Question about Cooper Wiring Devices ACE6001V-K "ACE" ROTARY DIAL DIMMER
How to wire a gfci to triple single pole switch
  • 8,404 Answers
Are you tryng to control this GFI with a three-way switch circuit? Wire it like you would a light but put the gfi where the light fisture would be. Circuit on the side of a three way switch box (the box the switch comes in.).
Posted on Aug 29, 2010
Is this considered a single throw switch or a tripple throw switch and what's the difference
We cannot see the product you are asking about
Example single throw switch is household light switch ..., flip the switch either direction and load turns on-off.
Example double pole switch is 240 volt double breaker... flip the breaker and two wires turn on-off.
Example triple pole switch is any 3 phase contactor or 3 phase timer ... flip the switch and three wires turn on-off
http://waterheatertimer.org/How-to-wire-switches.html
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
http://waterheatertimer.org/3-Pole-contactors.html
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Apr 27, 2015 | Electrical Supplies
I have a gfci/switch and need a 4 wire instructions. As none of the diagrams match what i have.
What device are you replacing... a switch or a outlet?
1) If you are replacing a switch with 3 or 4 wires?
That is either a 3-way switch, 4-way switch, or a DPDT switch and cannot be replaced with GFCI
2) If you are replacing outlet with 4 wires, then it can be replaced with GFCI combo.
http://waterheatertimer.org/How-to-wire-GFCI.html#8
3) If you are replacing ordinary single-pole switch, then you can replace with GFCI combo IF the box has a neutral wire
http://waterheatertimer.org/How-to-wire-GFCI.html#6
4) You can install GFCI protection on any circuit by installing GFCI earlier in the circuit.
http://waterheatertimer.org/Basic-house-wiring.html
Gene
Oct 21, 2014 | Pass & Seymour 1595SWTTRWCC4 COMBINATION...
Replacing a triple single pole (1980's) with a
DISCLAIMER:Attempting to work on house electrical systems without proper training is DANGEROUS and you stand the risk of dying.
The Cooper 7729w is a three pole single throw switch with a common (connected) hot wire that supplies it. What you had before was two separate single pole single throw switches and one single pole double throw switch that is used as a three way. The short answer is NO that replacement will not work UNLESS you don't want the other switch on the other side of the room to work.
Personally, I think that if you really need to ask this question you need to seek the advice of a professional electrician.
Dec 18, 2012 | Electrical Supplies
TR274 & TR 291 Wiring Diagrams
Copy following link for specific wiring diagrams for combo switches:
http://waterheatertimer.org/How-to-wire-switches.html#combo2
Combo switches require Neutral wire in the box.
Neutral wires are usually the white wires twisted together, covered with wire nut, and pushed to back of box.
Nov 09, 2012 | Cooper Wiring Devices Triple Deco Single...
Wiring a GFIC outlet to a single light/outlet
Copy following link for wiring diagrams of GCFI wiring:
Jun 10, 2012 | Electrical Supplies
Hooked this product up flipped all three and only light and heater come on no exhaust fan
there should be a hot wire to the fan just look for the other wire one for fan one light one heat its there, good luck
Aug 16, 2011 | Cooper Wiring Devices Triple Deco Single...
I have a single pole switch that currently controls a bedroom outlet. i am installing a fan and light in the bedroom. i have a new triple switch that i want to control the existing outlet, the fan and the...
Wiring is not fully described: Location of hot wire and neutral wire from breaker box are unknown.
If Hot wire arrives in ceiling box first, the switch box will not have white neutral wires that are twisted together and covered with wire nut. Neutrals will be in ceiling box.
What is known: You are replacing single pole switch attached to one 14-2 wire going to light.
You are replacing light with a fan-light and replacing switch with a 3-pole TM8111 switch.
You have replaced 14-2 wire with 12-3 wire.
TM8111 wiring shows following link:
http://waterheatertimer.org/images/TM8111-switch-wiring-500.jpg
Fan pull-chain wiring shows following link:
http://waterheatertimer.org/images/Fan-motor-1-344.jpg
Assume neutrals in ceiling box.
Assume Hot wire in ceiling box: Connect 12-3 black wire to black Hot wire. Connect 12-3 white wire to black wire on light. Connect 12-3 red to red wire on fan.
White neutral from fan and white neutral form light connect to other white neutral wires and covered with wire nut.
Wiring at switch:
Black Hot wire from ceiling box connects to A COM terminal.
White wire to ceiling light connects to A SP2
Red wire to fan connects to A SP1
Jun 21, 2011 | Pass & Seymour Legrand TM8111 Three Single...
I replaced a triple pole switch. Now only one switch works. Any advise?
If I understand correctly, you replaced a triple pole switch with another triple pole switch?
The key to replacing electrical devices is noting color of each screw.
Hot goes to dark screw.
Load wires going to each light connect to brass screws.
Neutral wires do not connect to switches.
Electricians don't guess, they test.
Separate wires for testing.
Tape tester leads to wood sticks to keep hands away from power.
Turn power ON.
Test each wire to bare ground wire.
Tester lights up on Hot wire.
This is the wire that comes from circuit breaker.
Hot wire connects to dark screw.
Connect each of the other wires to brass screws, and use switch to test which wire goes to which Load.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 17, 2011 | Cooper Wiring Devices Triple Deco Single...
GFI on cord trips out.
Probable cause is a single pole gfi opposed to a double pole gfi.
* Do not use a single pole GFCI ON A MULTI WIRE CIRCUIT, IT WILL NUISANCE TRIP IMMEDIATELY
Use a two pole GFCI circuit breaker on such circuits.
May 20, 2009 | LG LWHD1800R Wall/Window Air Conditioner
Cooper Wiring Devices ACE6001V-K "ACE" ROTARY DIAL DIMMER Logo
152 people viewed this question
Top Cooper Wiring Devices Electrical Supplies Experts
Steve
Dennis Boxerman
Are you a Cooper Wiring Devices Electrical Supply Expert? Answer questions, earn points and help others
