Question about Gigabyte GA-8I865GME-775-RH Motherboard
Hi, When i want to open the computer, the picture is not appear but hear a stressful beep. Before this happens the central unit was glued to my desk leg iron that is in full and the last time know that the litlle current was a leakage current of low intensity. Kid regards,
  • joecoolvette
    joecoolvette Aug 06, 2011
    "Before this happens the central unit was glued to my desk leg iron that is in full and the last time know that the litlle current was a leakage current of low intensity." This your idea of humor? If not clarify.
    Problem Solver:
  • 10 Answers
HI
PLEASE CHECK THE RAM ONCE AFTER THAT CHECK THE POWER SUPPLY.
BECAUSE EVEN IF THE POWER SUPPLY GOES ALSO YOU WILL FIND THE SAME ISSUE
Posted on Aug 06, 2011
Hi When taking pictures in Auto, Live View...the mode changes on screen to Auto Slow, and it sounds like a long delay before taking the picture. New to SLRs. Just curious why this is happening. Thanks!
Hi, no problem, in Live view the AF and aperture is lock and hear a beep. A Lo = scene low light or aperture set in high number, open aperture or set ISO higher .
Feb 16, 2011 | Nikon D3100 Digital Camera
Toshiba RAV-SM802KRT-E heat pump/air conditioner split system, works fine for a day or two then turns its self off, go to restart it and all you get is two audible beeps from indoor unit and no go.
Hi, what you need to do first is to go to the indoor unit and remove the panels where the beeps you are hearing are located. If the power shuts off when you remove the panel, you will have a panel switch located around the perimeter you may have to tape down to restore power while you check it out. You may have a chart on the panel glued to the inside or somewhere that may tell you what is going on according to how many beeps or led light flashes. The condenser coil outside may be shutting off on high head pressure due to it being dirty. You can use a water hose and cut power, and wash the coil out good. Be careful not to use to much pressure or you could bend the aluminum coil. If you are getting two beeps from the indoor unit, and it will not start, it should say on a chart what this means. Make sure your filter is clean. This unit is shutting down on a safety due to something going on, this is why you need to service it, clean coil, make sure filter is clean, Make sure your high voltage connections at all breaker boxes and fuse box at the outdoor unit are good and tight. They may be loose causing the unit to draw to much amperage. Start from the basics and see what happens. It doesn' sound like a internal problem, but I won't rule this out. Do the things as i have asked and we will go from there. Keep me posted.
Sincerely,
Shastalaker7
A/C, Heating, and Refrigeration Contractor.
Jul 14, 2010 | Heating & Cooling
Can anyone tell me what an F70 code is? When I push the start button it beeps at my twice and then in about 30 seconds I get a long beep and the error code F70 is on the display. Thanks in advance for your...
F70 error code indicates Central control unit heartbeat failure. If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the Central Control Unit to the User Interface.
1. Check for continuity of the User Interface harness.
2. Check wire harness connections to the User Interface and the Central Control Unit.
3. Replace User Interface if drum is rotating.
4. Replace Central Control Unit if drum is not moving
Thank you !!
Jun 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a Beam Rugmaster Plus power head Model BM1 393 Type AB and the connection were the metal pipe meets the plastic swivel broke close to the unit. It appears like a manufacture defect in that is broke...
This is most likely repairable. Lots of the Beam parts are available. I would recommend checking out any local vacuum shop or searching online for a central vacuum store that sells beam products.
Sep 29, 2009 | Beam Industries 750 Classic Bagless...
How do you unmute a pioneer supertuner ?
hi there
press and hold the source button till the pioneer unit shuts off...........once the unit is powered off press and hold the F / function button once the clock displays or you hear a beep press function button repeatedly until telephone appears......once this happens press the skip button to left or right to change to ATT (attention).........once you have done this press and hold the source button till the pioneer unit powers on....now simply turn up the volume and problem should be solved
hope i was able to help you
Feb 18, 2009 | Pioneer Car Audio & Video
Screen won't appear upon start up and I get 3 beeps but no screen
what you are hearing is a beep code, if its 3 short beeps then its the memory which has developed a fault and it may need to be replaced
Nov 16, 2008 | Acer Aspire 5100 Notebook
Beeping Upon Bootup
dependent on how many beeps you hear is dependent on what might be the problem. A fuller explanation from pushing the power button to nothing happening would be more than helpful. Beeps in a Poweredge can mean motherboard, memory or as you said power supply problems.
May 06, 2008 | Dell POWEREDGE 2400 Server
Seagate freeagent 500g usb 2.0 beeps sound
You still need assistance in cracking open the Seagate Freeagent Pro 500GB and trying data/file recovery? If yes, would appreciate a post back.
Good luck and kind regards.
Thank you for using FixYa.
Mar 17, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Downloading
Hi, In dowloading picture it must be in play mode to detect camera by your computer try it now , insert usb to camera and computer you can hear alert beep , the downloading icon will appear either from operating system or cd supplied by camera. , just follow instruction
Jan 06, 2008 | Canon PowerShot A560 Digital Camera
Cannot access western digital 120gb hard drive
Please use Computer Management by clicking Start> Control Panel> Administrative Tools> Computer Management> Disk Management.
If your harddrive appear maybe you need to assigned drive letter then apply and right click then explore.
Please rate me SOLVED
Nov 20, 2007 | Western Digital (WDXB1200BBRNN) 120 GB...
Gigabyte GA-8I865GME-775-RH Motherboard Logo
59 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
