Question about Crosley CDE6000 Electric Dryer
Just Stopped Working
I had opened the dryer to see if the towels were dry and not it wont turn back on...its model number is CDE6505W it is a crosley
  • atwood6245 Jan 17, 2009
    Put clothes in dryer still wet. Checked wires, all connections still have the same problem
  • Crosley Master
  • 8,220 Answers
Use a putty knife and press against those spring clips holding down the top.Just Stopped Working - f23fbc9.jpg
Check the door switch for continuity. Let me know.
Posted on Jan 13, 2009
My crosley dryer (model# CED137SXQ0)made a loud ugly noise and stopped working i tried turning back on but it doesnt come on or make any noise.
check to see if the drive belt is broken. check out this video:
Aug 04, 2015 | Crosley Dryers
Sometimes my dryer will shut off 5 min after I start it then when I try to turn on again notheing I have to wait for a minute then it will let me turn on. Then sometimes it will shut off maybe 15 or 20...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
Dec 30, 2010 | Crosley Dryers
Crosley Model #CDE22B7V. Clothes dryer only gets
I used to work for a Crosley dealership. The number one problem is gonna be the blower wheel.709b43d.jpggo ahead and pop the top(after unplugging the machine) f11ef2b.jpgGet the front off and then get the drum out. Clean out all the lint. 31001043 is the part number
Apr 01, 2010 | Crosley Dryers
Crosley Dryer Model CEDX463RQ1 no heat
take elements to a dealer and have them checked, unless you have a digital multimeter and can DIY.Otherwise get a replacement element
Aug 01, 2009 | Dryers
Crosley heavy duty giant capacity plus auto dry control wont dry
Get putty knife and start by popping the top then take the front off and check the heater mounted on the rear bulkhead.
Jan 05, 2009 | Crosley CDE6000 Electric Dryer
CDE6000W, Crosley dryer stopped working in middle of load
it could just be the motor going out some dryers only last 6-8 yrs some dryers continue to be quite even if there going out i suggest call a repair preson to see if repairing it is worth it
Here To Help
Nov 17, 2008 | Crosley CDE6000 Electric Dryer
I for got what cables go where in my crosley dryer i have a cde6505w model i change d\the harnes and i for got how the wires go and where they go can u please help me out
look closely at the sockets, they design them not to be interchangeable. so one by one you can insert them hopefully you can put them all together.
tnx 4 using fixya..
Aug 07, 2008 | Crosley Dryers
You really need a volt / ohm meter to check for Continuity & Volts
Its well worth the investment... $15.00 bucks give or take a few
I would check to see if you have 220v to back of dryer where the cord mounts to dryer,
If dryer is getting only 1 leg 110 volts instead of the 220 will it not heat.
Check themostates & heater for Continuity... Most models, Now have a..
Hi-limit fuse that need to be checked for Continuity and replaced if bad
Oct 11, 2007 | Crosley CDE6000 Electric Dryer
Jesse, does the door light come on? If not check the thermal fuse. You will have to open the top by pushing in on the two clips on each side. In back, on the right side of the heater you will see a thermostat and about 4 inches below the thermal fuse. Look at number 5 in the attachment. Makes sure to kill the power before going back there. You can either jump it out or ohm it out to make sure that is the problem. Part number for the fuse is LA1053.. back
Mar 11, 2007 | Crosley CEDC392JQ Electric Portable Dryer
Crosley CDE6000 Electric Dryer Logo
118 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
