Question about Panasonic Cameras
I* have a wonderful 300xdigital Panasonia camcorder, but no ac adapter to charger my battery. Its' about 8 yrs.old. I love it & my deceased husband bought it for me.They tell me that the cord is no longer made. the block is but no cord to power it with. Does something sound stange with that?If you could only find me one..#PVL780D battery itself#PV-BP18. Please help me find a adapter for this one, its special. I'm expecting my first Great Grand Child June 3.I need it soon....I have been looking everywhere. Please...Thank you. Syl;via Adams
Buy a new camcorder...
Posted on May 08, 2008
Lost my ac dc adapter need new one for rca small wonder camcorder
You can try www.ebay.com. I found the following AC adapter for the RCA Small Wonder camcorder:
http://cgi.ebay.com/RCA-EZ209HD-Small-Wonder-camera-CHARGER-AC-ADAPTER-/140516900106?pt=Batteries_Chargers&hash=item20b775bd0a#ht_1469wt_723
Mar 01, 2011 | Cameras
The new adapter is not compatible with the battery more info: laptop-batteries.com.au
you will need a genuine dell charger and look on your old one to see what pa it is if it says pa-12 then you need the same one again
Feb 22, 2011 | Dell Inspiron E1705 Notebook
I have a HP 6735s Laptop. I have been getting a few of the "Smart AC Power Output" messages, however yesterday after I turned my laptop off and then on again, the laptop wouldn't detect the AC...
bad battery,
you do know that the main batteries are "love to fail"
right,
just about all batteries do that in everything,
even the coin cell,inside can fail in 5years flat.
if power pack is 19vdc with volt meter, good !
the battery is next, yes it runs pc but can be bad.
a bad battery can still have power but overloads the charger chip
it really is an analog world. (reality)
if savvy , always keep a spare battery for moments like this.
Apr 07, 2017 | HP Compaq 6735s Notebook
Can a nx9110 charger /ac adapter work on an ibm thinkpad t30
Thefollowing three conditions should be met for you to use a charger safely. 1)Output Voltage is within +/- 5% of your old charger's output.
For example, ifyour old charger provides 19.5V, then you can use a charger that provides 20.5Vor 18.5V.
2) Output Current is the same or higher than that of your old charger.
For example, ifyour original adapter provides 3.42 Amps, then you can use a charger thatprovides 3.42 Amps, 3.9 Amps or higher.
3) Connector tip must fit securely into your laptop. Pleasecheck carefully before using nx9110 adapter on t30.
Dec 11, 2010 | IBM ThinkPad T30 2366 Notebook
No Power Using AC Power or Battery
I had this same camera. If you have a power fluctuation it can really damage the batteries. make sure it was not exposed to fluctuations
Jan 26, 2010 | Panasonic VDR-D100 DVD Camcorder
My hitachi camcorder says I need an AC adapter/charger
Hi Riannasmail,
You need a camcorder to charger DC cable,it looks like a battery with a trailing cable that has a DC plug on the end that plugs into the Hitachi battery charger.If you are in the USA you should be able to buy one for about $8 to $12,if you live in UK you will be ripped off at about £24.
I made my own adaptor and charger system for less than £20,If you need more info please contact me.
Oct 14, 2009 | Hitachi DZ-MV750MA DVD Camcorder
Will not rewind
Sony is pretty secretive about the :23 code. It can't be found anywhere. However, to service the C:31 code, Sony recommends you do the following:
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
  4. Turn on the camcorder.
  5. If the error message appears, service may be required.
If your camcorder still shows the same error code, then you'll have to send in your camcorder for service.
Sep 28, 2009 | Video Cameras
Power problem
Your battery is probabily uncharged or disconnected. Try taking the battery out and putting it back in. Then charge it (by plugging in the AC adapter) until the green activity light stops flashing. If this does not work, your battery is probabily dead. Did you short it out? Or perhaps it is old. Li-Ion batteries (the kind used in these machines) lose their ability to hold their charge in a few years - even if they're not in use! So, if your battery is 3 or more years old, try considering a new battery.
Jan 03, 2008 | JVC GZ-MG130U Camcorder
Damaged DVD-R Disc
Try to play it by connecting camcorder through the ac adapter/charger which will further connect the battery, so this means you do not have to put the battery in the camcorder rather get it through the ac adapter/charger and format if it asks to. I recovered 1 disc by doing so!
Dec 31, 2007 | Hitachi DZ-MV550E DVD Camcorder
Power Failure
Check the output from the AC Adapter first. If no good, battery not charging/dead so nothing works. If good, camera needs service - could be anything. There is probably at least one surface mount fuse.
Aug 20, 2006 | Canon ZR60 Mini DV Digital Camcorder
Cameras Logo
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
