Question about Microwave Ovens
The bottom element on my frigidaire CFEF372A is not heating up, and the outlet on the top of the oven also doesnt work, but everything else works. do i need a replacement element, or is it a fuse that needs replacing? if so, where do i find the fuses?
MicrowaveSvc
  • 9047 Answers
SOURCE: Where is the fuse?
It won't be the fuse. If the fuse were out, it would be completely dead.
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 28, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: MICROWAVE OVEN DOES NOT HEAT ALL OTHER FUNCTIONS WORK
Since the light comes on and the turntable rotates, I would suspect a bad magnetron, a loose connection at the magnetron, a failed high voltage transformer, or shorted high voltage rectifier diode.
If it's less than one year old, it should be fully covered under warranty.I'd suggest contacting the manufacturer to get it fixed free.
Ifit's within the magnetron portion of the warranty (usually 5-9 years)but out of the original full warranty (usually 1 year), then yourmanufacturer will cover the part cost, but not the cost to visit you orthe labor charge to do the work.
If you or a friend want to work on it, please see these links first:http://www.microwavedisplay.com/safety.txt& http://www.microwavedisplay.com/disassembly.txt
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it is NOT shorted, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
Thereshould also be a "mini-manual" hidden inside the unit behind thecontrol panel or hidden on the left side behind the grille, which isvery helpful when troubleshooting & testing.
For Frigidaire models, you can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Or you can find your nearest Frigidaire/Maytag-authorized servicer here.
You can visit Daewoo onlineor call them at 1-800-323-9668 or 1-800-553-4355 to find parts or findyour nearest authorized service center to have them do the work.
Posted on Oct 07, 2008
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Range RF315PXDW
It sounds like you are missing part of your input voltage.
I would take a voltage reading at the receptacle and confirm you are reading 220-240VAC. Some homes have the 220 service receptacles wired up with two 120 volt breakers to make up your 220 service. If your home is configured this way, you may have one of the breakers tripped. Or, the receptacle itself may be bad. If you confirm you have the correct voltage at the receptacle, your power cord may be bad.
The reason the clock and display will still appear to work is because the clock only uses 110-120VAC and is tapped off the source voltage. The surface burners and the oven heating elements, however, require the full 220 service.
If you are confused by this explanation, please post back and let me know. Hopefully, this is a problem that will not require any parts or a service call. If the power cord is bad, you can purchase a replacement at any hardware store. I hope this information is helpful.
Posted on Dec 19, 2009
Testimonial: "I will definitely check both the 120v wires in receptacle feeding power to the stove. The breaker in the house breaker box is a single 60amp breaker. "
  • 274 Answers
SOURCE: Our electric frigidaire oven doesnt heat up all
its time to replace the coil for the oven,get model number and serial# and fine parts dealer there easy to replace.
Posted on Jul 08, 2010
heatman101
  • 43501 Answers
SOURCE: Everything operates properly but oven
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Jul 06, 2011
Fuse location
Good Afternoon Friend, that's a great question!
Depending on the model of your Frigidaire microwave, the fuses are typically on located behind the control console, on the magnetron or on the oven capacity. However, if your microwave does not heat, you may possibly have a faulty control panel, magnetron, or experiencing an issue with the power supply. Please confirm that your microwave is plug into its own outlet and that you are not using a GFI outlet. Hope this helps! - Z
Sep 01, 2014 | Frigidaire FGMV174KF Microwave Ovens
Top stove micro wave-everything works but do not heat the food.
heatman101
Aug 09, 2011 | Frigidaire FMV156D Microwave Oven
Tappan Oven 316246653. Preheating the Oven does not work. Bottom Heating Coil (if thats what its called) is not working. The Broiler Coil at the Top does work. Is it the bottom coil that needs replaced...
Usually when the element fails to heat up, It means its usually broke, cracked, or where they plug in gets brittle and breaks. Your best bet is to replace the bottom element.
May 23, 2011 | Microwave Ovens
Our electric frigidaire oven doesnt heat up all the time the electric burners under the smooth top work fine PLES389ECG
Jun 16, 2010 | Microwave Ovens
Doesnt heat
heatman101
hfjjf
May 13, 2010 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
My delonghi 800w microwave oven works but does not heat up food
If your handy with getting the cover off and looking inside... check the obvious.
I suspect :
fuse
thermister
relay
If both microwave and Heating elements dont work, then I will assume the magnetron is ok, ans we are dealing with a high voltage issue... and you will need at best... a volt meter and or neon troublelight...
moust appliances have a simple schematic inside... I would start with the heating element first... trace wiring back to circuit board... usually one side of the heating element is connected to the white wire (neutral) and live (Hot) side is controlled thru the circuit board... so finding the neutral should be easy... then trace with neon light or voltmeter...
I know easy for me to say... but with everything else working... it doesnt seem to be the microprocessor that controlls the unit...
May 06, 2010 | DeLonghi MW 605 Convection/Microwave Oven
Have old tappan speedwave 1000. buttons work but when you press start nothing work except the countdown on display
Unplug the unit for 15 minutes...plug the unit in and try again. If that doesn't work - take the back cover off and look for any blown fuses...should be obvious.
Mike...
Nov 29, 2009 | Tappan Microwave Ovens
My frigidaire microwave oven will not heat
YOU NEED TO CHECK THAT THE TOP ELEMENT HAS NOT BLOWN .
Nov 04, 2009 | Frigidaire FMV145K Microwave Oven
Nothing works
Check the ceramic fuse it is easy to spot under the top of the machine cover
May 28, 2009 | Frigidaire PLMV169DC Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
