Question about E-Machines eMachines Desktop PC
Power up replaced power supply, still won't power up. possible motherboard?
    Novelist:
  • 150 Answers
Does this mean no power at all, or just that the computer won't
post.
Do any of the fans spin ?
Do the hard drives spin up and make noises?
Do any lights come on?
Is the cord OK?
Is the rear power switch in the ON position?
Is the rear voltage selector switch set correctly?
Is the new power supply good?
(don't assume it is)
Now
Perform all changes with power off and cord unplugged (!!!)
Leave a minute or so after power down, to make sure
all the capacitors have discharged.
Touch and Hold the metal chassis with one hand to make
sure you have no static electricity, while handling cables
and I/O cards.
1) Check and wiggle all cables and I/O cards.
Remove and re-insert the I/O cards carefully
Remove and re-insert the memory modules carefully
2) Remove all I/O cards except the video graphics card
Does it power up and post now?
Remove extra memory modules, try just minimum RAM
3) Remove the Video card and see if you get any sign of
activity:
Error beeps, fans spinning up, hard drives clicking
and whiring, etc.
Possible causes, with increasing degrees if repair expense:
a) Bad power supply.
b) Bad mother board connection to the power supply or
to the front panel switches.
Check the little ribbon cables.
c) Bad front panel switches.
d) Bad video card, video card shorting the I/O bus
e) Bad memory module, memory module shorting the I/O bus
f) Bad CPU
g) Bad mother board and/or chipset.
On modern mother boards, power supply control and
fan speed control are both integrated into the mother board
and chipsets. Power switch behavior can also be controlled
by the BIOS settings. This means you have to take many steps
to isolate the problem.
Hope this gets you started.
Martin.
Posted on May 08, 2008
Pull everthing off board but power supply ram cpu and heatsink. then try to power unit.
P8P67 EVO Won't Boot with power to board
This is almost always the power supply. How exactly did you "check the power supply"? You checked all 12 or so voltage outs under load?
If replacing the power supply doesn't work, replace the motherboard.
Dec 24, 2012 | ASUS P8P67 EVO LGA 1155 Intel P67 SATA...
Asus laptop won't power on
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Dec 21, 2012 | Computers & Internet
Dell vostro a840 won't start
Possible causes:
1.Dell Vostro A840 AC adapter failure.
Dec 18, 2012 | Dell Computers & Internet
Acer 4320 won't power up
Possible causes:
1. Test your acer travelmate 4320 ac adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
Dec 12, 2012 | Acer TravelMate 4320 Notebook
My laptop won't startup
Possible causes:
Hope you just need to replace the hp power supply to fix this problem.
Dec 11, 2012 | HP Computers & Internet
Computer shouts down in 15 to 20 seconds after starting
The specs say the PSU is ATX compatible. Whether that is for the connector only or for the whole power supply is something you will have to determine.
If you have an ATX power supply handy (like in an old computer) give it a try. This one is only 300 Watts so it won't likely be expensive to replace.
Have a look at: http://www.techspot.com/community/topics/dell-dimension-1100-shuts-down-after-20-seconds.135987/
Aug 28, 2012 | Dell POWER SUPPLY Power Supply
Acer ax1301 won't power on
It's very possible that when your power supply died so did your motherboard. Especially if a power surge was involved..
Aug 18, 2012 | Acer America Acer Aspire AX1301-U9032...
Is there a way to increase the factory maximum ram of 512mb on a Sony PCV RX550. Purchasing motherboard, etc.
The only way to increase memory capacity on any motherboard is by replacing it with a new one that can take more. Rather than do that in your Sony computer, though, you should probably consider replacing the entire computer. Here's why.
First, you may not be able to fit a different motherboard into the Sony case. Many computers were made using proprietary motherboards with non-standard sizes or mounting hole locations. Then, they often have non-standard connectors for the front panel switches and lights, making it difficult to hook up. The power supply will be a problem. Guaranteed it will be too low-power for newer motherboards and won't have the right CPU power output connector, so you'd need to replace that as well. But a standard power supply may not fit into the case; again, proprietary power supplies with odd sizes were often used. So now you're looking at replacing the motherboard and power supply, and possibly the case, just for starters.
You'll need a new processor and RAM with the new motherboard. No new board will support your current processor and RAM. And you'll need a new hard drive and probably optical drive as well. New boards are designed for SATA (serial interface) drives. There won't be enough connectors to re-use the older IDE devices in your Sony.
You'll probably need a new copy of WIndows, too, unless your Sony still has an XP or Vista product key sticker on it. You won't be able to use any factory restore discs because the hardware will be completely different, so you'll be doing a fresh installation from scratch.
The bottom line is that you're going to end up building a new computer. If you just want a basic computer for the typical things like Web surfing and office use, you can buy a name-brand system for less than the price of all the parts, and it will come with Windows installed and will be ready to go. If you're wanting a super gaming machine or something tailored for a specific use, and you're willing to do the work, then by all means pick up the individual parts and roll your own.
Jul 17, 2011 | Sony VAIO Digital Studio PCV-RX550 PC...
Dell Dimension 2400 won't power up?
It is possible that you may have a bad power supply and need to have it replaced, it could also be something simple such a a loose connection on your motherboard. I would start out by removing the power supply from the machine and having it tested at a computer shop. Also make sure everything is plugged in correctly on the hardware. Let me know if this helps please, Jeff from fixya
Jun 15, 2011 | Dell Dimension 2400 PC Desktop
Computer will not turn on. Possible power surge.
If the power supply is good then your motherboard must have gone bad during a surge.
Dec 26, 2009 | Intel D865PERL Motherboard
E-Machines eMachines Desktop PC Logo
150 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
