Question about Microwave Ovens
I have a single handle blanco faucet. i removed the hex screw, but handle will not come off. is it stuck or is there something else to remove? Thank you, Bruce Eige (fishguy69@att.net
  • Microwave Ovens Master
  • 43,501 Answers
No the handles will sieze on there with time... the minerl deposits from the water will weld them right fast...
Tap it with a light hammer and work it to get it to loosen...but I have broke many tring to get them loose...
heatman101
Posted on Aug 29, 2010
I tried to remove the door handle by removing the inside cover and then removing the two screws holding the handle in. But I can't get the handle to release. When I try to pull it off the door there...
There may be more screws or you may need to rotate or lift the handle.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find handy exploded views and order parts by model number here.
Jun 19, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a moen 7637 single handle kitchen faucet that leaks around the stem. How do I take the lever off.
1) Use a small sharp-pointed knife and pop out the little plastic Moen logo at the bottom of the front side of the handle (and don't lose it!)
2) Lift the lever up a bit (the water may turn on) until you can see a small screw with an allen wrench socket.
3) Unscrew the allen-head screw; the handle will lift straight up.
Look down into the faucet; there's a philllips head screw. The leaking may simply be caused by this screw being loose.
May 01, 2011 | Microwave Ovens
Have just installed glacier bay faucet model #8181/ 785 564 single handle with pull-out sprayer. once pulled out the sprayer will not re-seat into the faucet but hangs out about an inch or two. have...
Take it back to HD or Lowes where you got it and trade it in for a Delta....you will be glad you did... this is only the beginning of your problems....you get what you pay for...
heatman101
Apr 21, 2011 | Microwave Ovens
I have a price pfister kitchen tap and it doesn' have a cap. how do i get the handle off to replace the cartridge
If this is the single-handle faucet I remember, there's a decorative hot/cold indicator on the front, a small half red/half blue circle. This pops out of the handle to reveal the retaining screw underneath. It's a hex-key (Allen key) screw but I don't remember the size. Once you've loosened the screw you'll be able to lift the handle off the faucet body to get at the cartridge housing.
Apr 03, 2011 | Microwave Ovens
We have a steadily dripping tap. Can you please help? thank you.
You don't say anything about what kind of faucet you have, so this may not apply. But if yours is the kind with handles you turn to control the water, you probably have worn-out compression washers. In this kind of faucet, water is shut off by pressing a rubber washer on the end of a threaded stem against an opening in the faucet body. When you turn the handle, you move the washer away from its seat and the water can flow. Over time the washer gets worn and no longer seals off the water. Also, the valve seat the washer presses against can wear and allow water to sneak past the seal. The result is that annoying drip or a steady trickle.
This site, among many others, shows how to change a washer and fix most drippy faucets. If you search for "repair a leaky faucet" you'll find lots of sites to pick from, including many with videos. If you faucet is not a compression type, a single-lever cartridge for instance, there are links to other repair procedures.
If your faucet is old and the parts very badly corroded and worn, you might want to fix the leak by replacing the entire stem as a unit. You can find replacement stems for most brands of faucet at big-box home improvement stores and at many hardware store. It's a little more expensive, but often much easier to unscrew the old one and pop in the new than to start trying to get the old washer off the stem.
A last tip: Whenever you do any work on a faucet, remove the aerator from the spout and run the water to help clear the line. If you just turn the water back on and run the faucet, debris that was kicked up during the repair can clog the aerator screen. Then you're left wondering why you get only a weak trickle or no water at all after you fixed the trouble.
Mar 10, 2011 | Microwave Ovens
GE Spacemaker microwave model JVM130J - handle loose
Yes, you're right about the screws. The inner door is held by clips. Just pop it out using a butter knife or something similar. You might need to remove the door from hinges first (It's been too long after I repaired one of these, so I don't remember exactly).
Oct 14, 2009 | Microwave Ovens
Sharp R1514 - handle is stuck "in"
The mechanism has failed. simply replacing this handle(push) mech will fix this issue.
Jun 03, 2009 | Sharp R-1514 Microwave Oven
Need to Replace Door Handle for KitchenAid Over Range Microwave Hood Combo KHMS147KSS
Check out this door frame diagram, specifically number 1805. It clips on to the door frame. Remove it using a dull table knife or something similar (be careful not to scratch or break anything). You will then have access to the bottom screw.
Mar 18, 2008 | GE Advantium SCA1000H Convection /...
Microwave Ovens Logo
160 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
