Sony Handycam DCR-DVD105 DVD Camcorder Logo
Posted on May 08, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony camcorder - USB mode
When I connect my camera to my computer to view the video I shot, I consistently get a message on my computer that says I need to install macromedia flash player. I have installed it, but still am unable to view my videos on the computer.
also the LCD screen on the camera simply says..."usb mode" but no controls for me to hit play or anything.
can you help? thanks!
Anonymous
Level 2:
Champion:
  • Expert 203 Answers
  • Posted on May 10, 2008
Anonymous
Expert
Level 2:
Champion:
Answers
203
Questions
Helped
54617
Points
461
The usb mode is usually reserved for removing pictures from memory card through camcorder to computer-using camcorder as web cam-new models can stream lower quality video from camcorder to computer-for a dvd cam use a converter box ie pinnacle movie box to convert analog A/V connections to usb and that will stream the correct way-
Hi HRU? Sir pls tell me how I can copy my Movies from Cam Coder of Sony DCR-HC28E in my pc although I have connect via usb cable to my computer but no any reply i foud. So pls guide me how I can?
This is the step-by-step for downloading from your camera as found on Sony's tutorial page:
  1. Turn on the computer.
  2. On the computer, install the USB driver for the digital camcorder. Note: Only the USB driver included on the supplied CDROM will properly enable the digital camcorder for USB streaming. Alternatively, you can download the USB driver here.
  3. Turn on the digital camcorder to the VTR, VCR or PLAYBACK mode.
  4. Turn on the USB streaming feature of the digital camcorder.
  5. Connect the USB cable to the digital camcorder.
  6. Connect the other end of the USB cable to the computer.
  7. Cue the video to the beginning of the video footage to be transferred.
  8. Start the video capture software on the computer.
  9. Begin playing the recorded video in the camcorder.
  10. Begin importing the recorded video with the capture software.
I cant seem to be able to transfer my recordings to a DVD recorder on my computer The video recorder is a Sony DCR-TRV22E.My computer is PRYON. PRY-i922vp
If the Computer is having Windows Vista installed on it then it's required to use a compatible i.LINK or Firewire cable to connect the Camcorder to the Computer.
Once the connection is established, you can use Windows Movie Maker to transfer videos from the Camcorder to the computer. Make sure that the Camcorder is set to the "VCR/VTR" or "Play/Edit" mode and the tape is playing in the camcorder before importing the videos to the Computer.
If you're having Windows XP on the Computer and using USB cable to connect the Camcorder to the Computer then it's required to install the USB streaming driver and the USB driver for connection on the Computer before you can establish a successful connection between the Computer and the camcorder for transferring videos.
You can install the USB streaming driver using the supplied Software installation disc.
4helpful
My Sony Dvcam DCR-HC15E Mini DV Digital Camcorder is not being seen when I plug it into the USB port on my computer. I have downloaded a program called Driver Robot which is supposed to update my computer...
Go to camcorder Menu and enable USB Streaming option.
Computer / Windows will recognize camcorder and will install drivers automatically for further communications.
Thanks.
1helpful
2answers
Video transfer
If you're using a Windows Vista Operating System it'snot possible to transfer the videos from the Camcorder to the Computer using the USB connection. The videos from the tape camcorders cannot be transferred to Windows Vista Operating System as there is no USB Streaming ooption available on the Windows Vista Operating System. The Camcorder uses the USB Streaming function to transfer the videos to the Computer. You may wish to purchase a i.LINK/Firewire cable to connect the Camcorder to the Computer in order to transfer the videos from the Camcorder to the Computer.
or
There is an update for driver on the Sony website to transfer the videos from the Camcorder to the Computer using the USB cable.
http://support.sony-europe.com/dime/downloads/downloads.aspx?site=odw_en_GB&m=DCR-HC42E&f=usbdrven_vista
You may also try installing the driver update for the Camcorder. The i.LINK cable gives a better video transfer qulaity than the USB transfer. The i.LINK cable used to connect the Camcorder to the computer depends on the number of pins available on the i.LINK/FIREWIRE port on the Computer. The i.LINK port on the Computer is a D shaped port which is labelled as i, DV, IEEE1394 and Firewire.
PUEDO UTILIZAR MI CAMARA DE VIDEO SONY DCR-SR 30 COMO WEB CAM PARA MI ORDENADOR PORTATIL, ASUS?
Si puedo utilizar su camara por eso. pero, la directiones estan en engles.
Primero es para S- Video
La orta mas pavajo estan directiones para USB Streaming
How to use a Sony® camcorder as a Web cam with a composite video or S-video connection.
Solution
sp.gif sp.gif IMPORTANT: The computer must have a composite Video or S-Video input jack [FIG. 1]and compatible webcam software installed. Some computers may require a video capture card and/or sound board.
NOTE: This procedure cannot be performed when using the battery of the camcorder as a power source. If the camcorder is turned on, but not recording or playing a tape, it will automatically turn off after 5 minutes to conserve battery power. In addition, please be advised that this procedure may not work for all Sony camcorder models even when using the AC power adapter. Some models have an automatic demonstration mode that will activate after 5 minutes if the camera is turned on but not recording or playing a tape.
  1. Plug the AC power adapter for the camcorder into a working electrical outlet and then connect it to the camcorder.
  2. Connect a composite video cable or S-Video cable to the VIDEO or S-VIDEO jack on the camcorder. NOTES:
    • Sony camcorders usually come packaged with composite Audio/Video cables; S-Video cables are sold separately.
    • To purchase either of these cables, check with your local electronics dealer or visit the Sony® Parts and Accessories Sales Web site or by call (800) 488-7669.
  3. Connect the other end of the composite video cable or S-Video cable to the VIDEO IN or S-VIDEO IN jack on the computer.
  4. Turn on the camera by moving the POWER switch to the CAMERA position.
  5. Remove the cassette tape from the camcorder.
  6. Turn on the computer.
  7. Start the webcam application to be used. NOTE: Contact the software manufacturer for assistance with setting up or using the webcam software.
[[Direct Accessories and Parts Center, DAPC]] How to use a Sony® camcorder as a webcam using USB Streaming. Solution
  • Not all Sony® camcorders are equipped with a USB Streaming port. For compatibility information, or if you require further assistance with any of the steps below, consult the instruction manual of your camcorder. A copy of the camcorder instruction manual is available in the Manuals/Specs/Warranty section of the Sony® eSupport Web site
  • The USB Streaming driver is not compatible with the Apple® Mac OS® operating system.
  • The computer should have a factory installed USB port and compatible webcam software, such as Microsoft® NetMeeting®.
  1. Install the USB Streaming driver on the computer from the CD provided with the camcorder.
  2. Restart the computer.
  3. Plug the AC power adapter for the camcorder into a working electrical outlet and then connect it to the camcorder.
  4. Connect the supplied USB cable to the camcorder and computer.
  5. Turn on the camcorder by moving the POWER switch to the CAMERA position.
  6. In the camcorder menu, set the USB STREAMING option to ON .
  7. On the computer, start the webcam software.
1helpful
2answers
Can not import film to PC.
I have a partial solution for those whose files come up as audio. connect your camera via USB. Windows Movie Player should recognize the camera when you select capture device. When you have your camera selected hit next. Put the file in My Video and title it. When you are ready too capture video Hit play on you camera while in the review screen. The Movie Maker will then capture your video as it plays in the camera.
3answers
Camcorder/computer
after connecting the CAM to computer switch the CAM to play back mode. (the mode in which you view the shot photos or files)
if it dosent work please contact the customer care
3answers
Camcorder connection to pc computer
you can install picture package software which comes any ofusual sony cybershot digi cam. I think that might work..try that and revert back to me.
2answers
Sony dcr-dvd201 unable to connect via usb to xp pro computer
I've learned my lesson here. Firewire and maybe WinDV is what I setup all the time now.
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
