Question about HP OfficeJet 6110 All-In-One InkJet Printer
When I try to scan I get the message " can not connect to pc" every thing elese works on the printer.
    Director Badge:
    Uploaded 100 video answers.
  • 1,751 Answers
Hi
follow this steps
1.disconect usb cable
2.uninstall your printer driver from your pc
3.run setup from printers cd or from the driver you can
download from Hp official site
4.follow the setup steps
5.only connecte your printer to pc when setup ask you to do
If i helped you
pls vote me
Posted on Nov 01, 2010
Why doesn't wireless scanning work if initiated from the PC or from the MF212w printer?
hi . I'm almost sure that the toolbox only work on USB. for network scanning there is another aplication I thin is color network scan gear
Mar 14, 2016 | Canon imageCLASS MF212w Network-Ready...
I have a brother MFC 9440CN when I try to scan a document the error message comes up as not being connected to pc. The cable is definitly connected as the print option works fine. Can you help. Thank you.
Are you scanning from the PC, or are you scanning from the printer?
If the latter, the scanner is trying to send the document to a server software on the PC, which is probably not running; hence the "not connected" message.
Try acquiring a picture using Control Panel -> Scanners -> Acquire Image and see if it works. If it does, you must run (or reinstall) the Control Center software, and configure it as to where to store the Scan-to-File documents.
Nov 02, 2009 | Brother MFC-9440CN Laser Printer
Scanning option won't work - everything else does!
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
astrtr4
Aug 19, 2009 | HP Officejet 5610 All-In-One InkJet...
Cannot scan wirelessly from HP Photosmart 4580 wirelessly
I reinstalled the printer software and reconnected the wireless connection and it now works well. I read somewhere that registry cleaner software may remove HP files that are required so this time after the registry cleaner scan, I unchecked any HP entry or printer entry and the scanner is still working, however, only from the pc to the printer, I still cannot scan using the buttons on the printer.
Jun 06, 2009 | HP Photosmart C4580 All-in-One InkJet...
Scanning error - cannot scan error code 2,155,0 ???
i found this while i had the same error msg... apparently its actully the USB cable where its does not suffice
here is the link : http://www.fixyourownprinter.com/forums/printer/49111
Thanks
Sanjieev
Jan 13, 2009 | Office Equipment & Supplies
My 3210 will not scan
I now have 2 of these and both print ok but can not scan with either, never tried to till now.
I have re- downloaded the driver from HP.com via Internet Explorer (usually use Mozilla Firefox) and i get 2 diff. error messages : network busy (impossible since it is connected via USB) and the 1 at my office connects wirelessly but error message is something to do with software.
Thanks!
Nov 02, 2008 | HP Photosmart 3210 Printer
Scanner won't scan to pc
Is the error message Epson Scan cannot be started? What is the Operating System? Is the printer directly connected to your PC?
Sep 26, 2008 | Epson STYLUS CX3900 All-In-One InkJet...
Kodak AIO Easyshare 5300 scanning problem
Could be USB connection if you have another cable try it. Try connecting to different USB ports on your PC. If you have a Powerd USB hub lying around try connecting the printer to the PC through that.
Also try disconnecting all USB devices including the printer. Reboot your PC. Connect only the printer and try and scan.
Some times multiple USB devices dont work when they are both connected to the same PC.
Hope this helps!
SDtester
May 20, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
When scan job is sent a start failure error comes on the display
Don't worry about the clean roller message. It is just a reminder much like your scheduled maintenance light that appears in your car.
Start Failure can occur for a number of reasons. When you get a start failure message close your scanning software and reopen it. Sometimes your connection may degrade if left idle. If that doesn't work shut down the scanner and pc. Turn on the scanner and wait until it is fully initialized before turning on the PC. These steps have resolved that problem for me. Lacking a manual, I just try things. Good Luck
May 07, 2007 | Kodak Digital Science 2500D Path-Through...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
44 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
