Question about Husqvarna Craftsman 36cc, 16 In. Gas Chain Saw
What kind of gas/oil mix does this use - Husqvarna Craftsman 36cc, 16 In. Gas Chain Saw
    President:
  • 2,220 Answers
Oil Mix Ratio:
The following ratios have been recommended for the last 10-15 years.
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
McCulloch, Poulan & Wen; recommend 40:1.
1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
Chinese chainsaws recommend 25:1.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Aug 30, 2010
  • dontbother10
    dontbother10 Sep 01, 2010
    Craftsman saws are manufactured by Poulan.
    Your OM probably recommends 40:1
Howtoinstallafuelfilteronacraftmanchainsawmodel358351061
Posted on Oct 05, 2010
Do i mix the gas or use straight gas
The answer is that ALL 2-stroke engines requires that you mix oil with the gas. ALL 4-stroke engines do not take oil in the gas. So the simple answer is if there is no place to add oil, then you have to mix oil in the gas - not the same kind of oil though! I don't know this particular model, but I have never seen a 4-stroke wearable leaf-blower. The kind on wheels could be either, but most (maybe all) are 4-stroke.
Sep 18, 2012 | Homelite Leaf Vac Attack
What kind of gas
Regular unleaded gas mixed with 2 cycle oil. (You need to check your model for mixture ratio but 30:1 (thirty parts gas to one part oil mix) is usually a good place to start) You can find mixing instructions on the back of the 2 cycle oil container
Dec 08, 2010 | Garden
I have 2005 sportster and i cant get my oil cap off,oil that mixes with gas,also what kind of oil should i use,that mixes with gas...thanks
oil doesnt mix with gas on a 4 stroke motor--u have a dry sump or independent oiler for the crankcase-cap may be stripped cud use a rubber gripper onit--use the lubricant a dealer tech sez
Aug 16, 2010 | 2005 Harley Davidson XL 1200 C Sportster...
For an 80 cc kawasaki dirt bike what kind of oil mixes with the gas and in what ratio and what kind for engine oil?
I WOULD USE AMSOIL,OR RED LINE SYNTHETIC OIL ( WILL MAKE TOP END LAST ALOT LONGER).. AND THE MIX IS 32:1..... AND FOR ENGINE/TRANY OIL YOU CAN USE BEL-RAY ( BEST IN MY OPINION)
May 20, 2010 | Fender 2 Stroke Full 49cc ATV # ATG-47B...
What kind of oil does my 2003 rm 125 need
For the gas tank= 2-stroke motor oil mixed at 32:1 *stock mixing ratio* [that's 32-parts gas to 1-part oil]. **[I personally use a 40:1 mixture for trail riding,..and 50:1 mixture for racing at the local MX track].
Mar 16, 2010 | 2003 Suzuki RM 125
What reatio of gas to oil? And what kind of oil?
32:1 / 40:1 will be fine.... your choice of pre-mix oil...pick your fav brand . use a ratio-right cup and make it simple
  1. Pump one gallon of gasoline into a gas can. Ads by Google
    '; for(i = 0; i '+ '' + google_ads[i].line1 + ' ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
    ' + '' + google_ads[i].visible_url + ''; } s += ""; document.write(s); return; } google_ad_channel = '+7733764704+1640266093+9911500640+3322788282+9016233241+8962074949+8941458308+0371618899+7122150828' + xchannels + gchans; google_ad_client = "pub-9543332082073187"; google_ad_output = 'js'; google_ad_type = 'text'; google_feedback = 'on'; google_ad_region = "test"; google_ad_format = '250x250_as'; //--> google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
  2. 2Measure out the proper amount of two cycle oil in the Ratio Rite.
  3. 3Pour the required amount of oil into the gas can with the gasoline.
  4. 4Shake the container lightly until all of the oil is thoroughly mixed in with the gasoline.
  5. 5Pour the mixture into the machine`s gas tank.
Jan 23, 2010 | 2004 kawasaki KX 125
What kind of oil should I use to mix with the gas?
you can use any type of two cycle fuel mix just make sure its for two cycles then mix 8 ounces of two cycle oil to 2 gallons of gas that will give 32 ratio which should run fine with that mix if its to rich it will smoke alot but I would rather have it alittle rich then to lean which is not enough oil to the and can seize up
Nov 05, 2009 | Garden
I guess he needs to know what kind of oil he needs also
you shouldn't need to mix oil with gas on a four cycle engine. this is for two strokes.
Aug 23, 2009 | Garden
I dont have the manual and Im not sure what ype of oil I should put on this chain saw. On the left The nob sais oil (which kind?) and on the right side it sais oil/gas mix (which kind?) what do i put on...
The Left knob needs chain oil. Available in most hardware stores. The right is gas mixed with 2 stroke motor oil. Usually a 50:1 mix. Ie. 50 parts gas to 1 part oil. 2 stroke oil comes with a built in measuring tool and directions printed on the bottle.
Jun 03, 2009 | Garden
Husqvarna Craftsman 36cc, 16 In. Gas Chain Saw Logo
272 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
