Manual for a Westinghouse LT959SA 9.5kg washing mashine
Washing mashine MW511 top loader was running good but this morning tried to start but it is making a beep beep tone and flashing lights
It is giving out a fault code,
Of the 8 wash progress lights, tell me witch are on,
I will tell you the fault code and info on how to fix.
Jan 29, 2012 | Fisher and Paykel Washing Machines
I just bought viscount washing mashine ez1000w without manual and i dont know how to operate it
Hello there I have the EZ1000W which is the hand washing program? I do not have the product manual . I have to wash a jacket of suit.
Nov 18, 2011 | Washing Machines
My new omega washing mashine shows an E2 error code 5 miniutes into the wash how do I fix this?
Manufactured by omega washing mashine have an electronic controlpanel that must be unlocked in order to set or make changes to your washingcycle.
E2 indicates a water leak. When a leak occurs, it trips thefloat device by dumping water into the dishwasher's base. The incoming watervalve will be switched off, and the drain pump will turn on until the sump isempty
However, if an error light is blinking on your dishwasher'scontrol panel, the panel must be reset before you can gain access. Blinkinglights on your washer control panel may signal a mechanical problem that needsto be repaired. If the lights continue to blink after you've reset the controlpanel, contact Sears to service omega washing mashine or considertroubleshooting the appliance yourself carefully.Instructions
1 Press and hold the "Heated Dry" button onyour omega washing mashine for four seconds to unlock the dishwasher controlpanel.
2 Press the "Heated Dry," "Normal Wash,""Heated Dry" and "Normal Wash" buttons one after theother, in fairly quick succession.
3 Wait for the washer to run a short diagnostic test.
4 Press the "Cancel/Drain" button at the endof the diagnostic test cycle. This should reset the control panel on your omegawashing mashine. Thankfor using fixya.
Jul 30, 2011 | Washing Machines
I have a hot point washin mashine that does not finish a wash and stopes half way through then lights at front of mashine start flashin
Had this with mine. Cleaned the filter (as decribed elsewhere on this site). Also cleaned the component fto which the drain hose attaches - guess this is the pump. Just unclip the drain hose and the hose going into this pump, and check there is nothing obstructing the pump. The clips are a bit of a fiddle, you might want 2 jubilee clips to replace them. Then ran a "maintenance wash" as per manual (ie a hot wash, no clothes, no detergent). Seems OK now
Nov 02, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Model no wa80b3 samsung washing mashine
My washing machine is Samsung Top loading Model WA80B3, the problem is that the water inlet valve is continuously working all the time during the washing cycle and it does not stop automatically, so I have to run additional drying cycle after washing cycle and after closing the water supply manually
May 02, 2009 | Washing Machines
Westinghouse heavy duty washer
Check this website out. It has a good questions and answers section. I would guess that it is the water inlet valve in the washer, but it could be a few different things.
http://www.repairclinic.com/0088_11_1.asp
I know of a different site that has good prices on parts. I have ordered from them numerous times. Let me know if you need that link.
Oct 03, 2008 | Westinghouse WWS833ES Super Capacity Top...
Washing mashine repair
Plug off the wall. Clean out your outlet filter. Access is a door in the front bottom of your machine, be prepared for some water to come out. Refit.
Sep 17, 2007 | Washing Machines
Washing Machines Logo
61 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
