Question about Refrigerators
How do I change a thermostat in my hoover nextra fridge freezer
  • 4 Answers
SOURCE: Nextra Hoover Fridge Freezer, Fridge not cold enough.
I would turn the thermostat up towards number 4.
Posted on Dec 12, 2007
garing
  • 998 Answers
SOURCE: freezer stopped working
Pour about 1/2 cup of water into ice maker . If it dumps the cubes , then replace the water valve . If it doesn't , replace the ice maker . Also make sure the refrig coils are clean and free of dust , lint , pet hair , etc....
Posted on Aug 12, 2009
SOURCE: Hoover Fridge Freezer thermostat (model HFA290)
Try www.fridgeshop.net and look at "Candy Hoover Problem"
Posted on Nov 28, 2009
toolkits
  • 1099 Answers
SOURCE: freezer getting cold but not freezing food
..I'm not certain here but there are a couple of things we can look at and diagnose. First, be sure that your doors close tightly. If the gaskets leak, this will allow humidity in...that's where ice comes from. If you 'windowshop', this will also cause icing. Now...let's start with a full defrost. This can take about two days with the unit open and off. Once accomplished, the next thing to do is look at the unit itself. First, underneath, is the condenser coil clean? If not, do that. Now, from the back, remove the felt panel covering the lower portion. The big thing is the compressor. If the unit has been off for more than 20 minutes, clean the big pipe off. Now, start the unit. It should develop frost on the pipe which should either freeze up or dry out after 5 minutes or so. Caution: there is a fan in there! If still frosty, you're low on gas and the unit probably has a small leak. The icemaker can be looked at by removing it. It contains a float. If the float is damaged or jammed, it will not shut off...and will overfill the icemaker. Good luck.
Posted on Jul 28, 2010
  • 330 Answers
SOURCE: my hoover a class nextra fridge freezer is not
sounds like a gas leak.
Posted on Jan 11, 2011
I require a wiring diagram for the thermostat of a Hoover nextra HMA 280B fridge freezer on
Not sure about this model but most thermostats have only 3 terminals... 2 live terminals and 1 earth.. The earth is usually the terminal on the main outside frame or body of the thermostat. There is usually a wire from active or the + side of the main terminal block or supply cord. The other terminal usually goes to the compressor. Basically, a thermostat turns the compressor on and off to maintain the temperature in the fridge its just an on / off switch..
Aug 04, 2011 | Hoover Refrigerators
My Hoover Nextra fridge freezer is 9 years old in perfect condition. Fridge has stopped cooling but freezer is working ok. I have turned up temp control to super, motor is warm but silent. What could have...
Hi, I have a Hoover Nextra Fridge Freezer and last night it tripped all my electric. When I plugged it back in, it sounds like it is starting, but then after a couple of seconds clicks off again. Any ideas?
Dec 26, 2010 | Refrigerators
My fridge section of the hoover nextra keeps freezing?
maybe the thermostat control is defective
Jun 17, 2010 | Freezers
Freezer stopped working
Aug 12, 2009 | Refrigerators
Refrigerators Logo
214 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
