Question about Electrolux Guardian Bagged Canister Vacuum
Clog in handle/hose
Small rubber ball got sucked up and is caught in the handle or hose. How can I take it part to remove the object?
  • Anonymous Mar 23, 2014
    I foot from handle
    Problem Solver:
  • 6 Answers
I would try puting the hose in the blower port (most of the time the port is the same as were the filter sticks in)
hope this helps:)
Posted on Jul 29, 2008
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=113654&thid=579130
Clog in handle/hose
Posted by TCow on May 08, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. in some cases the Electrolux handle will come apart but id not then I use a couple of methods, if you have another canister vacuum or shop vac then turn on the Electrolux and the other canister vacuum and try to pull the ball out one way or the other. Or you can use a wire coat hander and create a little hook on the end and insert it into the handle portion of the vacuum to see if you can pull out the ball or loosen it so that it will roll out. One other choice that id you have a long small broom handle the length of the hose or longer and then you can push the ball out but the handle has to be smaller than the size of the inside of the hose and also be VERY CAREFUL… because it is an electric hose and it is very expensive so if you cannot remove the small ball bring it to a local vacuum cleaner dealer or the absolute last resort is to replace the hose, but most clogs can be removed. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 27, 2008
Got a small rubber squeezable ball stuck about 2-3 inches from opening Miele silver moon
Take a 3 inch drywall screw or deck screw and screw it into the ball. Make sure that you thread into the ball about at least a half inch. Slowly work Out the ball backwads
Dec 04, 2016 | Vacuums
Doesn't suck when hose is in
If your Nilfisk doesn't suck with the hose on it, and it sucks from the body with it off, it means that the hose is blocked. I have had Nilfisks when I worked in hotels and have seen this before. Push a broomstick down the tube from both ends after removing the metal handle. There is a rubber seal with a plastic ring. Remove the ring and the seal will stretch and come off the ball on the end of the metal tube.
Mar 24, 2016 | Nilfisk Vacuums
I have a bissell lift off revalution pet 6860-h and its not picking up very good i think the house could be plugged but I dont know how to take it apart to be able to get to where it is plugged at
First unplug vacuum and remove the dirt container. Remove the upper tank and check for clogs at the inlet at the top. Feel inside the hose from there, as the bend is a common place for fluff and debris build-up. If the clog is here, remove what you can, replace the tank and container, and turn it on. Anything left may get sucked on inside.
If not, hold the hose grip at the powerhead end firmly and pull up.
Check the powerhead passage first. Any clog here can be pushed back through with a wooden spoon handle or similar object.
Turn the vacuum on to check for suction at the end of the hose. If none, drop a marble or coin into the end of the hose and lift so it drops into the dirt cup. If it doesn't, there's definitely a clog in the hose. You should be able to clear it by using a broom handle to push it through to the tank.
See pages 11-12 of the manual if these don't help.
Here's where to get a copy of the manual if you need it.
http://www.bissell.com/assets/0/132/134/228/c5ec572a-8f1e-4ff8-bbbd-5314b7582140.pdf
Mar 05, 2011 | Bissell Vacuums
Hi, my vac is not sucking well like it used to. I
If your machine has a removable hose, it may need cleaned. When the hose is removed you'll be able to look inside and see any bulky objects lodged there. Be careful removing the clog to prevent puncturing the hose.
The manufacturer's website will likely have links to service in your area.
Feb 24, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
We have suction at the outlets but when we plug the hose in we have no suction at the carpet vaccuum head.
Is there suction at the end of the hose? If not, the hose is clogged. Generally the blockage is located near the handle, but sometimes at the other end. Occasionally, if something long, like a straw, is sucked up, it will get caught somewhere else in the hose that's impossible to get to.
You can try to hold the wand end of the hose directly to the CV tank and turning it on. This should clear the clog. If not, hold the handle end to the blower of a shop vac or canister and turn it on. The other end should be either in a large plastic bag, inserted in the in port of the vacuum, or directed outside.
If there is suction at the end of the hose, the most likely place for a clog is at the elbow on the power nozzle or just behind the brush. This can be cleared by using the handle of a wooden spoon or similar blunt object to push the clog back out toward the brush.
If none of these help, take the vacuum to the nearest Aerus Electrolux store for assistance.
http://www.aerushome.com/storelocator/
Jan 16, 2011 | Electrolux Central Vacuum
I have some sort of object in the hose of my Epic 6500. I have tried reversing the hose and blowing out the foreighn piece of debeis but this has not worked. Is there a way to remove the plastic...
By reversing it, I assume you plugged the hose into the exhaust blower on the top of the machine. If so, insert the other end into the intake and turn one the vacuum. This way the clog is also getting sucked at what should be the loose end.
If it's a sock or similar item, it will be more difficult. Yes, the handle can be removed, but can sometimes be a bit difficult to put back together for someone not real sure of what they're doing. I've seen several hoses ruined by having sharp or pointed objects inserted to clear a clog, cutting the hose and/or wiring, and ending up burning it up. I recommend taking it to a shop and letting a trained technician take care of it. An authorized Aerus Electrolux dealer would be best.
Oct 14, 2010 | Electrolux Epic 6500 Vacuum
The main machine is not sucking up dirt but you can use the hose with an attachment and it still sucks up o.k.
There's probably a clog in the tube in the power nozzle. Detach hose and drop a marble or similar size object down tube. It should roll through and out at the brush. If not, there's a clog and it needs to be removed.
Oct 06, 2010 | Dyson Vacuums
Have a small ball caught in between the handle and the hose and was wondering if the handle comes off
Depending on which style hose you have:
Dolphin Handle: There is a small retaining clip on the hose that can be removed by a flat head screw driver. Make sure your hose is not connected to the inlet and the power cord is disconnected from the inlet valve. If not you will receive an electric shock
Non Dolphin Handle: There are two screws under the handle. One at the back and one by the suction control. Remove those two screws, and pull the wire cover off by the suction control and when the piece is removed the hose should slide right out of the handle.
Aug 14, 2010 | Electrolux Centralux Vacuum
I sucked up some toilet paper in my central vac, and not it has almost no suction. How do I remove the block?
Toilet paper shouldn't clog a central vacuum system. There was probably already something in there that caught the toilet paper and made it worse. Here is a good resource that might help:
How to unclog a central vacuum system
Nov 06, 2009 | M&S Systems AirVac AVP1200 Platinum Series...
Electrolux Guardian Bagged Canister Vacuum Logo
430 people viewed this question
Top Electrolux Vacuums Experts
Roger Potts
Mike Cairns
Mike Cairns
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
