Question about Kenmore Washing Machines
Washer fill with water, lid closes but no sound-like it wants to start... no spin, no rinse... also looks like where lid closes no connection
  • Kenmore Master
  • 43,501 Answers
You may be right.. the lid switches often break...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Aug 29, 2010
Fills with water, skips wash and rinse cycle, starts spin cycle and sprays water out of the top
I would look at lid switch on this model and plunger to lid .Under lid is spray flume that can be damaged by large loads ,check that close. put it in wash full and drop lid hard it may come on.
Nov 19, 2013 | Maytag Dependable Care LAT9206
Washer 110.92573110 works fine until it should rinse. It just stops and does nothing. It won't pump out the water. The schematic is unreadable. Do you have an electronic copy of the service documents...
check the lid switch,open and close the lid just a little and listen for a clicking sound,every time the lid closes and opens the switch should click,also you can set the timer to spin,open the lid and stick a screw driver into the hole where the strike on the lid would go into,that's the lid switch,if it starts to drain and spin then you'll know the switch is bad,the lid coulld be bad and not do anything and that's why you have to listen for the clicking sound,if it does click and the lid switch is good another thing it could be is that no cold water is entering the washer,when in rinse all that fills into the washer is cold water no matter what setting the water is on,this is to keep the clothes from wrinkling but it sounds like the lid switch
Apr 22, 2011 | Kenmore Washing Machines
Only the rinse and spin cyl wont work on my whirlpool
first check the lid switch,open and close down the lid and listen for a clicking sound,if you don't hear it clicking you have a bad lid switchtry opening the lid with it on spin and stick a screw driver or anything that will fit in the hole where the lid closes down into the hole where the lid switch is,if it runs then you know the lid switch is bad.also on washers,in the rinse cycle only cold water is used in the final rinse,no cold water the washer won't fill and run,the valve will just hum.let me know how you make out,you could also have a bad timer.if you need more help send the model number
Dec 05, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
My Maytag top load, looks like PAV2300 but not sure, will not rinse. The water drizzles a bit during the cycle and I hear the timer but the machine does not rinse. I cannot force it into rinse. I have to...
Hi and welcome to FixYa. I am Kelly
There is a water level pressure switch inside the top panel that has 3 wires on it and a vacuum line. That pressure switch controls the water inlet valve functions via the timer.
If by chance the pressure sensing line is getting hydraulically locked with water due to some form of obstruction it can cause the symptom you describe.
This pressure switch also controls the start of the spin once the water level has dropped (prevents the wash tub from being a water brake and damaging the motor clutch)
If the water level pressure switch is working normally then the only thing left is the timer.
You can do your own testing of the water level presure switch with an external vacuum hose (3 feet in length) connected in place of the machine hose. (DO NOT drop the machine hose when you disconnect it!)
1. place timer on wash and start filling. LID CLOSED
a. Force air orally into the external line
1) Result fill stops agitation begins
2. place timer in spin LID CLOSED and force air into external line until the pressure switch clicks.
a. START SPIN CYCLE NOW and listen for water pump out
b. release pressure on external air line
1) result tub starts spinning
If it passes the above tests your looking at a timer problem causing your no rinse situation.
Thanks for using FixYa!
Kelly
Feb 18, 2010 | Maytag PAV2300 Top Load Washer
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
Water is now filling, washing going round in drum but not rinsing or spinning.
Spinning and Rinsing require a safety switch to be enabled by the closing of the washers lid.
Check around your lid and washer lid opening to find the mechanism that is used to activate the safety switch mounted just under the lid opening inside your machine. Sometimes it is a plastic plunger(protrusion) on the lid that mates with and opening(hole) in the machine around the lid opening to cause this switch to close. Other times it is on the hinge side of the
lid and the protrusion is formed right into the metal of the lid itself to push a plunger on the hinge side to close this safety switch.
Most spinning problems on machines are cause by this lid safety switch. Washing machines cannot spin if the lid is not closed and this safety switch is not working to switch power to the spinning motor.
Aug 30, 2009 | Ariston Technologies AW125NA 13 lbs. Load...
Washer is filled with water,,it wont drain,,nor
Sounds like a bad lid switch. When you close the top lid, there is a safety switch that closes, it is actuated by a pin attached to the lid, there will be a small hole located on top of the machine, somewhere on the perimter of the top of the tub. Could also be a bad timer.
Jun 25, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore stackable mod number 417.94802301
check your lid switch. if your lid swith is bad, it will fill and agitate, but will not pump or spin. therefore it will not go into rinse cycle without being able to pump out water. some lid swithes control the agitation also (usually frigidaire and older maytags), but i doubt yours does. you can check the lid switch for continuity while opening and closing the lid with a meter
Apr 30, 2009 | Kenmore 98702 Stacked Washer/Dryer
70 series Kenmore washer
POWERUP, YOUR WASHER COULD BE THE LID SWITCH OR THE COLD WATER VALVE. AT THE END OF THE WASH CYCLE, THE MOTOR WILL SPIN OUT THE WATER, BUT ONLY IF THE LID SWITCH IS ACTUATED. IF THE SWITCH IS BAD, IT WILL NOT SPIN OUT THE WATER AND THE TIMER WILL NOT ADVANCE FROM THAT POINT.
IF THE WASHER SPINS, THE NEXT STEP IS TO FILL WITH WATER FOR THE RINSE CYCLE. MOST WASHERS USE COLD WATER FOR RINSES. IF THE COLD WATER VALVE IS RESTRICTED OR FAULTY, THE WASHER WON'T FILL. IF THE WASHER WON'T FILL, THE WATER LEVEL SWITCH WON'T ACTIVATE AND THE TIMER WON'T ADVANCE TO THE NEXT STEP.
Mar 31, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
12 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
