Question about Kenmore 24032\24036 Top Load Washer
Holding water not doing nothing else/2 speed moniter with 3 speed combinations
  • Kenmore Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Aug 29, 2010
Frigidaire Top Load Washer Model # FW933FS2, when starting a load of laundry it begins to agitate but no water enters the drum. What do I need to fix this problem?
Hello James, thank you for your post!
I understand that your Frigidaire washer will start to agitate and no water will enter the drum. This could be an issue with your water valve or the control panel. I would check to make sure the water lines are opened and the connections are not restricted or damaged. If the water hoses are not damaged you may need to have a professional technician out to perform a proper diagnosis. This will help you to avoid any unnecessary part purchases. Good luck! -Matt
Dec 15, 2015 | Frigidaire FWS933FS Top Loading 3.0 cu.ft....
Cell phone gets hot
Probably due to lots of apps running in current and background sessions. Turn some of the unneeded apps off, and understand that as you use your phone the battery will become warm as it provides the current to the phone.
Mar 31, 2015 | Frigidaire FGX831FS Washer/Dryer Laundry...
I set a code in the master lock speed dial 1500id, and it will not open. I cannot reset the code and do not know how to get this open. I have read the other suggestions and nothing has worked yet. Anyone...
Try 2 options:
1. just squeeze the shackle twice and pull it out. This is in case you forgot to enter new combination.
2, Make the 2 combination together, the old and the new as one sequence. This in case you forgot to squeeze the shackle before enter new combination
Ity
Sep 06, 2011 | Office Equipment & Supplies
How can i change a tail light an a sorento kia 2008? I can t reach the connector inside..... What do i have to take off? Thank you
To Remove
1. Disconnect the negative (-) battery terminal.
2. Loose the 2 screws holding the rear combination lamp then disconnect the connector. And then remove the outside rear combination lamp assembly.
3. Remove the bulbs from the rear combination lamp assembly.
To Install
1. Connect the bulbs to the rear combination lamp assembly.
2. Connect the rear combination lamp connector.
3. Reassemble the rear combination lamp assembly.
Mar 24, 2011 | 2007 Kia Sorento LX 4x4
No power to moniter
This kind of problem needs an isolation. Please try the steps below:
1. Check the physical connection and make sure that the power cable is properly seated to the monitor.
2. Connect the monitor into different power outlet.
3. Try using different power cable.
Otherwise, you need to bring your monitor to the repair shop if none of the steps help.
Have a great day!
May 09, 2009 | HP L1702 17" LCD Monitor
How i change caracter's in game, marvel vs street fighter for psx? what are the corret pressing button for change the 2° caracter in game? thank you
For the main mode of this game, switching between characters is not an option, but you can switch between characters in crossover mode, however here are some interesting secrets involving this game.
Playstation only [edit] EX Options To enable EX Options, beat the game once. Then at the title screen, highlight Options, hold playstation-button-select.png, and press playstation-button-start.png.
[edit] Enable the Hidden Helpers To enable Shadow and Sentinel, simply beat the game once. They can be picked by moving to the bottom of the screen and pressing Down when highlighting Iceman or Colossus.
[edit] Play as Hidden Characters To enable a hidden character, simply beat the game with their counterpart. Then follow the instructions to select them.
Beat with Unlock Selection Venom High-Speed Venom Highlight Chun-Li and press Up. War Machine Hyper-Armor War Machine Highlight Zangief and press Up. Morrigan Lilith-Style Morrigan Highlight War Machine and press Down. Mega Man Roll Highlight Mega Man and press Right. Mega Man Magnetic Mega Man Highlight Mega Man, hold playstation-button-select.png, and pick him. Hulk MSH Performance Hulk Highlight Ryu and press Up. Chun-Li Shadow Lady Highlight Gambit and press Down. anybody Onslaught Highlight Wolverine and press Down. [edit] Fight the Hidden Character The requirements have been simplified a lot for the PSX version. Just do the following:
  • Don't lose a round.
  • Don't continue.
  • Don't have a second player join in.
  • Get the following special finishes during the last round:
Team Finishes MSH-Performance Hulk & Sentinel get 3 Hyper Combo, Variable Combination, or Variable Cross finishes. Lilith-Style Morrigan & Shadow get 4 Hyper Combo, Variable Combination, or Variable Cross finishes. Hyper-Armor War Machine & Sentinel get 5 Hyper Combo, Variable Combination, or Variable Cross finishes. Roll & Shadow get 2 Variable Cross finishes, and 3 Hyper Combo, Variable Combination, or Variable Cross finishes. High-Speed Venom & Sentinel get 3 Variable Cross finishes, and 3 Hyper Combo, Variable Combination, or Variable Cross finishes. Shadow Lady & Shadow get 4 Variable Cross finishes, and 2 Hyper Combo, Variable Combination, or Variable Cross finishes. [edit] Use the same character in a team Beat the game once, and you can do teams like Gambit + Gambit.
[edit] Start off in a different mode You can pick Ryu or Zangief and have them start off in their other modes by doing the following:
Mode Method Ken Mode Highlight Ryu, hold playstation-button-select.png, and pick him. Akuma Mode Highlight Ryu, hold playstation-button-start.png, and pick him. Mech Zangief Highlight Zangief, hold playstation-button-select.png, and pick him.
Apr 14, 2009 | Capcom Marvel Super Heroes vs. Street...
Minn Kota copilot remote settings
Pushing the speed increase and the speed decrease buttons on the remote at the same time sets the audio output mode to one of 3 modes.
Jul 19, 2008 | Minn Kota Boating
Speed Dialing
hold the number that you assigned untill you see the number of the person (hold about 2 sec) when the number shows up press talk botton
Oct 19, 2007 | Uniden TRU9485 Cordless Phone
Kenmore 24032\24036 Top Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
