Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
Issues with replacing Ballast
I own a Samsung HL-R4667 DLP TV. One day the picture went out on the tv, sound was still present, and the lamp and temp lights blinked on the front. After trying to replace the lamp, and the tv still exhibiting the same symtoms, I replaced the ballast. After replacing the ballast, the lights are still blinking on the front of the tv and no picture is showing up. However, the lamp is now turning on in the back of the tv.
At this point, I am uncertain as to what to do to my tv to get it to work again. Is there a reset process I need to follow? Someone mentioned that the main board may need to be reset. Does anyone know how to do this or have experience with this? Should I try to purchase a samsung repair manual?
Thanks for any advice or assistance.
I have
  • Ed Izworski
    Ed Izworski Oct 09, 2008
    I had paused the program on directv about 15 min. later I went to play and the tv would not do any thing I turned it off and the botton red lights stay on.
    When I start it I have sound but no picture,but ther is light in the back. Also the screen trys to go white but settles down to a datk gray.
  • 4,234 Answers
The flash code indicates that the lamp cover is not installed correctly. There are safety switches built into the housing that require the cover be installed correctly for the set to work. If the cover is actually in place correctly, there may be a broken switch. Check for this and update this if you can not resolve the problem.
Dan
Posted on May 08, 2008
Samsung DLP turns on and off - cycle repeats
make sure put the lamp door back before trying to turn it on because they have switches on them that allow the tv to turn on. If that is ok you probably have a bad ballast.
Call a local tv repair shop to further diagnose the problem.
Dec 10, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLP TV, no picture, has sound
Try replacing the ballast next. Its the small circuit board directly underneath the lamp housing. You can access it through the lamp door. If the ballast is overheating or has a leaking capacitor, the tv won't stay lit for more than a minute or two.
Mar 12, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
I have some proble dlp tv I put new lamp;put the problem didnt whant away
May 05, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung HLS4266W 43" dlp
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Dec 24, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung 46" DLP
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Nov 08, 2007 | Samsung HLN467W 46" Rear Projection HDTV
SMASUNG DLP 50 HDTV
The ballast that powers the lamp is bad
Oct 12, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
229 people viewed this question
Henry  Thomas
Henry Thomas
