Washer isnt spinning out does drain but not spinning at all
  • Washing Mach... Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Aug 29, 2010
Spin cycl isnt draining why
Good Morning friend, thanks for your post!
From my understanding your Electrolux washer is not draining. It could be the drain pump, motor, or control panel causing the problem with your washer not draining properly. I would schedule an appointment with a technician to come out and properly diagnosis your washer to avoid any unnecessary part purchases. -Matt
Oct 01, 2014 | Electrolux Washing Machines
Water not draining from washer. cannot open door. isnt there just a spin cycle i could go to instead of the entire wash cycle? i have already put it through 2 more cycles hoping the spin would drain...
Hi lauraeuschwa,
I believe your drain pump filter is just clogged. The drain pump is trying to pump the water out before the Spin cycle, but can't. Usually this is caused by a foreign object that is obstructing the impeller. See my tip on how to access, drain & clean the Drain Pump Filter:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
After this, the Spin cycle will run, after the drainage procedure. If it does not, then you may need to replace the Drain Motor. Which is a easy task.
Kind Regards :-)
* If this solution helped you, please rate it
Jul 18, 2011 | Kenmore HE2 Plus Front Load Washer
My washing machine isnt spinning or pumping water out? what could be the cause?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 08, 2010 | Hotpoint WF430 Front Load Washer
Washer will not drain water or spin
Check your drain pump motor. water isnt draining properly or not at all. It could be either something stuck in the piping (drainage), or the pump is not operating.once rectified, it should work properly again.
May 18, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine isnt' draining nor spinning.
1. Check the drain hose and make sure it is not plugged or kinked. 2. Unplug washer or disconnect power. 3. Check the electrical connections at the pump and make sure the pump is running. 4. Check the drain pump filter for foreign objects. 5. Plug in washer or reconnect power. 6. If the above does not correct the problem, go to step 7. 7. Unplug washer or disconnect power. 8. Replace the pump.
May 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What causes Cabrio washer to get unbalanced in spin cycle?
Try making sure that your draining hose isnt jammed all the way down the hole. When you installed it the u shaped accessory was needed for the draining hose. Try pulling the draining hose out...curve the front and zip tying it to your cold water valve. This will allow it to drain properly and not get water push back into the drum causing it to be unlevel
Aug 02, 2009 | Whirlpool WTW6200S Top Load Washer
I have a Kenmore 3.5 washer model # 44152. The washer is going through all the cycles but for the final spin it does not spin. Thus leaving the clothes sopping wet. What is wrong?
Is your pump clear? Nothing is in the pump blocking it? Does it drain ok? Check out your pump buy removing the bottom panel..Then check you drain hose where ever it is draining into, make sure drain isnt tp far into drain, or sink becausewater will syphen back into washer...try checking these simple checks first. i think your pump has a screw in type plastic cap. unscrew and check if you have anything in it and nothing is restricting the inpeller. spin the impeller with you finger make sure it spins around freely. you will feel some tension from the magnitation it is getting. but yeah, try these simple checks first and see what happens....
Jul 31, 2009 | Washing Machines
GE WSSH300G0WW will not drain
this means the machine isnt spinning fast enough, or the drains are clogged.
Apr 29, 2009 | GE WSXH208A Front Load Washer
Front end Washer not spinning
youll need to gain access to and clean out the drain pump assy, the most common issue is that the drain pump is clogged, cant drain water therefore cannot spin.
Dec 08, 2008 | Frigidaire ATF6000ES Front Load Washer
The washer isnt draining
fit, make sure the washer is going through the neutral drain before going into spin. Just around 90 seconds of drain right after agitation. If not, it's a gearcase problem covered under warranty for 5 years. Also I have found socks and things caught in the drain hose right where it exits the washer. This will prevent a full drain. Catriver..post back.
Oct 24, 2006 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
101 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
