Question about Haier ESA3055 5200 BTU Energy Star Qualified Air Conditioners ESA3055
I have a window unit haier 5200btu and for the first time all season it has collected water in the front and is now spiting it out into my home. i have it on a good tilt and i dont see why it would start to do this now. it is less then a summer old. i really just wanna know how to get the water out of the front so i can run my unit again. and im sure this isnt a good thing but we put our own drain holes in and they have been doing fine all summer.
    President:
  • 3,074 Answers
The drain is probably clogged since you put the holes in yourself I would take pipe cleaner or compressed air and see if this helps it drain. Hope this helps tim
Posted on Aug 29, 2010
  • Haier Master
  • 43,501 Answers
Check your drain holes again they must have plugged... but yes the newer units do have water sitting in them...
heatman101
Tip
If your Haeir window A/C unit is spitting water
I got this tip from this site yesterday when my Haeir A/C window unit began spitting water. Look for either a hole on the bottom edge of unit or a horizontal **** on bottom of unit it will either be in the front or back, take a toothpick or if your A/C is in a window unit and your target is on outside, take a long broom, bristle end up and brush out between window ledge and unit, any dirt that may have collected there. This will unclog the hole(s). You should also try to drain any water collected, out of unit. Turn A/C back on, it may do the same thing for about 15 minutes, but the problem should go away. Remember, you may not be actually able to see the hole or ****, but IT IS THERE. Make sure you brush it as thoroughly as you can. It worked for me. Thanks FixYa!!!
on Aug 07, 2008 | Haier HWR24VCB 23.6K RAC w/ remote Air...
I have a Haier dehumidifier, model DE45A-L and recently it has started leaking water and not collecting in the bucket. When we dump the water out it seems to just come from everywhere in the front. The...
There may have been a failure in the area where water is collected and directed to the bucket but also check to determine whether the bucket is reinstalling correctly after it has been emptied.
Sep 02, 2014 | Dehumidifiers
My dehumidifier is two years old and only used during the summer months. This season it is running but not removing moisture from the air...the collection bucket is completely dry. Help!
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jun 06, 2011 | Haier 45-Pint Dehumidifier
I own 2 Haier air conditioners. Same model number, purchased at the same time. Plugged them in yesterday and one is collecting water in the bottom and shuts off. The only way to get it to come back on is...
Condensation occurs when warm, humid air is pulled across a cold fins of an air conditioner and blown out the front as cool, dry air.
What is happening with your air conditioner sounds to be normal operation - here's why:
The condensate usually drips onto the ground from traditional window air conditioner units or through a pipe to the ground from remote air handlers of split systems. Since yours has no place to drain away into soil or waste pipe, it is collected in a compartment that must be emptied, just like a dehumidifier. When the compartment is full, the unit shuts off - otherwise the compartment would overflow on the the flooring or carpet. This could be a very expensive repair if hardwood floors were damaged or carpeting were to become moldy. Even more so if the the space under yours were finished - like an apartment building or if you used this on the second floor of your home - and damage to the ceiling below were damaged.
You could operate the device if it were connected by a hose to a drain at or below the bottom of the connection point (a floor drain, shower drain, etc.) or if the unit were placed on a counter top and allowed to drain into a sink or other drain / waste pipe below the the hose connection point. The hose must not get higher than the connection point at the drain plug on the air conditioner to work properly.
I hope this helps and good luck.
Apr 25, 2011 | Haier HPR10XC6 Portable Air Conditioner
My Haier spits water out the front of the unit it drips for long period of times of and on .
Take a level and place on top of unit front to back. Should be 1/4 bubble toward back.
Also purchase "Slime-Out" tablets to remove gunk.
Nov 05, 2010 | Haier ESA3125 Wall/Window Air Conditioner
My upright haier is leaking water
okay lets take the unit apart now lets clean the front an back coils even the bottom of the unit ,now lets pour bleach in the unit bottom base to prevent any sludge that could build up an create a blockage so every time ac season comes in treat the unit with the same method....
May 16, 2010 | Haier HWR12XCB Air conditioner
Haier dehumidifier will turn on but does not collect water.
hello. If your dehumidifier doesn't seem to run often but the humidity in the room is high, try adjusting the humidistat control on the dehumidifier to a dryer setting. If the dehumidifier seems to run constantly, but there's little or no water in the container, there may be a problem in the refrigeration system. Try cleaning the unit. If that doesn't work, you can't repair the refrigeration system yourself, you need a qualified appliance repair technician to do that.
Apr 14, 2010 | Haier HD656E Dehumidifier
Lg lwhd1200fr air conditioner is leaking water inside, best ideas on how to solve this problem?
REPOSITION UR WINDOW AC. RAISE FROM FRONT ABOUT 1/2 " SO WATER WILL DRAING DOWN TO CONDENSER OUTSIDE.
Sep 12, 2009 | LG LWHD1200FR Wall/Window Air Conditioner
PIECE OF JUNK
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Jul 29, 2009 | Haier HD656E Dehumidifier
Heating & Cooling Logo
95 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
