Question about HP Photosmart C7280 Printer
Dear Sir or Ms., Was given a HP Photosmart C7280 All-in-One Printer, Fax, Copier and Scanner. Would appreciate it if you would send me a book then I would be able to use it other than print. If you charge me tell me how much it would cost o.k.? Thank you in advance. Pat Smartz 1305 Fox Avenue ****** Falls, Pa. 15010
  • 748 Answers
The documentation and manuals are on the CD delivered with the printer, for on-screen viewing.
There is no paper manual available.
Posted on Aug 29, 2010
I have a hp photosmart c7280 all-in-one printer fax copier scanner when some one sends me a fax it wont go through when i access the tool section on the printer and try to run a test page is says fax...
chances are your phone line is not a dedicated outgoing data transmission line : result of the phone companies keeping tabs on their property and its usage. if you are using a regular phone line, you have to call for the phone co. to add the data transmit feature.
Jan 19, 2012 | HP Photosmart C7280 Laser Printer
I keep getting "image on fax send report is set to
Hi!!
Press the Setup button on the front panel of your All in One
Go to Print report
Check for Fax report it may be off turn it On
Apr 16, 2011 | HP Photosmart C7280 Printer
My C7200 Photosmart Printer/fax says " Origininsl Jam" .
If you are using DSL I suggest you to use filter. that will resolve your issue
Aug 19, 2009 | HP Photosmart C7280 Printer
Scanner failure-Hp c7280
make sure to go to hp.com and install all the correct drivers for that system
Jul 21, 2009 | HP Photosmart C7280 Printer
Where do i register my copy, printer, scanner, & fax
ritadraudt, You can register your HP products by visiting the following link:
http://register.hp.com/
Jul 07, 2009 | HP Photosmart C7280 Laser Printer
The photosmart c7280 printer will not receive or send fax. what am i doing wrong?
Check the phone line with a regular phone plugged into the wall socket.
Jun 19, 2009 | HP Photosmart C7280 Printer
Hp4300 series disc won't work with my new hp window vista computer my printer is a 4315v
Please perform the steps given below and check if yuo are able to fax
1. Open a MS Word Document.
2. Click File -> Send to -> Recipient using a fax modem.
3. Follow the instructions given in the fax wizard. Ensure that you select the HP all-in-one as the fax program.
Now check whether you are able to send the fax.
OR
Try setting up the Fax once again
=== Fax Setup wizard ===
- Double-click on the HP Solution Center to open it.
- Go to Settings --> Fax Settings & Setup --> Fax Setup Wizard.
Complete the fax setup wizard and then, try to fax
Vishwanath V U
May 19, 2009 | HP Officejet 4315v All-In-One InkJet...
I cannot scan onto my HP c7280, but I can print to it. It connects via cat5 to switch. I cannot 'locate' the scanner.
check for the scanner drivers in the control panel,if they are there...if not you will have to reinstall the scanner drivers on your computer.use the s/w cd that came with the printer and install it all over again..then try scanning from the windows photo gallery or the MS paint and word.These do not use the twain drivers ,they use the windows scanner drivers....see if it works
Mar 12, 2009 | HP Photosmart C7280 Laser Printer
Set UP of HP Photosmart C7280 All-in-One Fax Printer Scanner Copi
The cd that came with the printer did you install it?
Usually when it shows 1 through 5 it means that you need to complete 5 steps for that to work.
Dec 24, 2008 | HP Office Equipment & Supplies
HP Photosmart C7280 Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
