Question about Toys
West coast choppers 36 ford. the car goes when you first turn it on but stops within a few seconds the speaker still sounds. If you turn the car off and right back on it works again for a few seconds
    Sergeant:
  • 252 Answers
1.Test the electric motor in the car by clipping the two wires.
2.Have a good 9volt battery to test with
3. Strip both of the wire ends.
4.Wrap one wire around the positive terminal of the battery and wrap the other end around the negative end of the battery.
5.Motor should begin to spend.(IF MOTOR DOESN'T SPIN YOUR MOTOR IS BAD). PLEASE REPLACE.
6.If motor does spin. Barely apply pressure the turning motor with your hand. If it stops turning or has a not torque at all the motor is bad.Please Replace
7.If it motor is good solder the wires back into the circuit.
8.Make sure all gears turn with the the motor and look closely to see if one is not striped. If one is Please Replace.
To replace parts tou will have to go back to the manufacturer.
You didnt specify what type of car this was. For example a Power Wheels, Radio Remote control,or just a switched toy car that you turn on and place on the floor.
If it is a large toy do the same test procedure but with a larger battery. If it is a Power Wheels I would prefer a car battery.
The elecric motor is the only thing that would make your 36 ford behave in this manner. I am sure this what your problem. I just gave you these test procedures so you can be sure yourself.
Thanks.
Posted on Aug 29, 2010
Looking for a 20 x 3.0 bicycle inner tube for a west coast chopper bike
Kenda 20 X 3.0 in case u still are having troubles with this it took me awhile to find one also
May 18, 2013 | Cycling
Dishwasher starts to fill then just hums
Sounds like a motor problem. Behind the chopper is an access to the impeller, try turning the impeller or the chopper blade and see if the motor will rotate. If it doesn't, then something is stuck preventing the motor from running.
Mar 07, 2009 | Dishwashers
Push button 4wd not working
It sounds like someone has changed into 4wd at speed and broken the internals of the system. Check the relays and fuses first but it sounds more serious than that. If it drives in 2wd put it in reverse an circle listen for any undue noises.
Jan 06, 2009 | Isuzu Pickup Cars & Trucks
Toys Logo
120 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
