Question about The Times Case Corporation Tractors International Harvestor
Case 7130 Tractor Running perfect suddenly shuts off. When tring to restart notice slow engine turning and a slight metalic sound and engine sound as if no compression or something.
    Problem Solver:
  • 15 Answers
Check the solnoid at the injection pump. When it goes bad it will shut the fuel off when it gets hot. Sometimes you can take them apart and clean them to get you by but you will have to replace it soon.
Posted on Sep 10, 2010
What is causing a loud ticking sound instead of a normal boat engine sound when accelerating in my boat?
One of the spark leads has come off or has chafed against something wearing away the insulation, thus the ticking sound, spark going elsewhere instead of the spark plug. Make sure the plug leads are secure and in good condition, make sure no water has entered the engine cyl head area
Aug 13, 2015 | Cars & Trucks
My Toshiba c-55 wont turn on the white button light flashes 4 or 5 times and then stops but it never turns on.
I heard of many power issues with these models. Mostly concearning the battery, it sounds like this may well be the case from the 'light flashing' issue.
The other problem involving slow start up/ being laggy could be down to the machine running hot and Windows is using passive cooling in the power options, or a failing hard drive can also cause software problems.
Dec 25, 2014 | Toshiba Satellite Computers & Internet
Case 7130 Tractor stas running then quits
I had a close to that problem and decided the fuel was the problem,So I added a electric fuel pump between the fuel tank and the manual fuel pump,,but also check the fuel line between the fuel pump and the fuel tank,for it may plugged with dirt or the manual fuel maybe to weak to the job ,so I added electric fuel and the no more problem with air locks or no fuel to keep the tractor running.
Jun 04, 2014 | The Times Case Corporation Tractors...
I have a DYT 4000 from 2004. Cutting the lawn today, about half way through something inside the engine popped (sounded like a belt) and the tractor shut off. I tried to restart and the starter was FLYING...
Sounds like an internal engine failure. Take the spark plugs out and stick a screw driver in the the cylinders. Then turn the engine by hand, and see if the pistons move. My guess is one or both won't, but if they do then you'll need to do more testing like a compression test or leak down tests. You may even need a partial tear down to find the problem. Sorry to be the bearer of bad news, but it is possible that it is repairable rather than having to purchase a whole engine.
Oct 03, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
A,b,g Tractor Carburetor Float Dltx10: i had my john deere riding mower running then shut...
My John Deere only starts with a hammer. I have the Kawasaki engine and it is famous for bad starters, so I carry a hammer and tap on the bolt when I want to start it. So, you either have a bad solenoid in your starter, or the contacts are dirty, battery connections are dirty. Or the battery is dieing. Check it out. Hope this helps.
May 07, 2010 | John Deere A,b,g Tractor Carburetor Float...
Engine cutting off after engaging the pto (mower deck) JD 317
its likely to be a switch playing you up try hard wireing the switch to see if it stops this cutting out first, do one switch at a time till you fine the one playing up
May 02, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Engine running too fast
have someone check the govenor on it. Sounds like it is mesed up
Jun 20, 2009 | Garden
Just purchased Husqvarna YTH2348 Purged transmission perinstruction in manual when recieved.Ran fine for about 2 hours.Now transmission whine while driving forward.In reverse no whining.Does anybody have...
As for whining sound I believe this normal. The purging instruction using the bypass valve ingaged on low engine running. Next with the bypass disengaged followed by the fwd with fast breaking and or rev with fast breaking actions to get the wheels to turning and getting better responce takes time. This does take some time to do - in my case 15 minutes or more. My tractor had 65 hours on it before it showed signs of not pulling a slight hill. I had to remove the transaxle and put in 50 wt. motor oil and with the purging I was able to bring new life back to this tractor. The original 30wt. motor oil is fine for a brake in oil and I did drain it and took the bottom cover pan off and cleaned the metal particals on the magnets and cleaned the filter. These transaxle are sealed but have a vent plug at the top of the case. That little plug is hard to get off with out damaging it. My tractor whins in forward and reverse but has good hydrostatic power now. So I say the whin is good!
Apr 06, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Sewing machine struggling to run or sewing slowly with no load
sounds like it needs oiled.
Clean thoroughly in the hook and bobbin case area and oil 1-2 drop is all.
Oiling instructions:
You never need a diagram to oil a sewing machine. Turn the hand wheel and look for every area that metal touches metal. 1-2 drops (more Is Not better) of oil everywhere metal rubs metal, use a flashlight and look and oil look and oil until every spot is oiled.
Mar 17, 2009 | Sewing Machines
The Times Case Corporation Tractors International Harvestor Logo
319 people viewed this question
Top The Times Toys Experts
Andrew Taylor
Andrew Taylor
Are you a The Times Toy Expert? Answer questions, earn points and help others
