Question about RoadPro AC/DC Power Inverter 2000/5000w
I have a 2500 watt roadpro, and would like to no if there is a different way to hook up to keep from killing both of my batteries in my Dodge Cummins. I have a small freezer that I take hunting so I can cool the meat, and freeze the capes.
  • 30 Answers
Refrigerators require a LOT of power. They are one of the biggest energy consumers in a typical household. Although they don't run all the time, they kick off and on quite a bit. To answer your question, there is no wiring solution for your problem. Power inverters are inherently inefficient as well therefore they are actually pulling more power than required to power your refrigerator. Your refrigerators will work while your engine is running (because the alternator is providing continuous power) but as soon as your engine is off, they switch to battery power. If an generator is out of the question, I'm sure you can find larger batteries that could extend the time your refrigerators can run.
I hope this helps!
Posted on Aug 30, 2010
    Master:
  • 507 Answers
You can install a battery isolator or battery switch between your two batteries; using one for the inverter and one for the truck. Or you have to get larger capacity batteries.
Posted on May 17, 2014
Dodge cummins tow haul stays on
Hi, I have a 2004 Dodge Ram 2500, 5.9 Cummins with 225,000 miles. Just today, my Haul/Tow keeps coming on and Trans/Temp light. Keeps automatically switching in and out on its own. It's been 100,000 miles since my last trans maintenance. Going to a mechanic close and he suggested to start with fluid change, filter change, and inspect the band, maybe adjust. Trans runs very smoothly. Checked the fluid, looks clean and not hot. Is this common with this year and mileage? If so, whats normally the out come? If the band is bad, do I have to replace the entire trans?
Scott
Oct 29, 2011 | 2004 Dodge Ram 2500
Is there a dodge cummins diesel engine?
From 1989 til now Dodge has put a Cummins Diesel in their 2500 and 3500 pick ups. Here is a link to a great article that explains all the different motors and stuff.
http://www.dieselpowermag.com/tech/dodge/0604dp_cummins_diesel_motor_history/index.html
Mar 15, 2011 | Dodge Ram Pickup 3500 Cars & Trucks
I have a 1200 watt amp and 2 12 in pioneer champions and it keeps killing my battery how do I hook up this capasitor I just bought?
first make sure your power wire is directly hooked to the battery, {make sure ure in line fuse is pulled} power wire that goes to positive of power cap , ground wire is grounded to chasis, now attach aditional power wire to amp and aditonal grond to amp . make sure all conections are solid and tight { also make sure inside of power cap is tight as well after long periods of time the insides loosen } i have 2 -1,000 watt sony xploid amps and 2- 1,200 watt sony expoid subs and they pound hard . i probley should have 2-1.2 farrid caps for what i have but it seems that its holding its own
Dec 04, 2010 | Metra Tsunami 1.2 Farad Capacitor
I am looking for a way to kill fuel supply to the engine as an anti theft device. My truck (2004 Dodge 2500 5.9L Cummins) has the factory alarm, but I am not sure exactly what this alarm does as far as...
If you remove the fuel pump fuse of relay you will stop the flow of fuel. A simple on/off switch installed on the hot wire going to the fuel pump will work.
Oct 07, 2010 | 2004 Dodge Ram 2500
Cummins verry rough idle no throttle response
HI
Thanks for the info!
Lets start from scratch and see if we have a mechanical or electrical problom Disconect the batterys both positve and negitve
let it sit for a 1/2 hour. Then hook the batterys up try and start it.
lets see if you get a check engine light or if wee need to go intothe mechanical end, Ill be here on and off most of the day
Thanks!
Jul 13, 2010 | 1998 Dodge Ram 2500 2WD
How do reset a 2005 dodge 2500 cummins
If you are talking about resetting the codes of the computer, most cars can be done by just disconnecting the battery for about 5 minutes.
Apr 29, 2010 | 2005 Dodge Ram 2500 Truck
P1493 code
If you are running any extra systems, ie amps, subs, high watt speakers, etc. etc. you may need to get a better batter, like the blue. or yellow top one. check with auto zone.
Mar 11, 2010 | 2001 Dodge Ram 2500 Truck
2004 dodge 2500 with cummins diesal engin light
your code is PCM/ECM power input signal intermittent. this is ussually a sign of a bad connection whether it be in a connector or a short or brake in a wire.
Jan 26, 2010 | 2004 Dodge Ram 2500
Have several non working inverters
I have had this happen a few times.
Sadly replacement is the Best option.
Repairs can be %75 the cost of a new one.
The best invert we have been using is a Pure Sine 1500 watt inverter.
Sad news but hope this tip helps.
R/
David
Jan 09, 2010 | RoadPro RPPI-2500W Inverter
RoadPro AC/DC Power Inverter 2000/5000w Logo
195 people viewed this question
Top RoadPro Electronics - Others Experts
Craig Butler
Craig Butler
jdthefixer
Are you a RoadPro Electronics - Other Expert? Answer questions, earn points and help others
