Question about Oster 5965 Electric Kettle
I have noticed black water deposits at the bottom of the pot, and want to clean them out. What do I have to do? If I have to buy some tablets or other aid, what is it and where I can get it? Thanks.
  • Oster Master
  • 43,501 Answers
mix half white vinegar and water together...then pour this solution in just as you would if you were making coffe....minus the coffe grounds of course... then run it through a cycle and then run clear water through again... and you will be good to go...do this once a month or so to keep it working great...
heatman101
Posted on Aug 29, 2010
Cuisinart coffe maker does not allow water in
Common problem, it is hard water issue, these coffee makers do not handle even slightly hard water as deposits build up quickly blocking water flow to element. Try one of the many coffee pot cleaners, but if it is as bad as described, may not be enough to clean out coils.
CERACOAT-NANOTECH.com
Apr 21, 2015 | Cuisinart Coffee Makers & Espresso...
Steam holes on the plate are letting out limescale onto clothes, is there a way to clean out iron
Yes you fill the Iron with White Vinegar (the acidic Vinegar dissolves the lime deposits), and then flush with hot water, then clean the bottom with CLR (Calcium Lime and Rust remover) brand cleaner from any hardware store. This also is how deposits are cleaned out of a Coffee pot.
Jan 12, 2011 | Vacuums
The dishes look clean but there is residue left on cups and cereal bowls. I invariable need to rewash them manually. in addition there's a sandy or grainy deposit in the bottom right by the door which I...
You are using to much liquid soap or you need to buy some speed dry tablets for the drying cycle. Or put a water purifier on your main water line coming into your house. You may have what some people call hard water.
wvrain2006
Sep 29, 2010 | Maytag Dishwashers
How to clean the inside of tea pot (scale deposits)?
Vinegar is very good at removing scaly deposits. Heat white/clear vinegar just as you would normally heat the water for your tea. After heating the vinegar, pour out and rinse thoroughly with water. If there are still deposits after this first attempt, use vinegar once again. Once you are satisfied that all the deposits have been removed, heat water in the tea pot 2-3 times to remove any smell or taste from the vinegar (before using for tea).
Jul 07, 2010 | Breville "Ikon" Tea Kettle Electric Kettle
Self cleaning the quisinart coffee maker
I always use a mixture of 50:50 of cold water and white vinegar to help clean the internal parts of any minerals and scaling.
Unplug the coffee maker first, then add the water/vinegar mix to the reservoir.
Place a new, clean paper filter in the basket to help catch any deposits that will be dislodged and cleaned from the coffee maker.
As far as having the coffee pot dry, there is no need for that. I do tend to wait about 15 minutes to let the cleaning mixture disolve any deposits in the main water reservoir and then I turn on the coffee maker and let it process the water/vinegar solution through it.
Once it's done, turn off the coffee maker and discard the solution in the pot. And rinse out the coffee pot/carafe with clean, fresh cold water. Remove and throw away the used paper filter element andrinse out the basket with warm water and put it back on the unit.
Now fill the coffee pot/carafe with fresh, clean water and pour that into the coffee maker's water reservoir. Put in a new, clean, paper filter and turn the unit on and run a plain pot of water. This will help to clean out any remaining residue and clear the unit of the vinegar taste and odor.
Now you're all set to start making fresh tasting coffee again. I always recommend using filtered water for the best tasting coffee, as the taste is a direct result of brewing temperature, water purity, and the coffee you use.
Hope you find this Very Helpful and best regards!
Sep 22, 2009 | Cuisinart DCC-1200 Coffee Maker
Cuisinart DCC-1150 series coffee pot how to clean reservoir
Hello dhubert14,
This is a really common problem with the cuisinarts. I am most familiar with the DCC-1200, but you may be able to solve the problem. This an indication that something is plugged up. Open the top of the unit and in one of the corners you should find a filter stick or column that is removable. Pull it out and open it up to clean out the clogged up carbon filter in there. (You can later buy a new filter on Amazon.) Clean out the debris from the bottom of the cavity. Replace the stick into the cavity once cleaned. Now it's time to run through a solution of 2 parts water and 1 part vinegar. Do this once or twice with fresh solutions, then with a pot of fresh water. When the filter stick is plugged up the sensor says its time to clean it, but most people don't know about this fix. I hope this is really helpful to you, dhubert14. Positive feedback is appreciated. Good luck. NormanZ
Apr 01, 2009 | Cuisinart DCC-1200 Coffee Maker
How do I clean the Hot Water Dispenser?
I have zojirushi 4L (model: CD-LCC). I noticed that the bottom of the pot have some stain which are looked like "corrosion". What should I do? How to remove it? Please help.
Thank you
Nov 01, 2008 | Zojirushi 5L Water Dispensing Pot Cd LCC50...
Glasses always have sediment on them, not all dishes get cleaned
Remove the lower spray arm by rotating counter clockwise while lifting it up. It will come right out. Look at the bottom and you will see two holes (jets) that are plugged with food chunks, broken glass, etc... their job in life is to keep the fine filter clean. Also make sure your hot water is actually hot... like 130 degree hot. Then run 2 cups of Tang Orange drink through it on the Pots and Pans cycle, added heat on, to remove mineral deposits. (Tang is VERY high in citric acid and will clean it out safely)
Aug 02, 2008 | GE Profile PDW8400J Built-in Dishwasher
Coffee pot turns stops brewing in the middle of the cycle
Yup thats the Ticket - EASY FIX -
you have to clean the insides too people... lol.. The best way to do it is to buy citric acid crystals available from your local pharmacy. who knew huh? a couple of tablespoons in distilled water. Brew half the pot and let it sit for 30 min the brew the rest of the pot. Notice the color of your water after your done brewing. probably green from copper.. I could go into much more detail but thats the short answer... brew another pot or two of just plane ole water and bang your good go.. You should do this every month with any coffee pot for better tasting coffee..
Jan 20, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Bosch max wfl2000 washing machine
Just been through this with our Bosch Maxx, problem was the pump discharge pipe was blocked with soap deposits. I also removed the large black rubber pipe from the drum/pump and cleaned this out as well.
All working fine now.
SteveN
Sep 08, 2007 | Washing Machines
Oster 5965 Electric Kettle Logo
166 people viewed this question
Top Oster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Ben Eng
Level 1 Expert
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
