Question about D-Link DIR-600 Router
Hello! NEED HELP OPEN PORT 3784. I have troubles portforwarding. I have entered everything at the Portforwarding site but it doesnt want to open the port. Im really stuck. Have tried to disable the firewall (didnt work). Would love some info how to fix it. Is there any other settings that needs to be changed ? Here is some info: General Info Router: D-link DIR-600 Modem: Motorola SB5101E OS: Windows Xp OS Firewall: Enable Subnet Mask: 255.255.255.0 Gateway: 192.168.0.1 DNS : 148.160.16.66 Router Port Forwarding Rules: Name : Ventrilo IP Adress : 192.168.0.100 Public port : 3784~3784 Private port: 3784~3784 Trafic type: any Thanks
crapiemael
  • 241 Answers
SOURCE: After replacing Cable Modem, D-Link DI-524 Wireless will not work
Did you call Comcast and give them the new MAC address of the Motorola SB5101 SURFboard cable modem? I'm surpised it works at all without doing this first. This is the hardware address of your modem so the world can see you, no one in the world has the same MAC address, they are all different. It's on a sticker on the modem.
Posted on May 28, 2009
nitro329
  • 5 Answers
SOURCE: I need to open a port to use utorrent
To open a port, you first need to know what port you need to open. Once you know this you need to access you router properties. Open your browser and go to http://192.168.1.1/ (BE VERY CAREFUL WHEN GOING THERE! You can brick your router!). when it asks for username and password, type it in if you know it, if not check your manuel or http://www.routerpasswords.com/ to find the default login. Once your in there, find something that mentions about ports, for instance, I have a Lynksys router and my port forwarding is under Applications and Gaming>Port Range Forward. When you find the correct page, type in the port number, save it, and there you go! If it mentions about TCP/UDP open one at a time, test it, then close the unused one to prevent a hacker highway into your computer and/or network. To test if your port is open without waiting forever for your torrent or utorrent to say that its still closed, use this free lightweight port checker that I use. http://portforward.com/help/portcheck.htm
Hope this helps,
Dan
Posted on Jun 17, 2009
admin734
  • 268 Answers
SOURCE: i have a ps3 and when i try and connect it, It
To make things easy, you can set your Playstation 3 to obtain all the network information automaticlly. All you would need to provide is the SSID (Name) of your wireless network and the encryption password (if you have one enabled).
On Your PS3:
"Goto settings
Goto network settings
Goto network connection, select enable
Goto Internet connection settings just below internet connection-
Push yes when it says you may be disconnected
Select wired or wireless
For wireless use scan or enter manually
Follow on screen instructions.
Once that is set up return to main menu and go to network near the right
Then once in the internet browser press triangle and goto file and enter the internet address you would like visit. "
Source: Link
Posted on Oct 20, 2009
SOURCE: my windows 7 pc wont port forward through my dlink
Normally the Router does the Port forwarding as below, try this, Prepare the Router
as this stage differs from one router to another. We will give you a general idea and you should refer to the manual of your router for confirmation.
  • Go to the administration interface of the router by typing its IP address in the web browser (for example 192.168.1.1)
  • Enter Login and Password
  • In the page that comes up, search for Port Forwarding.
  • Then add following data:
    • Name: Give it a unique name like Remote Desktop
    • External Port: 3389 or whatever
    • Internal Port: 3389 or whatever
    • Destination IP address/server: Enter the IP address of the computer as defined in step 1 (e.g. 192.168.1.99)
    If necessary punch through the firewall too, on those same ports.
Posted on Jan 28, 2010
  • 10406 Answers
SOURCE: D link router connection Hi I have recently bought
Everything looks normal:
Description . . . . . . . . . . . : Atheros AR5007EG Wireless Network Adapter
Physical Address. . . . . . . . . : 00-1D-D9-44-F8-15
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::1c05:824a:4808:dd81%14(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.102(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 21 February 2011 13:48:48
At the command-line prompt, try: ping www.ucla.edu
If it responds, then you *DO* have a good Internet connection.
Posted on Feb 21, 2011
I have a new router and need help to portforward it
  • Notes about this router in this article's example
    • Name: Netgear RangeMax N150 Wireless Router
    • Model: WNR1000v3
    • Default IP: 192.168.1.1
    • Default Username: admin
    • Default Password: password
    • Firmware: 1.0.2.26_51.0.59NA
Step 1:
  • Open a web browser and proceed to the default IP of
    • http://192.168.1.1/
  • Login with the User Name of admin
  • Login with the Password of password
  • Click Ok
200px-portfwd-netgear-01.pngStep 2:
  • Click Port Forwarding/Port Triggering
  • Select Port Forwarding
200px-portfwd-netgear-02.pngStep 3:
  • From the drop-down list, select HTTP
200px-portfwd-netgear-03.pngStep 4:
  • After selecting HTTP
  • Enter the IP Address of the device
  • Click Add
  • Done
Mar 15, 2012 | NetGear N150 / RANGEMAX 150 Router
Im trying to open the ports "3784, and 6100" for Ventrilo and i can not get them to work.
you will need to setup your computer for a static ip address.
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 12.0px Tahoma} p.p2 {margin: 0.0px 0.0px 0.0px 0.0px; font: 12.0px Tahoma; min-height: 14.0px} span.s1 {color: #05aef0} span.s2 {font: 12.0px 'Lucida Grande'}
Click the Security link near the top of the page.
Click the Applications & Gaming link near the top of the page.
You should now see a new menu. In this new menu, click Port Range Forward.
Enter the name of the program into the Application box. It doesn't really matter what you put into this box, but something that will remind you why these ports are being forwarded would be a good idea.
If you are forwarding a single port, enter that port number into the Start and the End boxes. If you are forwarding a range of ports, enter the lowest number of that range into the Start box. Then enter the highest number of that range into the Endbox.
Use the Protocol drop down box to select the protocol type of the ports you are forwarding.
Enter the ip address to forward these ports to into the IP Address box. If you are forwarding ports so you can run a program on your computer, you should enter your computer's ip address into that box.
Put a checkmark in the Enable checkbox.
When you're finished, click Save Settings near the bottom of the screen to save your changes.
And that's it! You're done!
http://portforward.com/english/routers/port_forwarding/Linksys/WRT54G/
Mar 20, 2011 | Linksys WRT120N Router
Open port for emule
Hello
The web site mentioned below helps to configure the port for emule
http://portforward.com/cportsnotes/emule/eMule.htm
Hope it helps, if so do rate the solution
Good Luck
Dec 27, 2010 | D-Link DIR-685 Wireless-N 300 MBps Router...
Cant access lorex DVR from the internet
u need a public ip with an open port, and portforward the port with the ip of ur dvr
Mar 15, 2009 | Home Security
How do I open port 30000 in a DIR-625 router?
Hello marquitos4,
Go to http://portforward.com/english/routers/port_forwarding/Dlink/DIR-625/DIR-625index.htm
and you will find all the info you need regarding port forwarding through your D-Link router.
The page is specific to the DIR-625 but just about any make/model is supported at http://portforward.com/
Enjoy,
FixThemAll......
Dec 15, 2008 | D-Link DIR-625 (790069292637) Wireless...
Port forwading
this site may be of some assistance
Jun 19, 2008 | Computers & Internet
World of Warcraft
Sounds like you need to do some port forwarding.
World of Warcraft communicates on port 3724 with the TCP protocol. The patching process requires port 3724, 6112, and 6881-6999. Once again to download the patches for World of Warcraft you should forward the following ports.
3724 TCP6112 TCP6881-6999 TCP
If you can not forward ranges of ports and are only planning on having one computer playing WoW, just forward ports 3724 TCP and 6112 TCP. The 6881-6999 port range is mainly used where multiple computers on a network may be trying to play WoW at the same time.
Ventrilo: From their web site: Click on the "Port number" input box and enter the servers port number. The program will automatically display the default port number of 3784 but you can change this to what ever the server needs it to be.
So forward 3784 or the port number you chose.
http://portforward.com/english/routers/port_forwarding/Motorola/SBG900/SBG900index.htm for a walk through on how to do the forwarding.
Hope that helps!
Jun 02, 2008 | Arris SURFboard SBG900 (49402201900) Modem
Nat
try portforward.com if that doesnt wark try www.techieguides .com
Feb 07, 2008 | NetGear WGR614 Wireless Router
My RCA router needs to be port fowarded
Go to this page: http://www.portforward.com/routers.htm Find your router on this list and it will give you a detailed description on how to port forward.
Aug 23, 2007 | RCA Thomson Digital Cable Modem (DCM305R)
D-Link DIR-600 Router Logo
139 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
