Question about JVC KWXC410
Wiring Hi, I'm replacing the original combo cd/cassete and radio of my 95 4Runner with a JVC KWXC410 which has it's own plug and it's different from the original. How to get to it?
    Brigadier General:
  • 6,966 Answers
The easiest would be to purchase a harness/connector specifically for a JVC to Toyota. You can try finding one here.
Alternately, you can hardwire or DIY splicing the wires/connectors following below wiring assignment.
You might find this document informative on radio installation in a Toyota 4Runner. Here is the installation manual of the JVC KWXC410. Should you need the owner's manual, it may be downloaded from here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 08, 2008
I replaced original cassette/radio in 2003 Ford Focus with a single CD/radio (1S4F-18C838-BA). When I turn on the headlights, the radio display light turns off. I noticed that the original connector has...
Instead of plugging the factory harness into the radio an adapter might be needed.
ref. link: http://www.carstereohelp.com
stereo-mci1pvvbw0dqilycvujzsuug-3-0.jpeg the above diagram is supposed to match your radio from the factory. The documentation with the new radio should provide the pins and plugs and what is on them. The correct plug or adapter should match up with the factory harness and work correctly.
Dec 21, 2017 | 2003 Ford Focus
Different or additional harness needed to install a Kenwood kdc 255u radio/cd player in a 2005 Scion XB?
YES.... to prevent cutting of any factory wiring (this use to be the old install method and requires much more time and expense) and potential electrical fires, you can now buy quite cheaply, what is called a Radio adapter harness.
As you wish to install a Kenwood radio to your Toyota Scion, simply buy an adapter loom which has a 2005 Toyota Plug on one end, with a Kenwood plug on the other (this essentially replaces the wiring loom that came with your Kenwood unit).
So, it's that easy .... Plug and Play.
And... if you sell your Toyota and wish to put your old Toyota radio back in, the original radio just plugs back in. PRESTO !
Hope this helps..
Cheers,
Scott
Jan 17, 2013 | Kenwood KDC 255U - radio / CD / MP3 player...
Probleme skoda fabia 1.4MPI anul 2000
Hello , Im having a skoda fabia 2000 1,4 i replace the original radio/cassete player with a regular cd one , but when i swap them above the cd player there is a little gap cos the radio/cassete player was a bit bigger then the normal cd player , so im looking for the plastic bit cos looks very ugly please any one who knows from where i can get it help ! L:)
Dec 26, 2012 | Cars & Trucks
Hi im putting in a JVC cd/radio in a 1997 ford escort TD,Ive removed factory fitted Ford radio cassette,leaving 5 wires connected to a yellow plug,I have 3 wires coming out of JVC marked yellow memory back...
hi...well i know this might not be of any help, but you can buy a connector that plugs straight into the ford plug, and then you plug the jvc plug/s into that, not cutting wires no messing up the original connector just incase you want to sell the car with original system in it... http://productfinder.autoleads.co.uk/productinfo.aspx?&m=FORD&f=ESCORT&id=463&pID=6889
thats the link for it...if you tell me what colours are on the ford plug i could tell you what goes where...thanks
Feb 04, 2011 | 1995 Ford Escort
JVC stereo not working properly - 2001 Sonata
generally wiring from the car is as follows...
red = ignition controlled live
yellow = permanent live
if you want stations saved and manual switch off of uni connect radio's yelow and red wires to the cars yellow.
if you want stations saved and radiounit switch off controlled by ignition (i.e only when car is running) then yellow to yellow and red to red. anything else will cause issues...
Feb 21, 2010 | JVC KD-R200 Car CD/ MP3 Player
Wiring difference
If your installing a stock radio/cd player from another Dodge the wiring plug is the same and will fit.If your installing a aftermarket radio/cd player(JVC,Pioneer,etc)you will need to buy a adapter plug that wires up to the radio and is a direct fit to your factory wire harness,so your not cutting your wires.When you buy the adapter plug it comes with a wire diagram of which wire is what.Your aftermarket radio should have a diagram also,either on it or in the manual.Hope this helps you.
Mar 04, 2009 | 2002 Dodge Caravan
Changing car radios
Hi I disconnected the battery and but that on charge i removed the radio and checked all the wireing and i think what i may have found when the guy who installed it in the first place, when he was putting the radio in place with the wiring the jack plug to the remote stalk control had come detached.
thank you
denis
Jan 26, 2009 | JVC KD-G430 CD Player
98 Deville casette/radio stereo won't play after swapping to CD/Casette/radio
Since the replacement is a different one from the one you are replacing, the car wiring harness is probably different from the one needed for the new radio. This is a really important difference if the new one is part of a Bose system and that is not the option installed in your car. The best way to check is for you to identify the option codes for each radio and go to alldatadiy.com and compare the wiring diagrams.
Apr 16, 2017 | 1998 Cadillac DeVille
JVC KWXC410 Logo
1,195 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
