Question about Samsung RB215LASH
I have hooked up the water line for the auto ice maker but it still won't make ice.
  • Samsung Master
  • 43,501 Answers
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Posted on Aug 29, 2010
hotuna
  • 288 Answers
SOURCE: HOOK UP OF ICE MAKER TO THE WATER LINE
At the back bottom of the fridge there will be a coil solenoid. If your appliance is ice make ready this will be there, these coils have a bracket that has fitting for a water connection. Get a 1/4 tube with a ferrell and nut. slide them on the tube and connect to the fitting.
Posted on Dec 06, 2007
  • 25 Answers
SOURCE: adjusta ice cube maker not working
Have you checked if water is comming out the tubing before hookup? A valve may be close...
Posted on Dec 10, 2007
The ice maker is not making any ice, or water or crush ice. The wheel that crushes the ice will not spin. Please help
Posted on Aug 19, 2008
  • 3 Answers
SOURCE: Brand new Kenmore refrigerator, ice maker does not work
According to the manufacture, you must wait 24hrs to reap the benefits of the automatic ice maker. I was helping a friend the other day install a water line to a side by side unit that had been running for well over a week and after turning the water on we got no ice. We contacted the manufacture and they said "there is a 24hr waiting period". This makes no sense. I wasn't trying to get a gun permit, just ice.
Posted on Jan 13, 2009
  • 5370 Answers
SOURCE: ice maker stopped making ice.
Ice maker stopped making ice. For this problem you have check few things. First thing, is the water filling in the ice maker chamber and then ice maker not making ice? Or, the water is not filling in the ice maker chamber so it's not making ice. If the water is not filling in the ice maker chamber then it's clear that ice is not getting made due to no water in the chamber. For no water filling, the problem is either water supply valve turned off so water is not filling. Turn on the water supply and it will fill. But if the water supply is turned on then the other possibility is ice blockage in the water fill tube. There is a tube from which the water runs and enters the ice maker chamber. If this tube is blocked then water will not enter the chamber. The tube needs to be defrosted, by using hair dryer. This procedure melts the ice collected in the tube and water starts running again. But if water fill tube is completely clear and no ice blockage or any other blockage. Then other possibility is water valve at the back of ice maker unit. This water valve is for letting the water in the ice maker. The water valve open only for 7 seconds and in this time the water fills in the ice maker chamber and then water valve closes and the same procedure runs again in the next water filling cycle.------- For your information I will mention that there are two valves. One is the main valve the back of the fridge section. This main valve lets the water enter the refrigerator and other valve is at the back of ice-maker section. This other valve lets the water to enter the ice maker. In most of the cases the fault is water valve at the back of ice maker section. ------------- The other above possibilities which I gave you is water not filling in ice-maker chamber so it's not making ice. But now consider that water is filling in ice maker chamber but it's still not making ice. Then the problem is ice maker unit itself. This unit is controlled by main board. But in most cases if water is filling the ice maker but it's not making ice then its faulty ice maker unit. So see if the problem is water not entering the ice maker then the water fill tube is frosted by ice or the water valve at the back of ice maker is faulty. Replace the valve. ------------But if ice is getting made in the ice tray,but the ice is not ejecting out then there is blockage to the ice ejecting blade.May be some ice is got stuck below inside.Clear all ice frost collected under the ice chamber.And then see.---------------
You can get required parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks. Helpmech.
Posted on Feb 21, 2011
Frigidaire gallery side by side won't send water to ice maker tray, but will to water dispenser
Hello Jim czyryca - From what you are describing if the ice maker is not making ice but is dispensing water, sounds like the refrigerator has a frozen water line, faulty ice maker valve or bad component that sends power to the ice maker valve when needed. The ice maker cycles internally to call for water so I strongly suggest contacting a professional to move forward accurately to assist with the repairs.
Jan 24, 2013 | Frigidaire FRS3R5EMB Side by Side...
The water is leaking from the ice maker . how can I turn it off, or close the tap
U can trace the line back to where it hooks in to water line and un hook it
Dec 19, 2012 | Refrigerators
The ice maker
see this causes and fix it. God bless you
Makes to much ice or won't shut off.
Check shutoff arm. This may be hung up on ice or food item.
Makes no ice.
Check shutoff arm. Check to make sure it is getting water, check water solenoid. Check water supply line it may be frozen or plugged up. Check freezer temperature to low of a temperature could cause the line to freeze up. Check for power at motor. You will need to remove the ice maker. Find the leads that go to the auger and connect a voltmeter. Press the dispenser lever you should have power if not replace the control board or micro switch. Check control switch or microswitch. Put icemaker in test mode. Only some are equipped.
Ice cubes to large or small.
Adjust size by removing cover and turn adjustment screw + or -. Check water solenoid. Check water supply line. Make sure it is level.
Ice tastes bad
Clean ice tray. Check supply line. Check water solenoid. Change filter. Run at least a 3 gallons of water thru the line after replacing filter this will flush all old water.
Ice is discolored.
Check water solenoid. Check supply line. Change filter. Clean ice tray. Run at least a 3 gallons of water thru the line after replacing filter this will flush all old water.
Most ice maker problems require either replacing the ice maker unit or the ice dispenser control board or micro switches.
Sep 28, 2012 | Washing Machines
My LG refrigerator has the ice maker hooked up to the hot water heater, is this right. MY HOT WATER HEATER HAS SLUDGE IN IT THAT IS GOING INTO THE ICE MAKER AND MAKING FOUL SMELLING AND TASTING ICE. ...
Having ice maker hooked up to hot water side is common practice...because the water is heated before it gets to be sent to the ice maker, it would have less air in the ice...kinda like a crude way to distill the water.
The sludge is from mineral deposits in your water...sometimes called hard water.
One of the best investments in areas of hard water is a water softener system, in-line water filters, or a combination of both.
Ya might look to see if there is a filter in the refrigerator to filter water before it gets to the ice maker as well.
Hope this helps...
Jul 24, 2011 | LG Refrigerators
Need info on how to hook up ice maker lines
OK the ice maker is the boss. It calls for water. Nothing else in the ice box controls the ice maker water but the ice maker itself. How? Fancier models use capacitance of ice mold to correctly fill the ice mold. On board intel monitors the temp of the ice mold by sending power through it and checking for differences in capacitance in the mold. When it hits the sweet spot it monitors the temp till it temps inside the mold determine ice is there and kicks in the harvest cycle. Older styles simply put a measured amount of water into the ice mold at the end of each harvest cycle. You gotta first run a water line to the water valve and then run a line from the water valve up to the Ice Maker fill spout behind the ice box. Nothing to it.
May 02, 2010 | Refrigerators
Hooked up water line and ice maker, water working notice maker. Any ideas?
Make sure wire loop extending out from the ice maker over the ice bin is pushed down. Up turns the ice maker off.
Without more info, I can't diagnose further.
Stick finger in ice tray where ice freezes. Is there water in there. No, check solenoid valve and water line to ice maker (kinks). Is there ice cubes in ice tray? Is ice maker pushed fully in? All wires to ice maker on back and underneath connected?
If this information was useful, please select YES to the first two rating questions. Good Luck and thank you!
Oct 24, 2009 | Maytag MSD2756G Side by Side Refrigerator
Water shooting out the icemaker hose
(I hooked up the lines and water goes heywire) You hooked up the lines to what? If you changed the water valve you may have the dispenser and ice maker lines reversed along with the electrical connections to the top of the valves.
May 13, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Apr 22, 2008 | Refrigerators
How to hook up Ice & Water dispenser on freezer door
The water valve is on the back of the refrigerator. The water line connects directly to that valve. If there is no line available then you will need to run one from a cold water line in the plumbing using a drill type (1/4") saddle valve on that pipe. Hope this helps. If you need more instruction let me know!
Oct 06, 2007 | Refrigerators
Samsung RB215LASH Logo
247 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
