Question about Coby MP-C883 MP3 Player
Reformatted, then won't play?
I plugged the player into my computer, and almost immediately it said that I had to format the thing. So I did, I loaded the songs onto the player, popped in the headphones, hit play...
And nothing. No sound, nada. The lil light blinks when I hit play, but nothing else. Do I need a new battery? (I haven't tried this yet, because we have no AAA batteries on hand at the moment)
Also - where is this supposed 'firmware' of Coby's? And why isn't it available online? Did reformatting the drive remove the firmware? Do I need it?
  • Anonymous Dec 28, 2008
    i reformatted my sons mp3 its a sansui 1gb credit card mp3 player and now when i load the songs on the lights come on but i have no sound
    what can i do to fix this problem before my son finds out i have done this lol
  • 537 Answers
Check this site for support for the Coby MPC883:
http://www.cobyusa.com/?p=prod&prod_num_id=1015&pcat_id=1001
I would make sure that you have good batteries when using/testing this MP3 player
COBY Electronics Technical Support
Address: 56-65 Rust St.
Maspeth, NY 11378
Hours: Monday to Friday, 8:30 AM–11:00 PM EST
Saturday to Sunday, 9:00 AM–11:00 PM EST
Phone: 800-681-2629 or 718-416-3197
Email: techsupport@cobyusa.com
Posted on May 08, 2008
My Sansa Clip lost all the music I had stored. It
You go to Settings, check System Info, check number of songs in there. If they are existing, you should change to MTP or MSC to play it. Or go to Settings, Reset All, Yes. Try it.
If you accidentally formatted it, can't restore them.
Good luck
Jan 24, 2010 | SanDisk Sansa Clip MP3 Player
I need a driver!
When connecting the player to a computer with XP it should be detected directly in Windows Media Player when:
1. The player is not locked.
2. Media Player 9 or 10 is installed and updated.
If the player does not respond or seems to be "frozen", the data on the
device might be corrupt. Then the player should be reformatted: this will erase all data ! How to format, see step 1 and 2:
STEP 1 - Connect the device to the computer
1. Remove the battery from the player’s battery compartment.
2. Put the hold/lock switch to lock.
3. Plug in your device to the computer.
STEP 2 - Format the device
1. Double-click My Computer.
2. Right-click on the player, which might show up as a Removable Drive, select Format.
3. Click Start.
4. Click OK when a "Format Complete" dialog appears.
5. Click Close.
There are also updates/reinstallations for the player's firmware
when needed.Press play/pause/up button and repeat/ab/down button
to see the software version; model number, storage capacity.
Need more help ? Just post a comment.
Dec 17, 2009 | SanDisk Sansa m250 MP3 Player
Format error
Take note that if you have reformatted your drive all file inside were lost. Basically mp3 players can play only mp3 format. If the format of your songs inputted to your mp3 player are not the same with the format required to your player nothing should be happen to play.
If the required of your player is mp3 so you need to put only mp3 format. No other format should be played. If your download songs are wma format convert it to mp3 format.
Regards
nicole
Oct 03, 2009 | Audio Players & Recorders
Usb device not recomized
fist reset the set manualy !
if you have the initial executing files that were on your mp3 when you bye,
Format your Mp3 on PC by FAT32 format and copy those on your Mp3 player folder
Sep 29, 2009 | Sony Network Walkman NW-E005 MP3 Player
"Not enough space for music DB. Please free up 30 MB"
The mp3 manufacturers are often being disingenuous - they plug an mp3 player into a Macintosh, and it shows up, so they say, "Hey! It's Mac-compatilbe!" But, the software is certainly not Mac-compatible, so if you ever experience a problem, there is no way to fix it. Also, the Sansa e200 series does not recognize iTunes format.
In general, I would agree that you need to reformat your player, but I have no idea how to do that on a Mac (I'm good at a lot of things, but I'm Mac-illiterate).
-Tha Mp3 Doctor
Mar 15, 2009 | SanDisk Sansa e250 MP3 Player
Recorded audio CD will not play
Most likely the recorded format is wrong and that is the cause.
May 05, 2017 | Bose Wave Radio
Songs appear but don't play
I'm pretty sure m230 is supposed to play WMA files, but I don't use that format. Drop a MP3 file in the Audible folder and make sure it plays. xlthim.
Jul 21, 2008 | SanDisk Sansa m230 MP3 Player
File System Error?!
I have the 4GB version (non-FM) and it's having the same issues. I reformatted mine to the NTFS filing system in hopes of uploading my songs faster since these players run on FAT32, but reformatting it to any file system other than FAT32 will cause it to give a File System Err notice on your player. I would suggest reformatting it to FAT32 using your computer. There are resources available everywhere online that shows you how to do this.
Mar 02, 2008 | Coby MPC895 MP3 Player
Format error
When you get the format error there is a couple of things you can do first try this if it has been reformatted and there isn’t any files on it get the sonic stage installer online somewhere not sure where run that and follow its prompts and when this is finished it should put the correct software onto the player which you can open to see if it is there. Then disconnect the player from your computer and hold down the search button for about half a second when the player is in stop mode rotate the switch at the top of the player till you get “advanced menu” and then press the play button to select it and rotate the switch again till you have “format” and press the play button to select formatting will blink and start formatting when finished complete comes up press the search button to get out of it and back to the main menu and hopefully it will work now!!! It worked for me anyways and couldn’t find a simple answer online so I said id throw this up there!!! Hope it works for yee too!!!
Oct 24, 2007 | Sony NW-E405 MP3 Player
Ilo mp3. incorrect fomatt reformatt the player.
Plugging it into your friend's pc cause the player to be reformatted in a way that it no longer likes your computer.
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Jul 28, 2007 | iLO (2 GB) MP3 Player
Coby MP-C883 MP3 Player Logo
265 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
