Question about Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum
Ken 116 31912100
While vacuuming, i heard a single noise found roller brush not turning didn't see any belt when removed top if there is one where would it be? any solution
  • 1 more comment
  • Roy54 May 24, 2008
    Model number 116 35923500. Brush will not spin. Didn't hear a noise, just noticed it wasn't spinning. The reset button was sticking up, suggeting the circuit breaker had tripped, but pressing it didn't make a difference. Looked for an actuator switch where the hose goes in but didn't see one.
  • anniem319 Oct 19, 2008
    Me too - noticed unit wasn't picking up as well and noticed brushe wasn't spinning - didn't hear a noise.
    I had this a short time - is this a piece of junk vacuum?
    Help please? anniem319@yahoo.com
    thx,
    Anne
  • jkhaines May 11, 2010
    Regarding the actuator, can anyone provide more specifics on where this is located and what it looks like?
    Problem Solver:
  • 3 Answers
Mthomas--the exact same thing happened to me as "Apprentice" above. The small white plastic piece fell out while I was cleaning the agitator, and I didn't know where it came from. At least I was smart enough to keep track of it, and was able to get it back where it went. All was fine after that.
Great website!!!
Posted on Jan 11, 2009
Reddevil16,
hit the solution on the head.
just watch the small plastic part that hits the acuator switch. it's small, white plastic. when I took mine apart, couldn't figure wher it came from. the only way the brushes will turn is to engage the switch.
Posted on Jul 26, 2008
    President:
  • 1,673 Answers
No belt, this is direct drive, the motor is part of the brush roll. If you go to sears.com, click on parts, put in you rmodel number, it starts with 116.*********. It will bring up a parts list along with a picture breakdown for you to look at, and you can order parts there also. You might also check where the hose goes into, some of these have a switch there, when you push the hose in it hits an actuator that engages the switch. This actuator breaks and then the brush roll won't turn because it can't engage the switch.
Posted on May 08, 2008
2 Suggested Answers
galati2k
  • 281 Answers
SOURCE: ken 116 31912100
open the bottom and you will see where the belt goes.clean off the motor shaft before putting on the new belt .the old belt might have left some rubber on the motor shaft.clean the shaft or your new belt won't last very long
Posted on Apr 10, 2009
Bissell heavy duty 9x cyclonic vacuum cleaner has loud noise when brush roller is turned on
Inspect the area around the brush roll. There may be something stuck somewhere in there. Remove the brush roll to see if the brush roll end caps will spin freely. If there is hair or debris restricting the brush roll may be causing noise.
Feb 19, 2015 | Bissell Carpet Cleaner Powerbrush Deep...
Tip
How To Replace The Belt on The Riccar 8850 Upright Vacuum
Greetings from GoVacuum,
I will attempt to walk you through the belt change on your Riccar 8955 upright vacuum cleaner. I have taken pictures for you for each step to ensure that it's done properly. What you'll need to have handy for this repair;
- Phillips Head Screw Driver
- Riccar 4000 / 8000 Series Belt
- Riccar 8000 Series Roller Brush With Clutch Assembly (only if the brushes have worn down, not necessary if brushes are still long)
Step 1: Make sure the vacuum cleaner is unplugged, and turn the vacuum cleaner upside down so the bottom plate is upwards. It's easiest to do on a work bench or counter top.
Step 2: Unscrew the two metal screws on the metal bottom plate with your Phillips head screw driver, and remove the bottom plate from the vacuum cleaner so the belt is completely exposed with the roller brush
Step 3: Remove the belt guard that sits to the left of the roller brush, and is a metal part that protects any dirt & debris from going over to the belt. Here's a picture of that part being removed;
Step 4: Remove the Rug / Floor actuator arm from the clutch on the right hand side of the roller brush. Simply pull the metal actuator arm to the left of the brush and out of the circle that it sits in. Here's a picture of that;
Step 5: Once you have removed the actuator arm for the clutch, as well as the belt guard, lift straight up on the roller brush and remove the roller brush from the vacuum cleaner:
Step 6: Once you have removed the roller brush, and the old belt from the vacuum cleaner, take one new belt and wrap it around the metal pin in the back of vacuum cleaners agitator housing. Here's a picture of where that pin is located with the belt wrapped around it;
Step 7: Once you have the belt wrapped around the metal pin (this is the shaft to the motor that actually spins the belt), but the other end of the belt through your new roller brush;
Step 8: There is a specific way that the roller brush has to be inserted. If the roller brush is not put in properly, this can cause all sorts of problems including the brush not spinning, and continuously having to replace belts. You can see on the end cap of the roller brush (the right side where the belt rides) that there is two little teeth that protrude out of the end cap as well as an indentation on the opposite side;
Step 9: With the roller brush inserted through the belt, position the two teeth facing downwards. You can see in the vacuum cleaner where the roller brush sits, a little groove down inside of the housing. These two teeth need to straddle that groove. Also make sure that the little ring, or circle that the clutch actuator arm sits into, is facing upwards completely. It should be directly on top of the two teeth. Stretch the belt using the roller brush as leverage down into the agitator housing of the vacuum cleaner, making sure that the two teeth are facing downwards straddling the little groove. After the brush is back into the vacuum cleaner, take the metal actuator arm from the rug / floor switch, and insert it back into the metal ring (or hole) on the roller brush;
Step 10: Replace the metal belt guard that rests to the left of the belt. You'll notice on the belt guard that there are two little 90 degree notches on both sides. These notches need to face towards the belt or to the right. Here's a picture of the belt guard being put back into place;
Step 11: After inserting the belt guard back into the vacuum, turn the vacuum cleaner over so the top of the agitator housing is facing you. Change the the rug / floor switch from bare floors to the carpet setting, and the turn the vacuum upside again so the brush and belt are exposed:
Step 12: With the vacuum set to the carpet setting, pull the belt forwards to ensure that the brush is spinning freely. If the belts do not spin freely, repeat steps 2-10.
Step 12: There is a flap that can be opened after the metal bottom plate has been removed, that will give you more access to the motor shaft. Make sure that this flap is closed;
Step 13: The last tricky part can be reinstalling the metal bottom plate. There is a little lip on the front of the vacuum cleaner that the edge of the bottom plate has to slide under for it to be installed properly. A lot of people just install the bottom plate over top of this lip, and this prevents the brushes from hitting the carpet as low as if the bottom plate is correctly installed. Here's a picture of the lip with the bottom plate in the backgroud;
Step 14: Slide the metal bottom plate into the lip on the vacuum cleaner, and fasten the screws back into the bottom plate to secure it. The lip is a little tricky, but after doing it just once, you'll have no problems in the future changing your belt.
Here's a picture of the bottom plate installed INCORRECTLY with the bottom plate over top of the lip;
Here's a picture of the CORRECT way to install the bottom plate:
I hope that this repair solution is helpful to you in installing the belt properly. If you found this helpful, please be sure to click the 4 Thumbs Up Icons in the top right hand corner of the solution. Feel free to request a clarification of the repair if you have any questions about this repair, or other repairs. I'm always happy to answer any questions.
Thank you very much,
Chris J.
on Mar 21, 2010 | Riccar 8850 Vacuum
Tip
How To Replace The Belt On Riccar 8850 Upright Vacuums
Step 2: Unscrew the two metal screws on the metal bottom plate with your Phillips head screw driver, and remove the bottom plate from the vacuum cleaner so the belt is completely exposed with the roller brush.
Chris J.
Trying to change the belt
things you will need Vacuum belt
  • Screwdriver
  1. Locate and purchase the correct belt for your Eureka vacuum cleaner from the local grocery or department store. Vacuum belts come in different sizes according to your model of vacuum. Check your owner's manual or the vacuum itself for your model number.
  2. Turn your vacuum cleaner over so that the bottom of the unit is facing you. Remove the cover plate from the bottom by undoing the screws that are holding it in place with a screwdriver.
  3. Locate the belt pulley rod near the back of the vacuum base coming out of the motor. With the vacuum cleaner base turned upside down and facing you, the motor and pulley rod should be up near the top of the base.
  4. Slide the vacuum brush roller out of the slots at the bottom of the vacuum base and remove the old belt from the brush roller and pulley rod. With the brush roller off of the unit, clean the brush by removing any strings or cords wrapped around the tube.
  5. Install the new belt by looping it over the belt pulley rod next to the motor and then looping around the end of the brush roller in the belt slot. Hold the brush roller and pull back on it to tighten the belt while you slide the roller back into the slots on the vacuum base.
  6. Replace the base cover plate by snapping it back into place and securing it with screws. Turn vacuum back upright and turn it on to test the belt and verify the unit is working
Feb 16, 2011 | Eureka Surfacemax 200 Bagless Upright...
Screeching noise
When a Dyson DC07 makes this horrible grinding noise, it can only mean one of two things.
The Dyson DC07 uprights use a clutch mechanism to control the brush spinning when you change the floor / carpet switch. When you hear this grinding noise, it's actually the clutch slipping because it can not spin the roller brush. Most other uprights use a belt to spin the roller brush, and if something is stuck in the roller brush it will cause the belt to break. Dyson vacuums however will make that awful grinding noise rather then breaking the belt.
When you hear this noise on a Dyson, it can only be 1 of 2 things. Either your clutch mechanism itself has gone bad, or the roller brush itself has gone bad.
I'll be happy to walk you through step by step on how to diagnosis this problem and find out which one of these two parts is bad on your vacuum.
Step 1. Make sure the vacuum is unplugged. Then turn the vacuum upside down so that the brushes are facing up. It's easiest if you put the head of the vacuum on top of a bench, or counter top. This is how the vacuum should look:
Step 2. You see on the bottom of the vacuum 3 plastic screws that are usually the same color as the vacuum cleaner. If you're vacuum is purple, the screws will also be purple. Use a flat head screwdriver, and turn each of the 3 screws a half of a turn, counter clockwise to loosen then. After each screw has been turned (you don't need to remove the completely, just a half of a turn is all), simply pull upwards on the bottom plate to remove it.
Step 3. You should now be able to see the roller brush exposed. You'll now need to remove the roller brush. This will take some patience, and some work in order to get this brush out of the vacuum. There is a special tool that has been designed to help you get the brush out easier. I would try getting the brush out first before buying this special tool. The easiest way is to use a flat head screw driver and pry the belt up while pulling up and out on the brush. With some patience and some maneuvering, you'll be able to get the brush out of the vacuum. Here's where you should put the flat head screw driver on the brush:
Step 4. Once you get the belt out of the vacuum cleaner, it's time to test it. Use your finger tips to hold just the end caps on the very end of the roller brush. While holding just the end caps, use your thumbs to try and spin the roller brush. Does the brush spin freely? It should rotate completely several times on each spin. If the brush doesn't spin, or you feel some kind of resistance to the brush spinning, then this indicates that your roller brush has gone bad. Here's a picture of how to test the brush:
If the roller brush went bad, then you'll need to purchase a new one. Here's a direct link to the roller brush your machine uses on our website GoVacuum.com:
http://www.govacuum.com/dysondc07.html
If the brush however was able to spin freely, and it spun multiple times, this indicates a little more serious problem of the clutch itself has gone bad. The clutch replacement repair is a much longer, more challenging repair to do. There is a very helpful video on how to replace the clutch below so that you may follow step by step instructions on how to change it. It was really helpful for me the first time I did this repair.
If you need to replace the clutch, here's a direct link to the clutch your Dyson DC07 uses on our website:
http://www.govacuum.com/dydcclasfore.html
Here's the video on how to replace the clutch:
When you hear that grinding noise, it can only be one of these two problems. This clutch mechanism was so problematic that Dyson removed it on the second series of the DC07 models. I hope that this repair was helpful in diagnosing your problem. If you have any questions about the diagnosing, or the clutch change, please feel free to use the Clarification Request form here on the Fixya repair page. If this was helpful you, please be sure to rate my repair as helpful by clicking the thumbs up icons.
Thank you,
Chris J.
GoVacuum
Apr 04, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Beaterbar will not turn and very loud grinding
Greetings,
When the Dyson DC07 makes that horrible grinding noise, there's really only one of two things that can be wrong. I have taken a few pictures to help you try and diagnosis the problem.
The grinding noise is made by the machines clutch mechanism. The clutch is what stops the roller brush from spinning when you change the vacuum from carpets to bare floors. The grinding noise is the clutch slipping, and not being to able to turn the belt. In most vacuums when the belt can not spin freely it will cause the belt to burn or to break. On Dyson's, the clutch mechanism prevents the belt from burning or breaking if you were to get something stuck in the brushes such as a towel underneath of a bad, or tassles on an oriental rug.
So when you hear this grinding noise, only two parts could be bad, the actual clutch mechanism itself, or the roller brush. I'll gladly help you diagnosis, and give you instructions on how to fix your Dyson.
Step 2. You see on the bottom of the vacuum 3 plastic screws that are usually the same color as the vacuum cleaner. If you're vacuum is purple, the screws will also be purple. Use a flat head screwdriver, and turn each of the 3 screws a half of a turn, counter clockwise to loosen then. After each screw has been turned (you don't need to remove the comletely, just a half of a turn is all), simply pull upwards on the bottom plate to remove it.
Step 3. You should now be able to see the roller brush exposed. You'll now need to remove the roller brush. This will take some patience, and some work in order to get this brush out of the vacuum. There is a special tool that has been designed to help you get the brush out easier. I would try getting the brush out first before buying this special tool. The easiest way is to use a flat head screw driver and pry the belt up while pulling up and out on the brush. With some patience and some manuvering, you'll be able to get the brush out of the vacuum. Here's where you should put the flat head screw driver on the brush:
If the roller brush went bad, then you'll need to purchase Genuine Dyson DC-07 Roller Brush for Models That Use a Clutch Part # 904174, then reinstall the new roller brush into the vacuum when you get it.
If the brush however was able to spin freely, and it span multiple times on each spin, this indicates a little more serious problem of the clutch itself has gone bad. The clutch replacement repair is a much longer, more challenging repair to do. I posted a video on how to replace the clutch below so that you may follow step by step instructions on how to change it. It was really helpful for me the first time I did this repair.
I hope that this was able to at least diagnose the problem for you. That horrible grinding noise can only be one of those two problems. If you found this repair helpful, please be sure to rate the repair as helpful by clicking the thumbs up icons in the top right hand corner of the repair. Please feel free to check out our website for your future Dyson vacuuming needs, we have a lot of stuff already on the site, and if we don't have it up, we can definitely get it for you.
Thanks again,
Chris J.
GoVacuum
Apr 02, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
It makes a very loud noise and doesnt pick up much
When they make noise like that there is usually an issue with the drive system (the belt and roller brush). I would try cleaning off the roller brush and putting a new belt on. You can access the roller brush and belt by turning the vacuum over so the brush faces up. There is a cover plate over the roller brush which can be removed by removing the (4) phillips screws. with the cover plate off, you can remove the brush and old belt. clean the brush off really good and put it back with a new belt. This is normal maintenence for this model and should be done every 6 months.
You can get the replacement belt here:
http://www.vacbelts.com/bissell-powerforce-belt.htm
Oct 24, 2009 | Bissell 6594 PowerForce Bagless Upright...
Describe how to replace belt on hoover windtunnel bagless
If you turn the vacuum so the bottom is facing up you will see the base plate that covers the roller brush. There will be four screws (usually phillips head), remove the screws and the base plate will lift off. You now have access to the roller brush and belt. Lift the roller brush up and remove the old belt. Place one end of the new belt over the motor shaft and the other end over the roller brush and put the roller brush back in place. Now simply replace the base plate and you're done! This models requires Hoover belt # 38528033 (single) or Hoover belt #40201160 (2 pack). You can get this belt at www.vacbelts.com.
Here's the pages:
http://www.vacbelts.com/hoover-40201160-belt.htm
http://www.vacbelts.com/hoover-38528033-belt.htm
Oct 15, 2009 | Hoover U5750-900 WindTunnel Bagless...
My brush will not turn, and the brush control is stuck on "off"
I have had problems with the belts on my Mach 5 overheating (smell of burning rubber) and also with the motor overheating and shutting down.
I learned the hard way that one of the issues might be that the roller/brush on the bottom of the unit has a metal bearing inside the roller/brush that can become clogged with hair (both human and pet hair) which effects performance of the unit.
It’s fairly easy to fix.
Lay the vacuum on the floor so that you can see the roller/brush. Then remove the phillip head screws that hold the protective plastic plate over the roller/brush. (There are about 6 screws that hold this plastic protective plate in place) Also, you will be removing the (1) screw that also holds the plastic plate over the belts. There are (2) belts that you can remove and when in doubt replace these (2) belts for around $9.00.
Once you have the protective plastic plate off that covers the roller/brush disconnect the belt is around the roller. Take the roller and cut off any hair that is wrapped around the roller. Next, grab the roller by each end and twist the ends caps and (1) of the ends will unscrew. Once you have unscrewed one of the ends remove any hair or dust that is trapped under this cap. (Be careful not to lose the small metal washer that sit on top of the bearing)You will notice under this cap is a metal bearing that can become clogged and jammed with hair. The hair should come out fairly easy and allow the brush to spin fairly easy once you have screwed the end caps back in place test that it spins freely. If it doesn’t spin freely replace the roller/brush with a new one for about $23.00.
When you put the belts back on the thick rubber one (Belt # 40201-271) has probably become stretched and should be replaced for about $3.00. The small diameter belt that goes over the roller/brush probably does not usually need to be replaced and does not usually fit very tight. I have heard that people will take the small roller/brush belt and turn it upside down to get a better fit.
I just did this on my Mach 5 and it runs like a new machine. I did end up replacing the roller/brush head.
Hopefully you will find this useful.
Jul 05, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Ken 116 31912100
Apr 07, 2009 | Kenmore Progressive Bagless Upright with...
Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum Logo
179 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
