Question about Yamaha CDC-755 5-Disc CD Changer
Yamaha CDC 755 5cd disc changer door will not open
techman
  • 3130 Answers
SOURCE: my CD changer's disk tray keeps opening up, refuses to play discs
You have a problem with the try control circuit. It could be the switch is leaking across itself. Could be a problem with the tray motor control IC, or the Microprocessor is not reseting the open tray line correctly, or theres a cam assembly inside the unit that tells the microprocessor where everything is by means of small micro/leaf type switches thats out of alighnment or broken. If its seven years old, you got more then it was designed for and I would'nt invest a dime or the time into the repair of this unit. Time to take a trip to the electronics store. Good luck
Posted on Jul 21, 2006
  • 85 Answers
SOURCE: Tray won't open.
Drive belt for draw is duff needs replacing
Posted on Jan 08, 2009
petraman7
  • 1175 Answers
SOURCE: Disc door keeps opening.
The drawer belt may also lift the laser up to meet the CD . If the belt is bad , the CD player will kick out the CD.
Change the belt.
Try studiosoundelectronics.com
or
mcmelectronics.com
Posted on Jan 12, 2009
  • 5 Answers
SOURCE: Door to load cd's wont open or close without help.
hello i have had the same problem with my 5 cd changer,i way i solved this was to turn the player top slide down then do this care fully ,shake it gently and see if a cd came out of it, groove sit in the player.if you hear a rattle than there is a stray cd in the device. you have got to shake the cd to the front of the cd dawer to take it out with a thin ruler or a butter knife but be care ful with the knife preess on the open button wale trying to slide the butter knife between the stuck cd and the inside of the cd sit cation be care.
Posted on Apr 25, 2009
localwonder
  • 6784 Answers
SOURCE: Note: CDC-625 unit won't open, no discs inside
Hi, this is a failed load motor. the windings are busted, in return, making it weaker than normal. it will not be able to move the gear assembly in this case.
The bad news is m the actual replacement parts for your unit has been discontinued. this will make it hard to repair.
I would cut the loss and just by a new unit. you wont be able to purchase any repair parts for this unit.
Posted on May 28, 2009
Yamaha cdc 697 cd player wont play disc
There are so many reasons for this fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 14, 2014 | Yamaha CDC-697 - CD changer 5-Disc CD...
Yamaha CDC-645 not playing
The lazer is shot. Could cost $150 to $280, to have it (repaired)
Oct 22, 2012 | Yamaha CDC-685 5-Disc CD Changer
CDC-735
Part Number VQ776900. I got it online for 99 cents but other places can be up to 7-8.00 dollars. I removed 5 screws on the sides and rear of the case. Took case off. Press the open button and help the drawer open with your hand while the motor tries to. Then remove old belt with pliers or paper clip, etc.
I did not take anything apart on the inside to replace the belt. Push the belt into the player over the larger wheel and then I pulled the belt with a paper clip over the smaller drive wheel.
Mar 17, 2012 | Yamaha CDC-755 5-Disc CD Changer
Need drawer belt for Yamaha CDC-805 CD changer - the one needed that opens and closes the changer's door - not sure where to get it or the part number. I thought I ordered the right one and got the 'drive'...
Any decent repair shop should have a large supply of replacement belts. The Part number isn't necessary. Just take the old one in and get a new one just 2mm smaller than the original. Some repair shops won;t sell them because they don't want you repairing your own property but a decent shop should sell you one.
Apr 07, 2010 | Yamaha CDC-745 5-Disc CD Changer
The disc tray of my Yamaha cdc-745 CD player does open properly.
It's the belt inside the machine - open tray and look in front left side and you will see it. Easy to change out with new one.
Dec 13, 2009 | Yamaha CDC-745 5-Disc CD Changer
The changer does not detect CDs in it. After
Optical pick up replacement required to rectify this problem
Nov 26, 2009 | Yamaha CDC-697 - CD changer 5-Disc CD...
Change the belt.
or
mcmelectronics.com
Jan 11, 2009 | Yamaha CDC-585 5-Disc CD Changer
Yamaha CDC-755 5-Disc CD Changer Logo
199 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
