Question about Vacuums
The salt is not being used. the softener comes on and makes noises as usuall. it appears to be working, but i believe the water in the house is not being conditioned (stains on dishes in the dishwasher)
  • 43,501 Answers
Water softners often do that and there are many reasons why they may not work...
It would take many pages for me to describe all that could go wrong...
Call someone who is familiar with those to troubleshoot it for you...
heatman101
Posted on Aug 29, 2010
Why is the head not getting steam and its making a knocking noise it didnt come with instructions
The knocking noise is actually the water boiling to produce steam.
No different from a pot boiling on the stove. The only difference being the noise is dampened in open environment in the pot, while in the vacuum its a small closed environment with plastic which enhances the noise. There also could some hard water debris within the vacuum chamber which pounces around during the boiling process, such as the same when a water heater becomes old and hasn't been drained. Hard water causes calcium deposits which in turn causes knocking noises in a water heater.
May 10, 2014 | Vacuums
No steam or water even coming out, its just quiet except brushes moving
David, the brushes on the motor may be burned out and the conduction process has been compromised. In short the motor is bound up and won't turn. This can happen if surface debris collect on parts of the motor. Do not turn it on for long and let the unit get warm as it will eventually break down permanently.
If you need a manual, go the company web site and seek that from customer services.
Mar 10, 2014 | Bissell 46B4 Stick Steam Cleaner
My vax vacuum has started making a high-pitched whining/whisting noise
Ususally this is caused by a forein object has gotten hung in the suction impeller attached to the motor. the noise flucuates due to the housing flexes with the movement of the handle and rod. the housings are usually made of plastic and something very small can easily get stuck in it and stay for a very long time. The vacuum needs disassembled and the forien object removed from the fan housing...
Hope this helps
Sincerely
Roger
Feb 07, 2012 | Vacuums
Forgot what kind of water to use - distilled or other wise can not find manual, can I get one - Model GS7RW Thanks, Susan
hi.
i am assuming it is the GS7RW garment steamer and not actually a vacuum cleaner.
any electrical item with a heating element should be used with distilled or de-ionised water.
if you live in a "hard water" area where the water contains dissolved calcuim salts, these will cause scaling and furring up of the heater element. easiest way to tell is to look inside your kettle. if there are white deposits on the base or heating element, your steamer will get the same deposits and work less effectively.
another option is to use the scented ironing waters available from many supermarkets for use in steam irons. these will not harm your steamer, and will also make your clothes smell nice as they come in a range of scents.
this link does have some instructions that may help.
http://www.conair.com/instruction_booklets/06PC2349%20gs7rw%20IB.pdf
Jun 14, 2011 | Vacuums
New Rainbow purchased 3 weeks ago. Went to a friends home which purchased one also and her's is very quite. Mine on Low setting to use as air clearner you can hear it in the next two rooms. Her's you had...
Your new rainbow is still under warranty I believe so explain it to the company and ask for another. I too had a rainbow however I am like your friend in which mine worked very well. The noise is coming from the motor housing or the motor itself. Good Luck
Jan 06, 2011 | Rainbow Vacuums
My scooba 5810 won't run
Fill the dirty water tank with hot water and giving the tank a good shake then pour the water out. Continue to do this until the water coming out of the dirty side of the tank is clean.
Jan 18, 2009 | iRobot 5800 Scooba Vacuum
Kirby Sentria
sounds like the motor burned up. not sure if travel adapters will handle a large load like a motor, around 8 or amps. power needs in US are 110 volts ac, 60 hertz.
I believe UK is 220 volts and 50 hertz.
usually when a vac is brought to europe you must change motor.
Jun 13, 2008 | Kirby Vacuums
Vacuums Logo
23 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
