Question about Craftsman Garden
13hp i/c gold engine won't start, no spark..do you think it's coil pack??
  • 43,501 Answers
Maybe but did you check the kill switches for the mower deck and the seat switch???
heatman101
Posted on Aug 29, 2010
Honda engine 13hp no spark on plug
Start by changing plug. Make sure to ground plug to engine when testing for spark. After go after cable. If resistance is on you'll need to check magneto or coils
Dec 16, 2015 | 13 HP Engine GX390 OHV Horizontal Shaft
Tip
Car That Turns Over But Won't Start problem?
There are many possibilities for this problem. But are some are very common for this problem.
1) Check out there is enough gas in your car.
2) Check the charge of the battery. It should be exact 12 volts. if the charge is low the engine will crank but won’t start.
3) Get it confirmed that there is fuel in car and fuel pump is also turning on
4) To check whether fuel pump is turning on or not try this procedure.Insert the key in the ignition, then turn the key to the ON position, and listen carefully from the back seat side you will here an electric noise for about 1 second every time you cycle the key on/off. If you hear nothing then your fuel pump is faulty or not receiving any power. In this case the fuel pump needs replacement.
5)But if fuels pump check out ok.then continues towards engine for finding fault. Check where engine is receiving the gas. Many times clogged fuel filter or blocked fuel injectors don’t let gas to flow towards the engine.
6) If the gas flow is proper towards the engine. Then route towards the spark plugs.
7)Check whether you get spark while you crack the engine. if no spark then it’s the problem in the spark plugs.
8) The spark plugs receive power from coil pack. If the coil pack is having proper voltage the fault in spark plugs is confirmed. But if the coils pack has low voltage then its time to replace the coil pack.
This will help. Thanks.
on Mar 16, 2010 | Chrysler Town & Country Cars & Trucks
Car turns over but won't start
Which engine?
I would first check the following:
Are you getting spark at the spark plugs? If not, check the ignition coil or coil pack.
Are you getting fuel to the engine? Make sure there is fuel in the tank, and that the fuel pump is working.
Check all your fuses to make sure they are OK. A blown fuse to any critical engine component (ECM, ignition, fuel supply) will prevent a vehicle from starting or running.
Feb 13, 2012 | 1997 Ford Escort
My 1996 ford taurus sho wont start, it will turn over but not start what could be wrong?
Hello and welcome to FixYa!
Looks like that there's no current flowing that's why it won't fire up. I strongly suggest that you check and replace the coil pack if necessary. If the coil pack is faulty there will be no current to the plugs. One good reason why it won't fire up.
Hope this helps and thank you for using FixYa! Have a good one!
Apr 25, 2011 | 1996 Ford Taurus
Fireing order
the firing order is 123456 pretty easy, but i think what you want is spark plug location on the coil packs, so lets start with cylinder placement. starting at the front of the engine the end with the belt the three cylinders closest to the radiator are 2 4 6 the cylinders at the back of the engine are 1 3 5 the spark plug wire location is from the front of the coil pack( fount of engine ) 1 4 6 3 2 5......HAVE FUN
Dec 13, 2010 | 2000 Pontiac Montana
2005 chevy silverado won;t start.
i had the same problem, and it turned out the coil pack was moulding inside wich stopped the spark all together, i ended up changing my coil pack and putting on new wires because the ends connected to the coil were very corroded and that cures the not running part just fine
enjoy
Jul 01, 2009 | 2003 Chevrolet Silverado 2500HD
Garden Logo
70 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
