Question about Husqvarna Chain Saw 20" Bar
HAVE TO TAKE THE BLADE OFF. took bolts off and that is all cant move th plate off.
  • 43,501 Answers
the plate can stick tightly sometimes...take the end of the bar and gentelt move to the side to pop the plate out and off...
heatman101
Posted on Aug 29, 2010
How to remove four blade base plate from masport 450 series
use hole where bolt for blade goes insert a large screwdriver or steel rod and get it to catch on the casting or at the grass throw end with base locked you can now undo lock nut. should be lefty loosy.
Feb 26, 2017 | Cars & Trucks
What is proper procedure for replacing all 3 pulley/ blade drive assemblies. Had trouble getting blade mount plate off of bottom off spindle shaft.
OK I HOPE THIS WORKS I HAVE A T-13560 GUESSING THEY'RE CLOSE, I HAD TO PULL OFF THE TOP COVERS SHAPED LIKE A "V" WITH ONE NUT HOLDING IT ON ,FIRST REMOVE THE CENTER BLADE BOLT UNDERNEATH ...THEN YOU'LL SEE THEIRS 4 1/4-20 HOLDING THE BLADE DRIVE ON BUT FOR ME I ACTUALLY TOOK THE FOUR BOLTS OUT HOLDING THE ENGINE MOUNT OUT IE. THE CENTER OF THE DECK TO EXPOSE THE TOP OF THE CENTER PULLEY (MY BAD ONE) AT WHICH POINT I COULD TAKE AN IMPACT WRENCH TO REMOVE THE PULLEY NUT ...THEN UNDERNEATH REMOVE THE BLADE MOUNT ....MY BOTTOM BEARING FELL APART SO I COULD PUT THE SHAFT IN A VISE , HEAT IT UP AND TURN IT COUNTER CLOCKWISE ...THEN REASSEMBLE GOOD LUCK
Jul 07, 2015 | Swisher T14560 T - 60" Trailmower with 14...
Remove base plate on a 375 sprint
do you mean the sump pan? if so just remove th engine from the machine remove the blade boss.undo all the sump bolts( think they are 3/8" ) and remove the sump pan,simples !!
Feb 25, 2015 | Garden
How do i remove the blade from a sr700 bLK N DEK MITER/CHOP SAW
Not sure how a Makita works, but on my DeWalt, a screw on a plate on the side of the guard is exposed when you rotate the guard all the way back. Remove that screw from the plate and the plate will allow the mechanism to lift up out of the way of the arbor screw.
Oct 17, 2014 | Saws
How to fit bosch PHO 15-82 planer base plate
my 15-82 has only one blade.There is a plate with three allen bolts to undo.Under that are two more allen key bolts to to undo.The blade moves although these two bolts are tight.The plane when looking at the drum has 6 inline holes.
Dec 17, 2012 | Bosch Tools & Hardware - Others
How do I change the blades on a vermeer 1600A chipper
Place the chute over the rotor. Remove all the clamp bolts for one blade. This will allow you to remove the old blade and clamp bar. Clean clamp bar and blade slot. Install new blade with clamp bar. You will need a knife gauge for this. Use the knife gauge at each end of the blade. Torque clamp bolts to 280 ft. lbs. After blades are installed it is necessary to adjust the bed knife by loosening the three bed knife bolts. Use the set screws to adjust the bed knife to 1/16 in. above the lower feed plate. Torque the bed knife bolts to 250 ft. lbs. Then use the other two bolts to adjust the lower feed plate to .013 to .016 between the bed knife and the rotor blades. Put the chute back into place and you are good to go.
Dec 08, 2011 | Garden
I cant undo the bolt that holds the blade plate on to remove it
What I do is align the wrench in a position that I can grab the blade with one hand and the wrench with the other and PULL the wrench toward you while pushing the blade away from you. The blade and the wrench should be only about 2 inches apart so you can put the most force on the nut. It may be possible to actually squeeze the wrench and blade together. Wear gloves.
Dec 01, 2010 | Briggs & Stratton Garden
My 2012NB has served me well for about 10 years, but lately lumber does not feed through smoothly and the result is a "ribbed cut" - there are gouges running across the board at about 2 inch intervals. My...
I just read the owners manual online at Makitausa.com and I don't see the reference to the feed rollers and pressure.. I would look at the condition of the planer blades to ensure they are sharp and not pitted. Then I would look at the feed rollers for being out of round. Let me know, it has been a couple years since I worked on one of them.
Jun 30, 2010 | Makita 2012NB Electric Planers
How can I change the circular saw in my Back & Decker Circular Saw, model: P3703 (1100 watts)
Unplug it and loosen the bolt in the middle of the blade. It's a standard thread, so turn it lefty-loosey. But you need to hold the blade from turning. That's easy by putting a screwdriver in front of a blade tooth, under the sole plate. Let the sole plate prevent the screwdriver from rising up with the blade as you turn the bolt. If your current blade has small teeth (like a plywood blade) then you can raise the sole plate as for a maximum depth of cut, then push the saw against the front edge of a workbench (or block of wood somehow held still) as if you were going to cut it. Before you remove the bolt, take note of the exact orientation of the washer (or washers)so you can replace them the same way.
Jun 18, 2010 | Black & Decker Saws
I have a 10"DELTA Miter Saw and need to change blade. Please describe how to remove and replace blade. Thanks
Without a model number I cant look for this saw, but if it is like the other mitre saws that I work on, the lower guard should have a bolt holding it in place, loosen the bolt so you can move the guard and the blade bolt is usually LH thread, on the backside of the gearcase by the blade there should be a spindle lock, rotate blade until it locks and then remove bolt. If your saw is different please give me the model number and I will pull up a schematic and look at it.
Jan 16, 2009 | Saws
Husqvarna Chain Saw 20" Bar Logo
24 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
