Question about Kwikset 4 Lido Lh Passage Levers Satin Chrome 200ll 26d
I have a Schlage F51 lever door lock. The latch is stuck and even after removing all hardware, I can't get the latch out of the door. Is there a way to reset the latch so I can open the door and remove it? Thanks, Mike
  • Anonymous Mar 17, 2014
    show sequence for re-installing after removing to
    refinish door
    Problem Solver:
  • 5 Answers
When you say "removing all hardware" do you mean,All hardware such as hinge pins and or hinges to get the door off?
Posted on Oct 15, 2010
I cannot open my outside door. It's a Schlage lock and with both doorknobs off the lock will not allow me to turn the square piece when all locks are off
Your door likely got slammed and the dead latch function of that latch is really tight. Can you wiggle the door at all? If not...put the lock back on so you have something to turn on and push the door as if you were closing is (use your shoulder or a buddy if you have to) and give the lock a twist while applying this force to free up the latch. This is not uncommon when a lock is set to function properly with the dead latch NOT going into the hole of the latch plate but is forced there by a gust of wind slamming the door! Let us know if it helps you.
Jan 04, 2017 | Schlage Locks & Locksmithing
Exterior door stuck closed manually retract ****** remove knobs KWIKSET
You will probably need to replace the latch assembly. There is a small rivet that holds part of the latch together, and it also acts as a pivot point for a small piece that retracts the latch. If it gets bent, the latch won't retract fully, but you might be able to push it back and get the door open.
May 24, 2014 | Kwikset 740ll 3 Smt Lido Keyed Entry Lever...
Our schlage lock with thumbturn on inside and keyed on outside. When unlock inside, knob turns freely as if it is really unlocked but if I close door, I get locked out. Please help
Be sure the outside knob is unlocked before closing the door.
Schlage locks do not lock the inside knob or lever. After releasing the turn button, also turn the inside lever or knob, then check the outside knob.
What model of lock is this?
Apr 09, 2014 | Locks & Locksmithing
Schlage entry latch
Make sure latch isn't biding and going all The way into the latch plate if the latch is up it won't lock ! Make sure it locks while the door is open !
Dec 21, 2013 | Schlage Antique Brass Georgian Entry Latch
Schlage BE365 - How do I remove the key? It will lock/unlock door but cannot be removed from lock.
Recommend resetting the lock back to factory settings and try reprogramming. Also if you don't hold the latch while turning the key to lock/unlock the door it may not be recognizing the keys inserted and this will keep the key in place. Try that before resetting to factory just make sure you hold latch and turn key until it wont turn anymore.
Dec 01, 2013 | Schlage Camelot Deadbolt Keypad, Satin...
Passanger side door locking problem. when I insert the Key, it can turn forward to lock the door, but can not turn backward to unlock the door. And I tried the second key, does not work either.
Really sounds like one of 2 possible problems.
First, perhaps the door latch itself is broken, and that is unlikely, except that I am unfamiliar with that particular latch on that particular car.
Second, it sounds like, if you were to take the door panel off, you would find the latch is locked because one of the locking levers is holding the door latch locked.
There or 2 or 3 lever like things that affect the latch.
There is a lever from the outside door lock that goes to the door latch.
There is a lever from the inside locking handle that goes to the door latch, and yet may be one more.
If any of these are "stuck" or broken, they will "hold" the door latch in the locked position.
Be blessed.
Feb 07, 2013 | 1998 Nissan Altima
I need something to help me put the insides back together.
If it a Schlage door knob. We have installation guides on our website at http://www.factorylocks.com. Here is a link to knob installation. Schlage F Series Installation Instructions for Knobs and Lever
I hope this helps. Leslie, factorylocks.com
Jan 27, 2013 | Ace Hardware Ace Ball Knob Entry Lock in...
Double cylinder deadbolt, bolt stuck in jam
You will have to remove cylinders from both sides of door, then stick a phillips screwdriver thru the bolt and push the screwdriver toward the hinge edge of the door.Might take a bit of pressure, depending on how hard its wedged into the jam, and you might break the bolt, but thats about the only way to get it out.try to determine why it got stuck before installing new one.
Oct 22, 2012 | Schlage Deadbolt. Double Cylinder Deadbolt...
I don't know the model number of the lock. It was installed in 1993.The latch broke. I got a new latch but cannot get it to work. Either it won't go or the handle slips. It does not have a key....
Start on this web page to identify your lock:
http://consumer.schlage.com/Products/Pages/category-landing.aspx?category=Electronic+Security
Then go to this page for links to the proper instruction and programming manuals and videos for your lock:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
If you're still having a problem or need parts, here is the contact information for Schlage Customer Service:
Schlage Lock Company
Customer Service Department
2119 E Kansas City Rd
Olathe, KS 66061
United States Customer Support
Warranty & Technical Information: 1.888.805.9837
http://consumer.schlage.com/Service-Support/Pages/ContactUs.aspx
Hope this helps!
Jun 01, 2011 | Schlage FE575-CAM-ACC FE575CAM505ACC...
Schlage deadbolt will not unlock even with the use of a key?
it sounds as though the linkage that pulls the deadbolt back has disengaged... if you undo the screws from the inside of the door and remove the manual knob there will be 2 more screws holding the key lock to the door. A thin flat bar is attached to the key lock that goes through the deadbolt and into the manual knob. This bar turns with the key, sliding the bolt on its track to lock and unlock the door. Once the lock is apart check the key in the lock to see if the bar turns when the key does. then see if there is anything that may be obstructing the deadbolt from sliding. The locks are pretty indestructible so if there is a problem it may have been from the install... perhaps the door is to wide for the lock to engage properly and the lock worked loose in the 6 months that it worked.
Jun 21, 2010 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
Kwikset 4  Lido Lh Passage Levers Satin Chrome 200ll 26d Logo
414 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
Steve Masymas
Level 1 Expert
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
