Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
My salt water system keeps saying service and wont work even after i did everything the book has asked me to do
  • 297 Answers
The book has not asked you to do any thing with the unit when it pertains to a service light. The book guides you through solutions only for codes
One of those pages tells you that service light is not for the consumer to fix or reset
Only codes are user fixable.
Call Intex and they will e-mail you a form fill it out and fax it back
you will have a new one at the door in days as long as you have a valid receipt and the unit is under 2 years old
Posted on Aug 30, 2010
Can I add salt and run new saltwater system?? Will it clea it??
if your asking will a new salt system clean my pool from a preseason condition , well no not really , salt systems are for maintaining a healthy pool water thru the season , see they use the salt ions to make chlorine , so I guess technically yes but it would take ten times longer to do it and by then the salt would be all used up (converted) , its much easier to use common pool chemicals to "start up" the pool then after a healthy chemistry is achieved then switch over to salt system , and even after u switch always keep an eye on your water chemistry(testing ) and your never will be surprised by an upset !!
Jun 23, 2015 | Pool & Spa
It keeps saying low salt i have an 18ft x 4ft deep circular pool and my salt water system wont clorinate
hello
there is too much for me to type please look up my name and posts about this issue
also look at my posts for low flow and green water
I promise you will learn very much about pool maitainence
Aug 08, 2010 | Intex Automatic Salt Water System for ...
Hi i have a 18 x 48 above ground intex frame pool with a salt water pump /chlorinator system. i have put the required amount of salt in 75 kg and it has fully desolved. the alarm keep coming up on the pump...
the amount of salt that they reccomend in the book is just a starting point
You need to get a salt test kit that reads in #'s not colors
Get your pool to as close to 3000ppm as possible
lower than 2800ppm and you will not produce enough chlorine
any higher than 3500ppm and you can trigger high salt alarm, have bad tasting water, or even get cloudy water
Like you have done, when adding salt , filter only for 6 hours or so to fully disolve
Jul 18, 2010 | Intex Automatic Salt Water System for ...
My Salt water pump keeps saying it is low on salt. I have added plenty of salt.
What is plenty of salt? There is a specific amount that you need Can't guess at it.
You must be above 2800ppm and no higher than 3800ppm
3000ppm is the best
You will need test strips for salt that reads in numbers not color
High salt can also trigger a LOW salt alarm
Don't ask me, it just happens
Just remeber 3000ppm
Jul 03, 2010 | Intex Automatic Salt Water System for ...
Low salt alarm on Intex system
so what does the test strip say. Should be as close to 3000ppm as possible anything close and under 2700ppm will trigger a low salt also you must run filter only for 24 hours to thouroughly mix the salt before trying to turn on the generator
Jun 14, 2010 | Intex Automatic Salt Water System for ...
Code 93 saltwater system
Hi, Code 93 is telling you that the system is done running, did you mean to say it said 92? That code would be for too much salt. If indeed it is a Code 92 you are getting, give Intex a call, or email. I have found their website to be very helpful, they have a F&Q's area. Good luck!
Jun 15, 2009 | Intex Automatic Salt Water System for ...
The salt light keeps burning
the salt light is done by a reed switch operated by a float in the salty water. float may be stuck - give softener (where you put in the salt) a tap and also stir the water inside the softener. i assume you have put in enough salt. its not a serious fault
Mar 30, 2007 | Baumatic 18 in. BDW45.1 Built-in...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
439 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
