Question about Magic Chef Chest Freezer MCCF5WBX
How do i drain the freezer? - Magic Chef Chest Freezer MCCF5WBX
  • 28 Answers
Some freezers have a plastic drain plug on the side that can be removed, but most do not. I have found the easiest way is to **** up any water in the cavity with a shop vac or bath towels.
FYI: An authorized servicer is required to drain the refrigerant from the system and requires specialty tools.
Posted on Aug 29, 2010
It is leaking
The drain line located in the back of the freezer section has clogged. Some drain lines are located on the outside of unit. If drain line is outside of unit, disconnect line, use a shop vac and place it over the connector and suck out debris. Then blow out the drain line, then connect drain line. If drain line is not visible on the outside of unit and there is no visible drain inside of freezer,, remover all food from freezer, remove the back wall in freezer section. You should see a drain in the middle, back of the freezer, Use sop vac and remove debris. If you don't have a shop vac, you can use a long straw, wrap tape around end to make a tight fit and blow out the debris.
May 16, 2016 | Freezers
Model No.ERF415M 13CT. I have ice forming underneath the bottom freezer draw, when I open the door it melts and runs out as water under the appliance.
drain is plugged up were it is normally drain to defrost the freezer completely find a place to store food in freezer for a few ours leave door of freezer open pull out all shelfs and lay a few tools down at bottom of freezer were you seen the ice build up after you have done that pull ref away from wall take back of bottom look fro drain pan with a turkey baster send water thru back of freezer inside if water still flows back out into freezer drain tube is still clogged use warm water when doing this if you see drain pan full of water use a shop vac that can deal with water suck out water send water again water should go strait to drain pan if still flows out may have to remove drain tube
Aug 23, 2011 | Daewoo Freezers
No drain plug in freezer to drain water out when defrosting?
The drain hole is behind the back wall underneath the evaporator coil. Im guessing you have ice on the freezer floor. This is because the drain tubing from the freezer to the drain pan underneath is clogged. There will likely be ice that will need to be defrosted in the drain tubing in order to get to the clog. Once the ice is removed, I use compressed air when I perform this refrigerator repair service.
Sep 27, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Drain keeps freezing
The problem may be the freezer drain heater has failed, locate the drain inside of the freezer compartment and check to see if it is warm, if not you may need to replace the heater.
Jun 30, 2010 | Woods Upright Freezer MU07W
Amana Freezer DeepFreeze AFU2067BW 19.6 Cu. Ft. ice in bottom
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Feb 20, 2010 | Amana Freezer DeepFreeze AFU2067BW 19.6...
Kenmore upright freezer Model # C675-287140J Serial # 08462430AJ water is freezing in bottom tray and building up.
defrost drain may be plugged.shut freezer off,melt ice with blowdryer,and unplug drain.drain probably located behind inner back wall beneath coils.
Mar 08, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Water does not drain from the Freezer during the defrost cycle
hi thanks for the question the drain hose goes to the underneath by the compressor thaw out the freezer and clean the drain hose this will solve the problem thanks the appliance doc
Sep 12, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
FZA 81 FREEZER-blocked drain
take back panel off inside freezer and you will probably find drain blocked by ice. melt off with a hairdryer and follow up with hot water till it flows freely away. takes a bit of patience
Aug 31, 2008 | Hotpoint Freezers
Up right 14.7 cu GE freezer
HI to clean the drain tube. pull fridge away from the wall .find the drain tube, by the drain tray. push a small plastic hose, up the drain tray. blow in the hose, to clear the debris. thanks the appliance doc.
Jul 28, 2008 | GE 16.7 cu. ft. / 473 liter Upright...
Drain iced up in freezer
the draining pipe is block with something, you can melt the ice with a hear drier or hot water, then put a wire true the pipe and after that, test the pipe again.
Jun 02, 2008 | Maytag 15 cu. ft. / 425 liter Upright...
Magic Chef Chest Freezer MCCF5WBX Logo
79 people viewed this question
Top Magic Chef Freezers Experts
Dan Webster
Dan Webster
Offbelay
Level 1 Expert
AJMAL KHAN
Are you a Magic Chef Freezer Expert? Answer questions, earn points and help others
