Home
My Products
Sign In
Back to:
All Products
Olevia
LT23HVX 23 in. LCD Television
Troubleshooting
Tags
tv will not turn on
tv remote sensor
my tv flashes and nothing happens
Can't turn tv on (by 2 users)
posted by
helpme0806
on May 08, 2008
Report abuse
Red sensor light flashes when on button pressed but nothing happens. Remote doesn't work either.
Solve This!
I have the same problem.
X
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
OK
1 Other User Has The Same Problem
Comment by
melbar68
, posted on May 14, 2008
my tv will not turn on i plugged it to the the computer to charge it through the usb port and it turned then when we took it back to the room to turn on it would not turn on does it have to charge for certain amount of time
Suggest a new solution for this problem
Can you Help with these Flat Panel Televisions problems?
Olevia LT23HVX 23 in. LCD Television
VGA Resolution
ok so currently i have my monitor limping along with the...
Answer This...
Hello.
Could you upgrade the ATI Chip and if so what to?
Answer This...
No Macbook VGA connection (NO PC SIGNAL)
As the subject says, using the right adapter (mini DVI to...
Answer This...
Where is the service port?
I want to try to use the USB method but I cannot find the...
Answer This...
Your problem
Did you also replace the fuse? Thankx 4 the capacitor info
Answer This...
Let Our Experts
Solve
Your Problems
Ask!
Loading problems.
Bogda
Guru
Let FixYa Experts
Solve Your Problem
Ask!
Repair Service
Find Flat Panel TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
No
Yes
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
