Question about Kenmore Dishwashers
I have a 587 dishwasher and would like to replace the outer door with a black one
  • Kenmore Master
  • 43,501 Answers
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Aug 29, 2010
How do I remove the front panel so I can replace it?
Dishwasher Outer Door Panel Replacement - GE ...
? 1:34
www.youtube.com/watch?v=TnzM5niMjD0
Nov 1, 2012 - Uploaded by RepairClinic.com
Dishwasher Outer Door Panel Replacement - GE DishwasherRepair (Part ... and the only 2 screws one can
Nov 01, 2015 | GE GDT550HGDBB Hybrid Stainless Steel...
When we close the dishwasher door the main circuit board trips
Probably a short in the door interlock, get a replacement interlock, remove plug, remove outer door panel (beware, sharp edges) replace interlock, outer door panel and test, should be ok.
Feb 18, 2013 | Dishwashers
Dishwasher wont run. i replaced the control board, still no power to board. i checked the power cord for electrical, and there is power to the cord. any suggestions?
having replaced the board and no power it. To me it seems like maybe a wire in between the inner/outer door panel may be broke. Check the area where the wires come from under the tub and enter the arae between the door panels and see if over time from a wire rubbing during the opening/closing of the door if a wire broke. Espically check the black wire from the house power connection into the control board
Aug 18, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Can I buy a new door for my GE dishwasher?My dishwasher is white and all my other appliances are black. Can I just replace the door?
Most likely, yes, outer door panel at the least, plus you'd most likely replace the lower panel and trim parts. If the unit is not too old, those parts are probably available. If you list your full model number, I can try to give you an idea of what parts it would take.
Aug 28, 2009 | GE 24 in. GHDA960K Built-in Dishwasher
Broken handle on dishwasher
Bernie,
TURN OFF POWER TO UNIT. Open door, remove all torq screws from door panel, separate inner and outer door panel. latch assy is able to be removed, place black wire connector and white white connector back respectively, place inner part of door back and replace the torq screws. Then turn power back on for unit.
Jan 09, 2009 | Maytag Dishwashers
Kenmore Dishwasher #587.... doing nothing but heat dry
The problem appears to stem from the float and float switch. The float is a mushroom shaped plastic part that resides on the bottom left, just inside the door. It appears that the float does not release the float switch, causing the dishwasher to think it is full of water, and won't allow the dishwasher to fill. It's a relatively straight forward repair, but even with a new part, the same scenario is likely to repeat itself until the float or float switch is modified by Kenmore.
Nov 20, 2006 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore 587
You may try the rubber gaskets and fasteners that attach your heat element through the bottom of the dishwasher body. This is the only full penetration of the shell involving metal that I see. You could see these fasteners if you remove the dishwasher from its current position, rotate it clockwise on its side and see the two cheapo pressed metal nuts on threaded studs that have wires attached. These keep that black metal loop on the bottom (inside the washer) in place. Remove wires, unthread pressed metal fasteners, check heater element for the rust issue (replace if needed) and reinstall new rubber gaskets and fasteners. Hope that helps!
Oct 09, 2006 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwashers Logo
51 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
