Question about Rv Motorhome Dual Co & Lp Gas Alarm Detector
I have a safari kalahari 1994 motorhome and i need help installing the batteries. there are 3 batterries 4 large cables and 2 bridges. any pic of a proper installation out there?
  • 6,674 Answers
Scroll down the page at this link, it should help. Just be sure whether you have 12 volt batteries or 6 volt.
http://www.marxrv.com/12volt/12volt.htm
Posted on Aug 30, 2010
Need info on how to change a 2000 Cadillac
REMOVAL PROCEDURE
TOOLS REQUIRED
A J 34730-1A Fuel Pressure Gauge
A J 39765 Fuel Sender Lock Nut Wrench
CAUTION: Refer to Batterry- Disconnect Caution in Service Precautions.
1. Disconnect the negative battery cable.
2. Relieve the fuel system pressure. Refer to the Fuel Pressure Relief Procedure. See:
Fuel Delivery and Air Induction/Fuel Filter/Fuel Pressure Release/Service and
Repair
3. Drain the fuel tank. Refer to Fuel Tank Draining Procedure. See: Fuel Delivery and
Air Induction/Fuel Tank/Service and Repair/Procedures
4. Remove the fuel tank.
5. Remove the fuel sender assembly.
6. Disconnect the fuel pump electrical connector (5).
7. Remove the fuel level sensor electrical connector retaining clip (6).
8. Disconnect the fuel level sensor electrical connector (7) from under the fuel sender
cover.
9. Remove the fuel level sensor retaining clip (4).
10. Squeeze the locking fangs and remove the fuel level sensor (3).
INSTALLATION PROCEDURE
1. Install the fuel level sensor (3).
2. Install the fuel level sensor retaining clip (4).
3. Connect the fuel level s ens oi electrical connector (7).
4. Connect the fuel level sensor electrical connector retaining clip (6).
5. Connect the fuel pump electrical connector (5).
6. Install the fuel sender assembly.
7. Install the fuel tank.
8. Refill the fuel tank.
9. Install the fuel filler cap.
10. Connect the negative battery cable.
11. Inspect for leaks.
11.1. Turn ON the ignition for 2 seconds.
11.2. Turn OFF the ignition for 10 seconds.
11.3. Turn ON the ignition.
Aug 29, 2014 | Cars & Trucks
1994 Olds Cutlass Ciera starter issues
You should have two or three wires that go to the large post on the solenoid, including the 4 gauge wire from the battery. Then one 16 gauge wire to the small post. That wire comes from the key switch.
Let me know if you need colors for wires.
Mar 01, 2013 | 1994 Oldsmobile Cutlass Ciera
What's your problem?1995 gmc safari alternator replacement. Need some kind of diagramed overview of the alternator and how it connects, what it looks like, how to do it basically
Hello! First see Serpentine Belt configuration diagram below... Alternator is part "C"...
If you have a voltmeter...read across the battery with engine off...Record...Start engine read again...Voltage must be 1.8 -2 volts higher; This means Alternator is working...
To Remove:disconnect (-) battery cable...Air Inlet Duct...Serpentine Belt (idler pulley maintains tension)...Heater hose brace...Wiring from Alternator...Mounting bolts...Remove alternator...
To Install: Install Alternator loosely...Tighten Rear Bolt to 37 ft. lbs...Front bolt to 18ft. lbsTighten Brace to Intake to 18ft lbs....Connect wiring...Install belt...Adjust Idler Pulley so belt moves less than 3/4" when tight...Connect (-) battery cable....Re-test as noted above...Guru...........Saaile
Sep 26, 2011 | Cars & Trucks
I need to reinstall Safari for XP. I deleted (uninstalled Safari this morning and now need to reinstall it.
To Download Safari:
1) Go to http://www.apple.com/safari/
2) Click "Safari 5 Free Download"
3) Uncheck the checkbox labeled "Keep me up to date... etc."
4) Be sure the button labeled "Safari 5.0.4 for Windows XP, Vista or 7" is selected
5) Click the blue button labeled "Download Now"
6) On the popup window, click the button labeled "Save"
7) Navigate to your desktop in the new window and click "Save" once more
To Install Safari:
1) Double click the icon which reads "SafariSetup.exe" on your desktop
2) Windows XP MAY ask if you're sure you wish to run this program depending on your security settings. If you see this popup, click "Yes" or "Run".
3) Click "Next"
4) Click the button labeled "I accept the terms in the license agreement"
5) Click "Next"
6) Uncheck the checkbox labeled "Install Bonjour for Windows" unless you are absolutely sure you need this additional program.
7) Click "Install"
8) Click "Finish"
Safari is now installed on your machine. Keep in mind that deleting an icon from your desktop does not uninstall a program. If you accidentally delete your desktop icon, this can easily be replaced through the start menu.
Apr 07, 2011 | Computers & Internet
Replacing the speakers on a 2000 gmc safari van what size are they? back speakers in the doors.
6-3/4 inches. you can replace with sizes down to 5-1/2 with proper mounting hardware.
May 28, 2010 | 1994 GMC Safari
How do I replace a water pump on a 1994 buick park ave
Removal
1. Support the vehicle on jack stands.
2. Disconnect the negative battery cable.
3. Drain the cooling system.
4. Remove water pump drive belt.
5. Disconnect the coolant hoses at the water pump.
6. Remove the water pump pulley bolts (long bolt removed through the access hole provided in
the body side rail), then remove the pulley.
7. Remove the torque axis mount. See TORQUE AXIS ENGINE MOUNT .
8. Remove the water pump attaching bolts and pump.
9. Clean all gasket mating surfaces.
Installation
1. Using a new gasket, install the water pump on the engine. Tighten the bolts to
specifications. See TORQUE SPECIFICATIONS .
2. Install the torque axis mount. See TORQUE AXIS ENGINE MOUNT .
3. Install the water pump pulley, then tighten the bolts to specifications. See TORQUE
SPECIFICATIONS .
4. Connect the coolant hoses onto the pump.
5. Install the water pump drive belt.
6. Fill the cooling system.
7. Add coolant supplement tablets.
8. Connect the battery cable, then start the engine.
9. Inspect for coolant leaks.
Jan 13, 2010 | 1994 Buick Park Avenue
I need shome where spark
You need be more specific...
- Firing Order...
2.5L Engine-NL-> Firing Order: 1-3-4-2-NL-> Distributor Rotation: Clockwise
4.3L Engine, non-HVS -NL-> FiringOrder:1-6-5-4-3-2-NL-> DistributorRotation: Clockwise
- Spark Plug Type...
Champion Part Number 7018 GAP 0.45"
Hope helped. Good luck (remember rated this help).
Nov 13, 2009 | 1994 GMC Safari
Legend Amp hook up manual.
Pretty Straight Forward get a 8 or 4 gauge amp wiring kit.
Run your hot wire to the +12V from the battery make sure to install the supplied inline fuse near the battery don't connect to the battery until installation is complete.
Run the REM to your stereo power ant. Wire. if available.
Run the GND to Metal Chassis Ground keep it as short as possible.
Run the RCA Cable from the back of the Stereo to the RCA Inputs or Low Level on the amp.
This amp is 2 Ohm Stereo Stable which means you can connect 2 (4 ohm) speakers in parallel to each channel or 1 (4 ohm) speaker on each channel or you can connect 1 (4 ohm) Speaker in bridged mode.
There are other speaker configurations you could use but you cannot drop the load below 2 Ohm in stereo mode and no lower than 4 ohm in bridged mode.
Hope this helps
Mar 25, 2009 | Legend LA1490 - American Legacy Series 2 -...
1994 Chevy Silverado
d2f5142.gifi hope this is what you are looking for
good luck
paul
Nov 17, 2008 | Chevrolet Silverado 1500 Cars & Trucks
Bridgeable vs not bridgeable
All amplifiers are bridgeable. The bridge setting is for driving a large speaker by using the power output of 2 or more channels. The power will be summed if a bridge is made.
For example, if you have a 800W, 4 channel power stage, you can connect 2 component speakers in the channels 1 and 2 and bridge the channel 3 with the 4 to drive a subwoofer.
Feb 14, 2008 | Car Audio & Video
Rv Motorhome  Dual Co & Lp Gas Alarm Detector Logo
306 people viewed this question
Top Camper Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
Mike
Are you a Camper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
