Question about KitchenAid Food Mixers
The kitchenaid tilt head mixer grater attachment won't go all the way on.
SOURCE: Kitchenaid Mixer head wobbles bad
The solution provided by luannej is useful only if your mixing attachment is striking the surface of the bowl. By adjusting the screw located at the junction of the head and base, you are actually controlling how far the head is allowed to tilt forward and, thus, the height of the attachment above the bottom of the bowl. Although the attachment striking the bottom of the bowl will lead to wobble (and noise!), it isn't usually the root cause of the wobble. In fact, the wobble may be causing the bowl strikes and adjusting the head height only hides the problem.
The head of the mixer is secured to the base by a large steel pin. Any play between the head and base comes from this hinge and its resulting tolerances. To "tighten" the sloppy tolerances causing your wobble, follow these steps: 1) Lock the mixer's head down and turn the entire mixer upside down. 2) Looking deep into the hollow base, find the small slotted set screw. This screw actually presses against the pin and takes up the slop between the head and pin. Note that this screw is not the large slotted screw I mentioned earlier visible when you tilt the head back. 3)Tighten the small set screw as much as you can. Your wobble should be greatly reduced or eliminated now. 4) Lastly, you may want to readjust the large screw controlling the head's tilt to optimize the distance between attachment and bowl. Hope this helps.
Posted on May 24, 2009
  • 145 Answers
SOURCE: Are attachments for a KitchenAid K5 compatible with the K55?
Kitchenaid stand mixer attachments are considered universal, which means compatible with all mixers. However, all Hobart attachments pre-date the new motors of Kitchenaid and would not be compatible with Kitchenaid mixers.
Posted on Jul 08, 2009
  • 145 Answers
SOURCE: Kitchenaid Mixer will not lock
This sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
If the flat beater is striking the bottom of your bowl, this may cause the locking mechanism to loosen and may cause the mixing head to "bounce" during use.
Your Use and Care Guide will cover the "beater to bowl adjustment," which you can do at home in a few minutes with a flathead screwdriver.
Hope this helps!
hslincoln
  • 235 Answers
SOURCE: My kitchenaid ksm150ps standing mixer's top seems
Hi DENISE, by the symptoms you describe it appears that it’s time to adjust your mixer’s Beater to Bowl Clearance adjustment screw, or head locking mechanism (or a component) of it is worn or loosened due to normal wear and tear and needs to be readjusted (or repaired) to keep your mixer head stationery and level.
The instructions for adjusting your beater to bowl clearance are located in your Owners Manual. If you don’t have the original manual you can easily download a PDF version of your Owners Manual from the KA website: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number, in your case KSM150 and select the file listed for your model that appears under Owners Manuals (66) KSM150PSER1.pdf (732.33 KB) and save that file to your PC. Turn to Page 14 and you will find the instructions for adjusting the mixer head height.
But to save you some time, I have extracted the instructions below:
Your mixer is adjusted at the factory so that the flat beater just clears the bottom of the bowl. If for any reason, the flat beater hits the bottom of the bowl or is too far away from the bowl, clearance
Tilt-Head models
• Unplug mixer.
• Lift motor head.
• Turn screw (A) SLIGHTLY counter clockwise (left) to raise flat beater or clockwise (right) to lower flat beater.
• Make adjustment with flat beater, so it just clears surface of bowl.
If you over adjust the screw, the bowl lock lever may not lock into place.
If the above doesn’t correct your problem, then you need to look at the Link & Lever Latch assembly. If you don’t have your parts list manual, select the file KSM150PSWH0.pdf (773.44 KB) listed under the Parts List Manual (61).
The manual provides an exploded view for the disassembly and reassembly of your mixer, along with all the part names and numbers. Turn to page5, titled: Base and Pedestal Unit. You’ll want to focus on Illus. #11, Link & Lever Latch assembly, and the related components, which locks the mixer head to the pedestal when you run the mixer. Check to see if something is just loose, exceedingly worn or broken. If something has broken, you can order replacement parts and install yourself.
Here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com. Prices can vary widely between vendors, so do your comparison shopping.
Also, while your mixer is apart it would be ideal to check for any other unseemly wear and tear on the gears, etc. It can be messy but quite gratifying to diagnose and repair your KA mixer yourself.
Finally, here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble, repair, and reassemble your mixer.
Finally, if you feel this is beyond your capabilities and will be too difficult to do by yourself you can take your mixer to a local small appliance repair shop and have them troubleshoot and fix your mixer. KA Customer Care can provide you with the name and phone # of the closest authorized KA repair shop in your area or you can do a Online web search, but be sure to get at least three estimates before deciding to commit to one repair shop.
Good luck. I hope this helps. Howard, Burke, VA
If this solution has helped you, please rate it, thanks! – hslincoln
Posted on Dec 23, 2009
  • 5 Answers
SOURCE: Brand New Kitchenaid Artisan Mixer - Mixer head is stuck
Unplug the mixer, turn the whisk the opposite of normal rotation in a quick motion, the remove a per normal.
Posted on Feb 20, 2010
Kitchenaid stand mixer motor head fell off
You didn't say which model KitchenAid mixer you have. Assuming that it is a tilt-head, and that the metal portion of the motor housing joining it to the base did not break, the Service Manual can be had at:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
Apr 16, 2017 | KitchenAid Food Mixers
How to use food grinder attachment
The mixer's planetary is not disconnected when the meat grinder is attached and continues to turn.
If the noise you hear only occurs when the grinder is in place, then the grinder may be assumed to be the cause. Consult the meat grinder's instructions and make sure that nothing is loose or overtightened.
Mar 04, 2015 | KitchenAid Kitchen Aid K45SSWH Classic...
My Kitchenaid mdl: KSM 155gbca is making a loud bumping noise with or without an attachment.
It is more than likely in the planetary or the fuse gear inside the gear box. Try it once you have the planetary off before you go looking inside the gear box. Easiest is planetary problem but far far more likely is the fuse gear.
Aug 08, 2014 | KitchenAid Artisan Series Tilt-Head Stand...
Does the epicurean have an attachment for ice cream maker?
The Model: the Kitchenaid KAICA attachment will work with all Kitchenaid mixers 4.5 to 8 quart models both tilt head and bowl lift.
Aug 03, 2014 | KitchenAid KT2651X Epicurean Stand Mixer
Hello, I don't have a problem yet, but have found this model on sale. I think it is discontinued. I would like to know if I can still get attachments for it? Am considering the smaller less expensive...
Most of the attachments for KitchenAid stand mixers are for use on all KitchenAid stand mixers regardless of series--as long as they have the attachment hub on the front.
Mar 03, 2011 | KitchenAid KSM50HDPBK Stand Mixer
The mixer attachment is hitting the bottom of the bowl. how can I lift it up?
It's difficult to answer without knowing what make or model.If I were to guess it is a KitchenAid tilt head model then there is a screw that is visible when the head tilts up. Turn this screw to adjust the head height.
Feb 11, 2010 | Food Mixers
Can't attach ice cream maker dasher
If the bolt is the hinge pin that the head swivels on when tilting it up, it can be pushed back in when the head latch is released and the mixer head is lifted slightly.
Jan 17, 2010 | KitchenAid Artisan Series Tilt-Head Stand...
Kitchen aid 300 watt counter mixer model ksm90
no there is no adjustment . worn hinge on the base , no parts made , not that i have ever seen ...... sorry i wish i had better news
Jan 05, 2009 | Hobart A200 Stand Mixer
Oct 24, 2008 | KitchenAid Artisan Series Tilt-Head Stand...
KitchenAid Artisan Stand Mixer - Tilt is Tilting too Much & hits the bowl!
This may have a simple solution: This sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
Sep 23, 2008 | KitchenAid KITCHEN AID 5 Quart Artisan...
Food Mixers Logo
119 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
