Question about Car Audio & Video
I lost the instructions for my dash install kit FD2080, it is going into a 03 ford winstar
3 Suggested Answers
  • 246 Answers
SOURCE: Lost brakes 98 ford winstar. Car setting for 1
Check your vacum hose to master brake cylinder.
Check your oil level, check your brake rubber cables.
Could be leak in rear brake cylinders
Posted on Dec 31, 2009
lpfaff1
  • 11573 Answers
SOURCE: I can't get the back line off my fuel filter on a 03 ford winstar
Tracy, If connectors are like in first video I linked,push line in on filter this will make tabs easier to push in, press tabs in on connector, then pull off hose while holding tabs in. You may have to spray WD40 or like oil to help free up and a lot of turning and wiggling, some stick on really good. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Ford Fuel Filter Replacement Windstar
How To Remove Ford Fuel Line Fittings Without Fancy Tools Quick Disconnect...
Windstar 2003 Fuel Filter Change
Posted on Apr 20, 2016
Apr 20, 2016 | Ford Cars & Trucks
Were is the rear rem on 2001 ford winstar located
not sure on 01 but on 03 it is on the back drivers fender panel.
Jul 14, 2014 | 1999 Ford Windstar
WHERE TO FINE 02SENSORS IN A 03 FORD WINSTAR
The O2 sensors are mounted in the exhaust pipe before and after the catalytic converter if that is your question.
Feb 21, 2013 | 2003 Ford Windstar
DEH-1200MP to '95 ford ranger i would like to know how to install it successfully and what sort of adapters and harsnesses i will need
Metra part numbers:
  • dash kit \ 99-5802
  • wire harness \ 70-5600
the dash kit comes with specific instructions and on the pioneer harness and metra harness just match all the colors up and your done
Jun 14, 2010 | Car Audio & Video
I need instructions on how to install an after market stereo in a 2006 Ford Fusion SEL.
Buy a metra dash kit and it will have step by step instructions,you will need harness too ,donot cut factory wires.!!!!!!!
Jun 03, 2010 | 2006 Ford Fusion
Dec 30, 2009 | 1998 Ford Windstar
Plastic box of wires to big for my new cd player after taking my old cassette player out
You wll need a stereo installation adapter kit. This will change the dash opening to the size you need, oftentimes by replacing an entire dash panel for a factory look.
http://www.bestbuy.com/site/olspage.jsp?skuId=8520442&type=product&id=1218019640369
Here is a link to the dash kit for your car at Best Buy. These will come with detailed instructions. Let me know if this helps :)
May 22, 2009 | 2000 Ford Focus
Airbag light flashes 3 times then 6 times then stays on
This is for the driver's side air bag.
This may be due to a high resistance or poor connections in the side air bag (SAB) wiring harness circuits or restraints control module. This condition may occur on vehicles equipped with, or without, side air bags.
Ford has a Technical Service Bulletin out on this no. 03-24-1.
To service, install an overlay harness which incorporates soldered terminals and tin wiring. Refer to the service procedure for direction on which side air bag kit to order. Installation instructions and illustrations are included in the kit.
FOR VEHICLES WITHOUT THE (SAB), FOURTH DIGIT OF VIN IS "Y" OR "Z" :
  1. Install a new Non-SAB wire harness kit 3L2Z-14B455-AB. Refer to the installation instruction sheet included in the kit.
FOR VEHICLES EQUIPPED WITH (SAB), FOURTH DIGIT OF VIN IS "C" OR "D" :
  1. Install the appropriate harnesses as indicated below. Refer to the installation instruction sheet included in the kit.
    • 1999-2001 4DR Limited Explorer XL2Z-14B455-DB
    • 1999-2001 4DR Explorer (except Limited) and Mountaineer XL2Z-14B455-AC
    • 1999-2000 2DR Explorer XL2Z-14B455-BC
    • 2001 2DR Explorer 1L2Z-14B455-AC
Apr 17, 2009 | 1999 Ford Explorer
Ford Winstar ain't startin'
Yes the alternator you installed is fried. Take it back and then when you put the new one in disconnect the battery first before installing. If the battery is connected while installing it will ALWAYS fry the alternator. Most parts guys don't tell you that so live and learn. This should help.
Jan 16, 2009 | 2000 Ford Windstar
Car Audio & Video Logo
29 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
