Question about Frigidaire 20.6 cu. ft. / 583 liter Upright Freezer FFU2124D
I have a Frigidate upright frost free freezer and have noticed water coming out from underneath the unit. What is causing this to happen...food is still frozen
  • Frigidaire Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 29, 2010
Frigidaire frost free upright freezer door corner dripping
Hello Yellow, thank you for your post!
I understand that your Frigidaire freezer is dripping water out of the corner of the door. It is possible that with your power going out the heat may have caused the gasket to warp. Do you see any frost build-up? The water that is dripping could be coming from condensation within the freezer. I would recommend checking the gasket to see if it is allowing warm air to enter the freezer.
I recommend that you visually inspect the door gasket for defects such as gaps or tears. You can also use a dollar bill to test the door gasket. Place a dollar bill in between the door and the body of the freezer. If the dollar bill pulls out with no to little resistance, you may need to replace the door gasket. A faulty door gasket can allow warm air to enter the compartment and cause frost to condensation or a leak. I hope this information is helpful. -Matt
Sep 01, 2015 | Frigidaire 13.7 cu. ft. / 388 liter...
Our Frigidaire frost frost free upright freezer from day one has frost build up on the food inside the packages. The frost is not a problem in the freezer itself, but on the food. Freezer burn occur
Hi Dale Dibb, thank you for your inquiry!
I understand that the food inside of your Frigidaire freezer is getting frost on the inside of the packages. I would recommend turning the temperature up inside of your freezer. Additionally moisture inside of the package would cause frost to develop on the inside of the food packages.
Please assure that all possible moisture has been removed out of the food packages prior to placing the items inside of the freezer. If there is anything else that I can help you with, please feel free to reconnect! -Matt
Sep 30, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Ffu20fc4cwo won't freeze food
Check power to and from the thermostat first
Sep 13, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My upright freezer freezes everything fine my only pro.blem is that it builds up ice/frost on the ceiling of the freezer first and then works its way down i have taken everything out,started fresh and...
Since you didn't give a model number, I don't know if it is frost free or not. If it is, then you have a problem with you defrost system: defrost heater, thermostat or defrost timer.
It also sounds like your door seal is not making solid contact and most air is leaking into the freezer.
If your unit is a frost free, then water should drain down and out.
Jun 24, 2011 | Freezers
My Frigidaire upright freezer is only 4 years old & isn't working
freezers have safety devices to protect themselves. The compressor has an internal overload to keep it from overheating. some have external reset buttons and some do not. either way the cause must be corrected. if the freezer was low on refrigerant you would see signs of oil near the coils, tubing, or compressor. If there is no leak, it overheats when there is airflow restrictions(dirty coils) or a fan has stopped working. only a few screws keep you from seeing all there is to see. If it is clean and the fan is running, then the compressor may just be the culprit
Nov 24, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
I have a frigidaire freezer upright model#ffu20f9gw3
Without any additional info, there are a lot of possibilities:
1. Condenser coil (underneath unit) is dirty and clogged.
2. Compressor is failing. (need A/C tech)
3. Metering device is clogged. (need A/C tech)
4. Refrigerant charge is low. (need A/C tech)
5. Door seal is broken (frost will form around door).
6. Defrost heaters are stuck on (replace defrost timer located underneath unit at front).
7. Condenser fan has failed (underneath freezer on back).
8. Evaporator fan (inside fan) has failed (ice will form on cooling coil).
This should get you started...
If this helps you, please select YES to the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
Ice build-up
Defected DEFROST HEATER can cause frost build up on the panel at the back of the freezer,and freezer stop cooling and ice frozen on unit so air could not flow to refrigerator side.Water will coming out caused of unbalanced freezing,and causing the flooding of water in the floor. You must change this defroster heater assembly so it will works normal again..
Hope this may help;
Regards,
VOTIT
Sep 22, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Defrosting???
your food should not thaw in a frost free freezer. but I can not tell you why it is thawing, sorry.
Apr 25, 2008 | Frigidaire 13.7 cu. ft. Upright Freezer...
Temp alarm going off
What is the temp in the freezer, sounds like temp is to low..no water should be coming out of freezer, sounds like may be defrosting Need to check the temp to make sure its cold enough.. thats what that alarm is for
Aug 10, 2007 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Ice build up in my frost free upright freezer
I looked at the BACK at the bottom underneath of my Sears Kenmore frost free upright freezer and what was causing the ice buildup was very simple. At the factory, the assembler looped the little hose too high and when the water went into the hose it could not get out due to being too high in one spot! An ice dam will form, blocking ALL water coming through
and freezing up any more water coming down giving you a HUGE wad of ice that is scary!!! I just removed the screw holding the loop that holds the hose and put a bit of warm water down the little hole on the INSIDE (Behind the grate) to melt the remaining ice in the tube.You need to take out 4 screws and remove the grate to see this. I could not believe that this was the problem! I haven't had any ice build up since.Now don't tear your freezer apart before you try this trying to fix the compressor, thermostat etc. It may be the only thing wrong with it!
Nov 11, 2006 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Frigidaire 20.6 cu. ft. / 583 liter Upright Freezer FFU2124D Logo
158 people viewed this question
Top Frigidaire Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
