Question about Sony God of War Collection for PlayStation 3
God of war 3 wont load - Sony God of War Collection for PlayStation 3
  • Will Bokach Oct 29, 2010
    God of War 3 did not ship with the Collection Disc. Please clarify problem.
  • Will Bokach Oct 30, 2010
    Are asking if God of War 3 in on the God of War Collection disc? Or are you having an issue with the game itself?
  • 39 Answers
SOURCE: god of war 2 doesn't play
Try this -
http://www.google.com/url?sa=t&ct=res&cd=3&url=http%3A%2F%2Farstechnica.com%2Farticles%2Fpaedia%2Fhardware%2Fps2.ars&ei=Yy4fSLKxBYqopwSviazxDA&usg=AFQjCNGqWb2PhrXU_z3FiEUBYsAL7FcEXA&sig2=XQtKVKuJCZvvBupNZUoVEA
Posted on May 05, 2008
SOURCE: God of War 2 game won't play on my PS2
Does it make a clicking sound as it tries to read the disk?
I had the same problem and it turns out that it is the console. But it is easily remedied. I cannot take credit but follow this link and you will see it is an easy fix.
http://boardsus.playstation.com/playstation/board/message?board.id=psx2&thread.id=1385484
Posted on Sep 17, 2008
  • 8 Answers
SOURCE: God of War II Loading Problem
im sorry man.. the game is incredible, but i think its messed up. but maybe its not just the game. do u have tohe old or new modeled ps2? the new one has a better laser detector thats y. if u have ps3, then it shoiuld definitely work on it cuz ps3 can detect ps1 games that have like a million scratches. if ur gonna get ps3, then dont get 40gb since it does NOT play ps2 games.
Posted on Jan 25, 2009
Jmizpah777
  • 290 Answers
SOURCE: God of War 1 and 2(Unable to read disc)!
Check your cd if it can play in different ps2 consoles. if it can, then theres nothing wrong with the cd.
probably your game console has problems on disk reading.
FIX Those Ps2 disk errors.
You're going to be surprised when you find out how easy this is. Read the instructions all the way through before you attempt the repair just so you'll be familiar with the entire process. First take off the outer cover of you PS2. If you haven't done this before, you will have to remove all the screw covers from the bottom of the unit, both plastic and rubber, these will be the only screws you will have to remove in order to take off the outer cover.
To remove the outer cover, lift up from the rear of the unit and pull towards the front in order to clear the controller jacks and the eject/close buttons. As you remove the outer cover you will notice a small metallic ribbon cable inside the machine leading to the eject/close and reset buttons on the front of the unit, this cable is usually taped to the top of the disc tray. This cable is not a sensitive as it appears; just remove the tape holding the ribbon cable. Once the outer cover is off you need to remove the cover to the disc tray, this will require a rather small phillips screwdriver (I've seen a few that use a standard slotted screw). Now that the tray cover is off, the first thing to do is to clean the laser eye. All you will need is a Q-Tip dipped in alcohol. Just swab the eye a few times and allow it to dry on its own, making sure that no lint was left behind from the Q-Tip.
After the cover is off of the disk tray and the laser has been cleaned you will need to plug the unit back in, (The unit needs to be hooked up to a TV as well to test it while you have it open. You should have a DVD, a game disk with a silver or gold back and one with a purple back in order to fine tune the system to play all three.) It will be necessary to have the unit powered up to perform the repair. Press the eject button so that the tray slides forward exposing the undercarriage. At the back of the unit you should see a small white, geared wheel about the size of a quarter. This little bastard is the cause of all your problems.
This wheel changes the angle in which the disk is held. You will notice that there is a small metal tab that holds the wheel in place. Take a felt-tip marker and mark the point on the wheel that meets the tab. That way you will always know the original position that the wheel was in. Now that the orig. position has been marked, feel free to spin the wheel for a few full rotations in order to see how it changes the angle. It will only alter the angle a few degrees before it goes back to zero, after it reaches the maximum angle it will go back to flat after each full rotation. Once you've toyed with it to see how it works, put the wheel back to the original position that you have marked. Then advance the wheel about 1/8 of a turn and place the disk tray cover back on top of the disk tray. (You will not need to screw the tray cover back down in order to test the machine; you will only need to hold down the cover with your fingers while trying to load/test a disk) Now place a DVD in the tray and press the eject/close button in order to close the tray and load the DVD (hold down the cover as explained above). Wait to see if the DVD loads, you may have to use the browser in order to load each disk you test. If the DVD loads, eject it and load a silver backed disk, if that loads try a purple backed disk. If all three loaded successfully, congratulations you're finished. If not, remove the tray cover, eject the disk and advance the wheel another 1/8 turn and repeat the process. It just a matter of finding an angle that will facilitate the operation of all three types of disks. Once you've found the proper angle and the system is operating to its full potential, close it up and let'er rip. I also do not recommend placing the PS2 on its side once you have fixed it. Although Sony says they recommend it in the owner manual, I have since seen internal Sony documents retracting the statement and attributing many malfunctions to storing and operating the unit on its side. Keep it flat at all times.
well. i hope this works.
pm me if problems continue.
Posted on Aug 08, 2009
Dajuliehubby
  • 203 Answers
SOURCE: play staion 2 reads all games but wont read god of war 1 and 2
Best bet is to try a laser lens cleaner and seeing if that helps. I know it sounds silly that it might be dust on the lens when only THOSE games don't work, but stranger things have happened.
Posted on Jul 30, 2010
God of war 3 pc cd key
fc4c-3d8-05f-d411-uk20
don't forget to thank me <3
Mar 09, 2013 | Video Game Consoles & Games
I need god of war 3 pc password or key?
Write your answer...I need god of war 3 key
Oct 30, 2012 | Video Game Consoles & Games
I need god of war ghost of sparta pc cd key
i need God Of War Ghost Of Sparta PC cd key can any one help ne please
Apr 04, 2012 | Video Game Consoles & Games
Only god of war wont work
Are you running the latest firmware 3.21?
If yes, I would try deleting the Game Data for GOW3 then try again. Hopefully it's just corrupt game data.
Let me know.
Apr 04, 2010 | Sony Playstation 3 (PS3) Console
Play staion 2 reads all games but wont read god of war 1 and 2
Jul 04, 2009 | Sony PlayStation 2 (PS2) Console
My god of war game wont work idk wats wrong with it
clean the disc and the eye of the playstation with windex
Mar 11, 2009 | Sony God of War for PlayStation 2
Want to play god of war 3
God of War 3 has been announced, but hasn't been released yet. It has been announced for PS3, not PS2. It will not be compatible with your system. If you want to play it, you will have to purchase a PS3.
Jan 06, 2009 | Sony PlayStation 2 (PS2) Console
Unable to read god of war II
Some ps2 models have defective lens coils that wont properly focus the lazer beam on the disc ive had this happen to me before, but to fix it, it requires you to replace the reader head. I can walk you through it, but only if you are comfortable in dissassembling/reassembling the ps2 with the chance of perminately harming your ps2 or yourself. Id advise you to take it to a repair shop for fixing.
Dec 21, 2007 | Sony PlayStation 2 Slimline Console
Sony God of War Collection for PlayStation 3 Logo
173 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
