I have a wireless router, my vista laptop is upstairs in my room, my wireless network connection is working. but the "local area connection" says that there is a network cable unplugged. but i have wireless. ?
  • 748 Answers
Well, the cable is indeed unplugged, because there is no cable - you are not using the wired network connection, called Local Area Connection. Therefore this is a perfectly normal status message of the wired (Ethernet) port.
If the wireless connection is working fine, then that's how it should look, nothing to worry about.
Posted on Aug 29, 2010
    Sergeant:
  • 223 Answers
"local area connection" is the wired connection, which in your case is "unplugged" If you go to control panel and look in connections, you will see that you are connected with the wireless, if you right click on the wireless there is a checkbox to display the status on your toolbar along side of the "Local Area Connection" Hope that clears it up a little
I can connect to xbox live wireless when in same room as router but go upstairs and can not connect..help please
Could be due to metal in the floor like insulation shielding the radio.
Would suggest using a power point switch if power points are on same power circuit
http://www.techbuy.com.au/searchcat/NETWORKING_ETHERNET_OVER_POWER.asp
and then either connect power point network switch to another wireless access point upstairs to cover upstairs area. All settings have to be the same as wi fi router down stairs. Same encryption password . Or you could just plug the Xbox into the power point ethernet network switch via ethernet blue cable.
Jan 27, 2015 | Video Game Consoles & Games
New hp envy 15 My hp envy 15 is less then 12 hrs old, i am having a problem with the wireless connection. When i use my laptop in my living room where the modem is the wireless network works totally fine...
You may need a repeater /extender to amplify signal.
There are many variables that may cause network to drop. You might want to test another laptop before making any purchases.
Good Luck.
Sep 21, 2012 | Computers & Internet
Upstairs computer no longer connected. Need to
What is the Operating system on the laptop ?
If it is XP then in the bottom right hand corner you will find Wireless network connection ( looks like 1 computer monitor). Use that icon to connect to the wireless network.
If it is windows Vista, then in the bottom right hand corner you will find 2 computer monitor icon. Use that icon to connect to the wireless network.
If it is Windows 98/ME/2000 then use the adapter utility to connect to the wireless network.
For MAC you will see the AIRPORT icon at the top.
Check the wireless settings of the router first . Make sure that you have all the wireless settings of the router. If you are not sure about the settings, then open the router set up and check the settings.
Click Here for step by step instructions on how to connect to the wireless network and troubleshooting steps
Dec 08, 2009 | Belkin (F5D7230-4) Router (587009)
Trying to connect a wired network wirelessly to a router
No. You'll need to run a "cross-over" Ethernet cable from one of the "LAN" ports on the "downstairs" router, connecting to the "WAN" port on another router that you will need to buy, and place "upstairs", and connect the 4 devices to the 4 "LAN" ports.
Or, run a long "straight-through" Ethernet cable from your DSL-modem (or cable-modem) that is "downstairs", and move your wireless router "upstairs", and connect the 4 devices to the router's "LAN" ports.
Your laptop "downstairs" should still be able to connect (wirelessly) to the wireless-router that is "upstairs".
Sep 16, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Home Network Problem with Netgear MR814 and Netgear FS105
Is your ReplayTV and Xbox configured to use DHCP? If not, you may need to configure static IP addresses for each of them.
Feb 17, 2009 | NetGear ProSafe FS105 5-Port Ethernet...
Signal Problems
try to bring another laptop to the location where you are having problem and see if the other laptop will have the same problem. if thats the case the problem is with the router. You can try upgrading the router's firmware or change the wireless channel
Apr 21, 2008 | NetGear WGR614 Wireless Router
Netgear dg834gt
I experienced a similar problem with a Vista laptop a few weeks ago. There were no apparent problems, so I uninstalled the wireless network adapter from the Windows "device manager" and then let it automatically reinstall the wireless adapter when it rebooted. The local wireless network appeared about 5 minutes after the reboot and has been working ever since. Hope this idea helps!
Jan 09, 2008 | NetGear DG834 Router
Laptop connection to Internet
In the simplest terms buy a longer ethernet cable or multiple ethernet cables and route them to several preferred areas.
However believing you probably would like to connect wirelessly
If your laptop has a built-in network card and originally came with Vista you may need to configure the network adapter and/or the router appropriately. There are often user guides for the both the adapter and router that will assist.
If your laptop has an built-in wireless adapter and you upgraded to Vista you should check the manufacturers website using support or drivers links to see if they have Vista software/drivers to support your built-in wireless adapter. IF not you may want to consider the purchase of a compatible add-on wireless adapter as noted below. And perform the appropriate configuration(s) as noted above.
Likewise if your laptop does not have a wireless adapter you may wish to consider purchasing an adapter. Care must be taken that the adapter is compatible with your computer, your operating system (Vista) and your wireless router (apparently WBR-1310).
Dec 06, 2007 | D-Link 802.11g Wireless Router WBR-1310...
Can see my network but wont connect
Yes you may trying chaing the channel to 11, because i have hear that chaning the channel will resolve this problem
Oct 23, 2007 | Belkin (F5D9230-4) Wireless Router...
Computers & Internet Logo
125 people viewed this question
David Payne
David Payne
