Question about Eureka Whirlwind 4388 Bagless Upright Cyclonic Vacuum
My eureka 5848 whirlwind lite suddenly turned off...what do I do? I don't have an owners manual...vacuum was given to me from my mom
  • 4,102 Answers
Hi this is a very common problem and its not easy to fix unless you know something about electrics, first of all have you checked and changed the fuse in the plug,
if you have then the problem is going to be at the vac end, you see where the wire goes into the vac well just inside their thats where you problem is you need to open the vac and get to the part that the mains lead is screwed into then you need to unscrew the connectors for the live and the earth wire you then need to cut the cable back about 6 inches and then you need to bare the wires back so you can refit them inside the vac you then need to refit them so their secure and put your vac back together and it should now be working.
this is not an easy job to do and its not for the faint hearted if you have never done anything like this before then dont bother as you could cause harm to yourself and others around you as their is a big risk of electric shock if you get it wrong.
now let me explain whats gone wrong, you know every time you use the vac you move it about and the wire is always moving now where the wire goes into the vac it starts to fray and then it splits and you lose connection then the vac starts playing up so this is why you cut 6 inches off the cable to get rid of the bad bit of cable.
if you are unsure what you are doing then the chances are you shouldnt be doing it, you are messing with something that could cause harm to you and others around you so you have been warned
plz rate this solution as i will not respond to any unrated posts, thanks
Posted on Aug 29, 2010
Owners manual
Here's a link to the owners manual for your Eureka 5843 Vacuum:
http://www.eureka.com/service/manuals/71496B.pdf
Please be sure to rate a thumbs up if this was helpful! Thank you.
Oct 08, 2011 | Eureka Whirlwind LiteSpeed 5843 Upright...
Need belt for Eureka vaccum The Boss model 5848 AV-2. Can you give me a belt number for what i nee. Thanks.
The belt part number for the Eureka 5848 AV-2 vacuum is 61120A.
Should you need part numbers for other pieces of the Eureka 5848 AV-2 vacuum, click on the following site, http://www.vacpartswarehouse.com/Eureka-5848-Lightspeed-Whirlwind-s/1959.htm
Mar 14, 2011 | Eureka 5849A Boss Bagless Upright Cyclonic...
How do I replace the belt on my mom's Eureka Whirlwind litespeed 12 amp 15" ?
take the cover off from the bottom there should be clips or screws on the bottom.and work the old belt off and new one on
Aug 12, 2010 | Eureka Whirlwind Litespeed 5740 Bagless...
How do the filters go back in my Eureka Whirlwind Lite 12 amp vaccum?
There are two filters for the this vacuum. The first goes behind the dump cup and there is a filter pack for that below.
Filter Value Pack. Eureka Part #60951A - Free Shipping
The second filter goes in the back of the machine the part you need is below:
Generic Eureka HEPA Filter Designed to Fit Style HF-5, Eureka Part # 61830 - Free Shipping
Apr 13, 2010 | Eureka Whirlwind 4388 Bagless Upright...
How do I change belt for Eureka Whirlwind Lite "Boss" model 450 A
Remove the 4 screws on the yellow top of the vacuum. The yellow plate will pop up exposing the belt and roller.
Jan 20, 2010 | Eureka Whirlwind Litespeed 5740 Bagless...
My Eureka Lite speed whirlwind has a bad odor when it runs.
It is either the filter or on the roller or belt.
  1. Eureka Parts Storewww.Eurekapartstore.com Unbeatable prices on Eureka Parts Largest site for Eureka parts.
  2. Eureka Partswww.ThinkVacuums.com/Eureka Eureka Central Vacuum Accessories Find Hoses, Tools, Nozzles & More! Google Checkout
  3. Eureka Part Storewww.vacuums24x7.com/Eureka-Parts Bags, Belts, Filters, Repair Parts. Complete Selection Eureka Parts.
Jul 06, 2009 | Eureka WhirlWind Litespeed 5844 Upright...
Need user/owners manual for Eureka Whirlwind Big Cup model 4686
hello chris. here is the link to use to get your downloadable manual
http://www.eureka.com/owners_guide.jsp
Jun 19, 2009 | Vacuums
The dirt cup clip broke and can't find the part!! Eureka whirlwind lite model#4388
I am assuming that you're looking for the handle at the front of the dirt cup... Part # 28131-288N, it has been replaced by part # 74985 Dirt cup grip assembly. If you call Eureka Customer Support at 1-800-282-2886 they will be able to find you a local dealer.
Apr 02, 2009 | Eureka Whirlwind 4388 Bagless Upright...
Belt location
If you torn the macine over, at the bottom of the sweeper you will see the belt on on side. You have to take the bottom part apart and remove the brushes to replace the belt. I hope this helps.
Jan 21, 2009 | Eureka Whirlwind 4388 Bagless Upright...
Need instructions to reassemble Eureka vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=12503&thid=680704
Posted by TamiLynn on Jun 18, 2008
I had to completely disassemble my Eureka Whirlwind Lite Model 410 bagless vacuum due to an excessive amount of debris that collected in an inconspicuous spot and now that I've reassembled it sounds like something from the motor is rubbing inside somewhere as if I put it together incorrectly. Do you have any schematics on what the insides should look like so I can put it together properly?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The best way to get the schematics is to contact the Eureka Factory @ the listing I will give you below. Sometimes the owners manual have the schematics in the owners manual but if not they might be down loaded from the factory website or to contact them by phone
And ask for cust serv or the serv tech support or parts for the schematics. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service 1-800-282-2886
Customer Service Dept
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 18, 2008 | Eureka WhirlWind 4381 Upright Vacuum
Eureka Whirlwind 4388 Bagless Upright Cyclonic Vacuum Logo
156 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
