Question about Philips Magnavox 51MP392H Rear Projection Television
I have a phillips magnavox 9p5511c1 projection television. the problem im having is one that one day the tv would not display any picture but the green light was on. not sure about sound. unplugged for a few weeks. plugged back in and it worked fine for a day. the next day the sound still worked but the screen is very dark. adjusting the picture and brightness settings does not cure the problem. any ideas?
  • 3 more comments
  • cornyrock Aug 30, 2010
    Would the failed convergence chips cause the screen picture to kind of roll when first turned on? Also it has black bars on each side like it's not displaying the picture completely. How much are the kits and what kit should I look for?
  • cornyrock Sep 05, 2010
    i replaced the convergence chips and all 12 supplied resistors carefully rechecking all my solder joints and the tv is still doing the same thing. On one video input i have a wii installed. When the wii goes into "burn-in" protection mode the picture on the tv screen is ok as in clear but dark with bowed sides. When the protection turns off the screen begins to bow concave and convex till it shuts off and does it again
  • cornyrock Sep 19, 2010
    what does that say?
    i have a phillips magnavox 9p5511c1 projection television. the problem im having is one that one day the tv would not display any picture but the green light was on. not sure about sound. unplugged for a few weeks. plugged back in and it worked fine for a day. the next day the sound still worked but the screen is very dark. adjusting the picture and brightness settings does not cure the problem. any ideas?
    I have already replaced the convergence chips and resistors that coincide with them
  • Philips Master
  • 5,807 Answers
Convergence is a way to far,
you may have to check for 200V line to your CRT Board
which is connected to the Flyback
Posted on Sep 21, 2010
  • 666 Answers
Sounds like your power supply is going on you the part usually isnt too expensive but having a technician replace it may be a pain If its still under warranty I would suggest returning it but otherwise id say somewhere between 150-250 for parts and labor
hope this helps
Robb
Posted on Sep 19, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The issue is with the failed convergence (STK) ICs which needs to be replaced. It’s not a difficult job if you want to do this yourself, you should require some basic knowledge about soldering-resoldering components. To start with you’ll have to open the back of the unit and then replace the ICs(STK ICs) which are located behind the black heat sink and also check theresistors as if they are short the ICs might blow again after sometime. Please check this picture:
There are repair kits available whichincludes repair instructions with the parts, if you want to do it yourself, you can buy and repair it yourself. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 29, 2010
  • Rylee Smith
    Rylee Smith Aug 30, 2010
    Yes you are right and you can click on this link for the repair kits which you can buy for as low as $65. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
  • 1,141 Answers
Sdfasdfdf
Picture but no sound on magnavox tv
My tv which is phillips has sound but no picture,there is two red lights on the front that comes on ,one is for power but what is the other one
Jun 20, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
PTV835 PICTURE SHRINKS
Hello, I dont have a solution but I am experiencing the same problem. Did your tv get fixed ? Any solutions that you can offer ? Rudy
Jan 13, 2010 | Philips Magnavox 9P6034C 60" Rear...
Picture is small then gets large then gets small again.
Probably a voltage regulator problem. It's not something you can fix yourself unfortunately
Aug 28, 2009 | Philips Magnavox 9P6034C 60" Rear...
MAGNAVOX PROJECTION TV- GOOD PICTURE , BUT NO COLOR
you need the ssm panel. You can get a replacement panel for your model at the following link.Which is the correct board for your model it controls color, convergence and etc.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-ptv900-series-ssm/cName/sale-items
Apr 21, 2009 | Philips Magnavox 9P6034C 60" Rear...
Red "aura" in the middle of my 55" Phillips Magnavox
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Feb 01, 2009 | Philips Magnavox 9P6034C 60" Rear...
Phillips Magnavox 60" model ptv835
Recently had same issue and after EXTENSIVE SEARCHING found all three ICs and replaced them. TV works perfectly, also, replaced convergence ICs at same time. The one 16-pin IC for the regulation ckt. is $49.95 the other 16-pin IC is $19.95 and the 8-pin opto is about $10. This price is for a minimum qty. and must have a business for quote.
Aug 29, 2008 | Philips Magnavox 9P6034C 60" Rear...
Phillips Magnavox 60 inch tv
not showing a picture are making a sound.
Jul 05, 2008 | Philips Magnavox 51MP392H Rear Projection...
No picture
voltage tripler...and deflection bd........
Jan 13, 2008 | Philips 55PW9363 55" Rear Projection...
Adjusting colors on a magnavox 46" projection TV
Replace the CRT fluid. It grows algea in the blue and green only. 9.99 from MCM electronics.
Oct 19, 2007 | Philips 46PP9302 46" Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
107 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
