usa.
they are marked Rubycon.
so again which fuse?
ill pretend its FI blown
http://www.fixkick.com/power-elect/blows-fuse.html#FI_blows
FI is bottom right, lost the cover? now you have one.
http://www.fixkick.com/Elect-fail-index.html
is engine 8 valve or 16?, they have different EFI , systems.
Im sure its FI, as it runs ECU and pump. so..... and they love to blow.
ok i throw dice for you, land on 8v.
see 8v FI fuse here?
http://www.fixkick.com/ECU/8v-tbi-schematic91to95.jpg
what i do is remove the left rear tail light,lens.
then see the pink pump wires, I measure the pump current
i reads 4 amps, with helper keying on over and over.
see?
now if near 4amps, then the ECU is shortings it CORNER cap.
http://www.fixkick.com/ECU/ECU.html
the caps dry out,inside, leak acid , wreck copper traces
and then the cap shorts, some times , it loves to short on speed bumps. due to vibration, its just a bad 50 cent part
that any tech can change or any HAM radio guy, etc.
with simple soldering tools and skills
do tell engine type G16a or b (a= 8v, and b = 16v) and we can
point to exact part bad.
Jan 29, 2015 | Geo Cars & Trucks
Why do i keep blowing 15 amp fuse on my 1982 suzuki gs 1100 gl?
you have a short.
check wiring near head stem and handle bar switch blocks
May 17, 2014 | 1981 Suzuki GS 750 L
Number 15 fuse keeps blowing
Possible causes:
- Fuse is under rated.
- Short circuit in wiring.
- Fuse No. 15 is overloaded.
- Positive wire is shorted to ground.
- Check all the loads one by one which are put on this fuse.
Apr 25, 2014 | 2010 Peugeot 206 SW
Replace 15 amp fuse to a 30
NO,NO,NO ! Fuses are electrical protection for the cars wiring installing a higher amp-age fuse takes longer to blow so your wiring gets hotter and starts to melt the insulation and shorts to other wires eventually burning up the harness. With a amp meter test the circuit to see how much power is needed to keep the circuit going if over rated (15 amp circuit taking 20 amps) then install a cycling circuit breaker 10 amp this will blow and cool and blow again continually then with a magnetic amp meter (Gauss meter) you can locate your short the source voltage causes the amp meter to jump as the fault occurs when you pass it meter will stop working.
Apr 22, 2014 | 2002 Ford Escape
Why do fuses blow
overload will blow you fuses.short to ground. wtich fuse is blowing?
Apr 16, 2014 | 1998 Acura TL
SHORT CIRCUIT
The question is not very clear, but I assume that you blow the main fuse when you connect the amplifier to the battery.
First make sure that you have the correct fuse rating (amperage) installed. Then try connecting the power to the amp with the speakers disconnected. If the fuse still blows, you have shorted output transistors in the amp. This could be expensive to repair. If the fuse does not blow, your speakers could be short circuit as well. It is very possible that both the amp and the speakers are shorted.
Sep 07, 2017 | Lightning Audio B4.250.2 Car Amp
All the lights work except the dash lights. The 5 amp fuses keep blowing and if I put a 15 amp it doesnt blow but no dash lights
DASH HAS A SHORT CIRCUIT.DASH NEED REPLACING BUT CHECK FOR SHORTS IN THE WIRES TO DASH.DONT PUT A LARGER AMP FUSE IN A CIRCUIT TO KEEP FROM BLOWING FUSE BECAUSE IF FUSE DONT BLOW WIRES GET HOT IN THE CIRCUIT THAT HAS A SHORT IN IT AND CAUSE A CAR FIRE.
Nov 04, 2010 | 1992 Ford Thunderbird
Fuse blowing on interior light/ remote
Was the bulb the same size and watt as the one you removed? Did you possibly cause a short in the fixture. I do not recomend using a larger fuse due to possible wiring dammage (risk of fire). Check the bulb for size and wattage/voltage check the holder to make sure it is not grounding out. Carefully check each step 2x.
Sep 20, 2009 | 2005 Volkswagen Passat
You have a 1999 Jeep Cherokee a 15 amp fuse in the motor compartment keeps blowing out
To isolate this problem, you need to trace the (+) wire connected to fuse. Its possible that part of the wire connected to that fuse is rubbing with your chassis or with other cables thus creating a short. If you are still unsure what to do, its best to have your car checked by an electrician.
May 03, 2009 | 1999 Jeep Grand Cherokee
Koolatron (2526435) Beverage Cooler Logo
Top Koolatron Refrigerators Experts
Ilia Bichin
richie46
Your Consultant
Are you a Koolatron Refrigerator Expert? Answer questions, earn points and help others
